Old 03-29-2009, 06:17 PM   #1
ckcadavona
Member#: 135730
93 L
Default OEM or Aftermarket Oil Cooler?
I was researching an oil cooler setup. The OEM oil cooler is aprox $170. A aftermarket oil cooler setup should run $250-300. What are the pros and cons to running a aftermarket oil cooler without the OEM oil cooler? The car is a stock V5 EJ207 daily driver and at most will see an hpde / year or a few autoX's.
ckcadavona is offline   Reply With Quote
Old 03-30-2009, 11:48 AM   #2
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I know the sti oem oil coolers run coolant through them. I'd keep the oem and add an external also if your autoxing.
methaddict is offline   Reply With Quote
Old 03-30-2009, 12:06 PM   #3
Member#: 189490
^^^ +1. You can always get rid of the OEM and have aftermarket only, what aftermarket oil cooler you have in mind?
Artie@Agile Auto is offline   Reply With Quote
Old 03-30-2009, 02:05 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
For $250-300, not a particularly good one, methinks. A proper oil cooler setup ain't cheap when you add everything up. You're looking at $200 just for a decent sized Mocal or Setrab oil cooler, let alone the AN fittings, the suitable lines, and the sandwich adapter. $400-500 is a more reasonable estimate from what I've seen (and done).
The OEM cooler is only marginally effective. It definitely helps, but even on my N/A EJ25 it isn't enough to bring temps down to where I'd like them to be. On track I saw 260F or so with the cooler, 270F without it. I plan to add an external oil-to-air cooler in addition to the OEM cooler.
Pat Olsen
Old 03-30-2009, 02:16 PM   #5
DoodieHead
Member#: 10236
2001 GC8 [622.4WHP]
SOHC / GT35r 25psi
I am going to be selling my Processwest oil cooler if you are interested. PM me.
DoodieHead is offline   Reply With Quote
Old 03-30-2009, 04:12 PM   #6
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
+1 one for an aftermarket oil cooler. Saw much better results with my B-Line Top Mount Oil cooler as opposed to running just the OEM with thermostat.
mrubino83 is offline   Reply With Quote
Old 03-30-2009, 04:33 PM   #7
ckcadavona
Member#: 135730
93 L
barrowed...
Greddy sandwich plate M20x1.5 (w/built in 180F T-stat) $95...or mocal for the same price
From Summit
B&M cooler with 1/2NPT inlet/outlets (11x5.75x1.5) $63
1/2NPT to -10AN fittings (x2) $9.50
Summit 10AN twist-tite fittings, $42 (2 straights and 2 90's)
10' Summit 10AN twist-tite hose $35
plus mounting hardware=
aprox. 250
Thanks for the input so far...from what I'm gathering the OEM oil cooler makes a marginal difference.
Old 05-29-2009, 02:20 AM   #8
kakarotoni
Member#: 156240
02 WRX
06 Impreza
sorry to bring this back but where do you get most of the supplies to build your own? I searched for the Greddy sandwich plate M20x1.5 and the only site that was selling them discontinued them not too long ago....
kakarotoni is offline   Reply With Quote
Old 05-29-2009, 03:19 AM   #9
methaddict
Member#: 159738
2004 WRB STi
I got all of my oil cooler supplies from www.racerpartswholesale.com. I just picked up a Tru-cool 24 row racing oil cooler for $45. They have 12, 24, 36, and 48 row sizes. I like the built in mounting flange for ease of installation. I bought the Canton sandwich adapter awhile ago, nice piece, billet aluminum, close tolerances, rubber o-ring has a wide foot print. Only thing with the canton you'd have to run a seperate oil thermostat. If you want to make it even easier they have the Mocal sandwich plate with a built in 180 degree thermostat.
Canton is the same company that makes the accusump. They also have the thermostat. I'll be using the Aeroquip socketless fittings and an adapter fittings, I believe I got four 1/2" npt -10an adapter fittings and four 90 degree socketless fittings, bought these awhile ago.
TRU-Cool 24 Row Racing Oil Cooler
TRU-CoolŪ Economy Racing Oil Coolers- 24 Row
New anti-clog design keeps maximum air flow through cooler at all times. Lightweight aluminum alloy is vibration proof. All coolers come with a built-in bracket and a 1/2" NPT fitting. High-tech coolers are so efficient and durable, major NASCARŪ teams use them.
Size: 5-3/4" x 11" x 1-1/2"
Here's an idea of what it'll cost for a setup. Length of hose is just an example, estimate amount of hose needed and add a several more feet because you don't want this line kinked and it's always better to have more than less. You may need some heat resistant sleeve for hose next to the header which they sell also or you can also get it at www.hose-man.com.
Shopping Cart
Description QTY Total Price
-10 Aeroquip Socketless Hose, Black (10ft) $43.70
Aeroquip Socketless 90 Degree Elbow Fitting - -10 Aeroquip Socketless 90 Degree Elbow Fitting (4) $66.72
Aeroquip Straight Male Connector, Aluminum - Aeroquip Straight Male Connector, Alum. -10 to 1/2" (4) $15.40
Mocal Sandwich Plate- 20mm Thread (1) $86.95
TRU-Cool 24 Row Racing Oil Cooler (1) $44.95
* If you have changed the quantity of any of your items,
please make sure to update the cart before checking out.
Total: $257.72
Old 05-29-2009, 04:13 AM   #10
MartinSTi05
Member#: 145145
2006 wrx STi
I am not a fan of the stock cooler because It directly ties oil temp to coolant temp. The differential in temperature between hot oil and hot coolant is not that much on a harsh track day and it really renders the stock cooler useless.
MartinSTi05 is offline   Reply With Quote
Old 05-29-2009, 09:40 AM   #11
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
The stock cooler also helps bring the oil up to temp more quickly since your coolant temp will rise much more quickly than oil temp. The best thing is to use the stock cooler and an external in addition.
boost junkie is offline   Reply With Quote
Old 05-29-2009, 11:20 PM   #12
jacky599r
Member#: 137631
2006 WRX
Red
just to check, which temp rating for the thermostat is suitable for a hot climate like mine. I see 30 deg ~ c 24/7.
jacky599r is offline   Reply With Quote
OEM or Aftermarket oil cooler rvjsoccer Newbies & FAQs 13 02-07-2013 05:15 PM
Built Motor... retain the oil/water heat exchanger or add oil cooler? rlavalle Built Motor Discussion 3 02-20-2007 06:38 PM
Where can I buy a good OEM or aftermarket OIL FILTER, In TORONTO, Canada Tulia Eastern Canada 6 07-18-2006 11:28 PM
oem header and oil cooler question hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-13-2006 11:02 PM
$150 OEM subaru JDM oil cooler kit complete, high pressure oil pump supermoose Private 'For Sale' Classifieds 10 11-29-2005 07:25 AM
