Old 03-29-2009, 01:17 PM   #1
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Default ej257 cams drop into ej255???
im looking into cams for my 06 wrx (ej255) the only ones i find are for ej257or ej205. my builder/tuner says they look very similar to his ej257 but he is not sure if i will retain the avcs which he said is a big deal. are there any 280/280 cams out there for my car that retain avcs??
godforbid67 is offline   Reply With Quote
Old 03-29-2009, 04:41 PM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
GSC sells cams that fit the EJ255.
06rexwagon is offline   Reply With Quote
Old 03-29-2009, 06:15 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
lol, cams aren't based from engine, but heads?
Nuke209 is offline   Reply With Quote
Old 03-29-2009, 06:18 PM   #4
06rexwagon
Member#: 114730
[email protected]
The block on the EJ255 and 257 are the same. It's the heads that are different.
Old 03-29-2009, 09:36 PM   #5
godforbid67
Member#: 137168
06 Built SGM WRX
hmm ill check them out, so ej257 wont drop in there fine?
Old 03-29-2009, 09:40 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
hmm so the gsc only go up to 272 though? i was looking into 280's.
Old 03-30-2009, 09:04 AM   #7
Nuke209
Member#: 108089
2003 WRX
NF Performance
yes, OP should be more specific (example, 2004 sti cams drop into 2006 wrx heads)
And yes, any sti cams should drop into your 2006 wrx heads.
btw, the 06 wrx cams are the same as the sti
Old 03-30-2009, 09:37 AM   #8
06rexwagon
Member#: 114730
[email protected]
You would think they are all the same, but I called BC and they specifically told me that their cams don't work in the EJ255 head. Strange though. Nuke is right, the part # for 06 WRX is the same as STi.
Old 03-30-2009, 10:57 AM   #9
Sonnyblk
Member#: 164505
06 WRX TR
CGM
Im running into the same problem i think im going to go the Tomei route. Several people in 06-07 WRX's are running those and its not far off from the STi cams.
Sonnyblk is offline   Reply With Quote
Old 03-30-2009, 12:42 PM   #10
kaos200
Member#: 2692
I wouldn't run the cams from a company (whos job it is to know such info) that gets this stuff wrong.
kaos200 is offline   Reply With Quote
Old 03-30-2009, 12:47 PM   #11
06rexwagon
Member#: 114730
[email protected]
Which is one of the many reasons I bought a set from GSC
Old 03-30-2009, 02:26 PM   #12
godforbid67
Member#: 137168
06 Built SGM WRX
my builder actually just sent my cams (06 wrx) and his cams (04 sti) straight to brian crower, and they are going to make me a custom 280 cam that retains avcs for the regular price too. my builder says the cams look exactly the same but the avcs seems different. they said it should only take about a week to get back too.
Old 03-30-2009, 06:39 PM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
So does that mean you're not agreeing with us that '06 WRX cams are the same??? The WHOLE valvetrain is the same part#s, difference is the head casting.
Wanna see if it's different, go ask for AVCS cam gear, same Part#. JDM EJ255 and EJ207 uses the SAME AVCS cam gear, however different cam specs because of 2.5L and 2.0L Ours is the same part#.
FuJi K is offline   Reply With Quote
Old 03-30-2009, 06:47 PM   #14
godforbid67
Member#: 137168
06 Built SGM WRX
im not saying they are the same or arent.....thats why i started this thread.......??
either way, the cams are already out with brian crower to make a set for my car.
Old 03-31-2009, 07:27 PM   #15
ki11switch
Member#: 176422
if for some reason you dont get them, i might be selling my brian crower 280/280 06 wrx cams
ki11switch is offline   Reply With Quote
Old 03-31-2009, 10:11 PM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
really would be interested if its soon.
and god damn lucky me (fUkk subaru workers) the blown block i bought was torn apart and is very uneven where the heads would mate up i dont even think i can use it! god damn, it can never go right for me, waste of 300 dollars.
BC 272 EJ257 Cams in Ej255 Heads? Ice13 Built Motor Discussion 5 10-28-2009 12:59 PM
WTB: EJ257 with drop in pistons tjphillips36 Private 'Wanted' Classifieds 2 03-02-2009 02:13 PM
identifying marks on ej257 cams? ted dibiase Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 03-10-2008 08:24 PM
EJ257 cams same as 07 WRX EJ255 cams? Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 01-14-2008 03:26 PM
Mn EJ257 cam shafts bikerboy Private 'For Sale' Classifieds 5 09-08-2005 11:40 AM
