Old 03-29-2009, 08:42 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default Probably not but i thought i would ask...
Will phase 2 ej22 sohc heads fit and work on a phase 1 ej25 block?
Dont ask why...
parkes is offline   Reply With Quote
Old 03-30-2009, 11:47 AM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Yes,
I'm not sure which headgasket you should use or what the ending compression will be but it will bolt up. If you do a search there is probably more info.
yebokmj is offline   Reply With Quote
Old 03-31-2009, 01:57 AM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Yes. Use the HG that goes to your block.
As far as Phase II EJ22 heads, are you talking about post-1996 heads? Or the actual Phase II EJ22 heads that look exactly like SOHC EJ25 heads on the outside?
In any case they will both bolt right up and the CR will be damn near the same for either one. Be sure to run premium gas with that motor. You might be able to get away with mid grade gas, but I never chanced it.
~Josh~
Weird ? but thought i would ask subaruNV Newbies & FAQs 1 03-26-2008 10:17 AM
Biggest partout in NASIOC history? Probably not, but lots of stuff... Joey_WRX Private 'For Sale' Classifieds 50 04-01-2006 03:57 AM
Probably not, but anyone every been to the Seychelles? Unabomber Off-Topic 3 10-07-2005 04:35 AM
Off topic, but I thought I would share.... thorondor Mid Atlantic Impreza Club -- MAIC 1 08-30-2004 12:47 AM
Not for me but I thought you would like to see this CF zerosports wing STR8OUT Interior & Exterior Modification 6 12-23-2002 03:14 PM
