#1 |
Member#: 204755
Hey just wondering what the pros and cons are to the SOHC EJ25 and the DOHC EJ25.
#2 |
Member#: 172486
NWIC
Vehicle:95 V4 STi-RA swap Stage 49.8 |
The DOHC were known to have head gasket difficulties.
Edit: For the 2.5rs ones of course Last edited by Smoke; 03-29-2009 at 08:03 PM. |
#3 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
MY05-07(08-09?) SOHC's have great intake manifolds
#4 |
Member#: 60082
Vehicle:2004 Forester STI Silver |
There some dyno graphs floating around directly comparing the DOHC and SOHC engines. Cobb also wrote some tech articles a few years back discussing both engine types. You can't find them on Cobb's site now, but Archive.org's Wayback Machine can give you them from older, stored pages. I know there's been various discussions on both engines. My impression is that the SOHC is basically superior, but there may be cases arguing both ways. With some modifications, the SOHC engine has no problem with top end power.
#5 |
Member#: 161832
Vehicle:2000 Outback Limited Black |
da risin smoke... 2.5rs, aka N/A's, have the SOHC, not DOHC. i have a 2000 2.5L and had the HG changed at around 110,000 miles.
SOHC are fine within the normal 6500rpm redline, but the DOHC flow more b/c they have 2 camshafts doing the work of one. there really isn't anything "wrong" with the SOHC, but i don't think it would be worth it to change to a DOHC if u r currently running a SOHC. i am keeping the car SOHC throughout all the mods i plan on doing. |
#6 |
Member#: 204755
I have the choice between a 98 and 99 2.5rs so I'm just weighing out the pros and cons between the two. Basically I'm just wondering which is better performance wise and which is more reliable and overall which is better
#7 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
You've never seen the 96 Outback with an EJ25D or 98RS with the EJ25D, or any of the few 99RS' that also got the DOHC heads?
![]() Quote:
The SOHC is simple to work on, where the DOHC requires a bit more attention to detail during timing belt changes or headgasket changes. I would go with a SOHC motor for that reason alone. Jay |
#8 |
Member#: 204755
Thanks for the info that was what I was looking for
#9 |
Member#: 161832
99rs switched back to SOHC for N/A's. my bad about the others.
#10 | |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
~Josh~ my woman wants me to put this in.......... she loves it......![]() |
#11 | |
Member#: 206102
Vehicle:1999 2.5 RS Black |
#12 | |
Member#: 5218
I meant the OEM tune on the ECU. Even the base timing is more advanced according to the SOHC FSM ('00). If you have the means to do it, an optimized tune is ALWAYS worth it. There is a substantial amount left on the table compared to the stock maps.
Jay Quote:
#13 |
Member#: 14507
Vehicle:1984 |
Hey guys, I'm looking at getting a 2003 or 2004 Forester. Just wondering when the head gasket was upgraded? Was is 2004 they fixed the problem? TIA.
#14 |
Member#: 5218
#15 |
Member#: 14507
Vehicle:1984 |
Thanks Jay.
#16 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
The 2.5 DOHC has larger intake ports, larger intake manifold runners. The exhaust however is a tad choked where the valve guide support is compared to the 2.5L SOHC. The 2.5L SOHC has decent intake ports, straight shot, but smaller intake manifold runner. Also the SOHC runs a higher compression ratio compared to the DOHC. This gives it more power to start.
If they ran the phase2 shortblock on the DOHC heads, that'd make more power than the SOHC no doubt. If BOTH where fitted with an after market turbo, the DOHC would make more TOP END power because of the better flowing heads and intake manifold. I see a good amount of SOHC turbo's RS's fall off in power above 6000rpms all the time and it falls fast unlike the USDM WRX/STi where the intake manifold is larger. What also plays a roll is the camshafts too.. but... if you ever seen the intake manifold, and heads of the SOHC/DOHC NA and WRX/STi DOHC you'll know wassup. BOTH motors has leaks of their own kind. The DOHC with overheating issues, the SOHC with oil leak issues. |
#17 |
Member#: 204755
to do a swap from DOHC to SOHC would you need to do a complete wiring harness swap?
#18 |
Member#: 5218
Not really.......but the (lack of) EGR and IAC becomes an issue as the DOHC used an externally mounted solenoid. Depending on the year EJ25 you use, the IAC will be a 3 wire solenoid (but still not compatable), or 6 wire stepper motor which is just out of the question.....unless you're good at building microcontroller circuits. Only certain year and emission spec. SOHC motors got an EGR system too.
Otherwise, the motor will start and run fine off the EJ25D ECU.....it'll just have a permanent CEL. |
#19 |
Member#: 175483
Vehicle:97 N/A w/ MS3 Aegean Blue |
Some EJ25D motors had EGR
or did you mean EJ25 SOHC didn't have EGR? (what you said is kind of confusing) |
#20 |
Member#: 133745
Vehicle:1998 Lifted Outback Green + Dirt |
Sorry to drag this back from the past but as Storm mentioned about the DOHC to SOHC swap on a Phase one (1997) ride, it will run and drive fine without an ECU swap or anything but with a perma-CEL.
| Thread Tools | |
| Display Modes | |
| Sohc Vs Dohc Ej25 | BlckBeautyVTEC | Southern California Impreza Club Forum -- SCIC | 3 | 09-22-2006 04:33 PM |
| EJ25 - SOHC vs DOHC | 2.5rsDOHC | Normally Aspirated Powertrain | 8 | 08-04-2004 11:38 AM |
| EJ25, SOHC to DOHC | Honkey3k | Normally Aspirated Powertrain | 7 | 07-22-2004 02:03 PM |
| Subaru EJ25 SOHC & DOHC head components (valvetrain, cams etc) | iON Performance Inc | Vendor 'For Sale' Classifieds | 21 | 03-09-2004 02:34 AM |
| EJ25 SOHC to DOHC and back again? | JoShYo | Normally Aspirated Powertrain | 16 | 11-14-2003 11:24 AM |
