#1 |
Member#: 174494
Hey i have built up a 15grand engine over the last year and ready to run it in.
garret turbo, custom built up cams (cut and re-welded), forged pistons, ACL bearings, EJ20 2.0L closed deck block Just wondering what is the best oil to run it in on? and what is the best oil to run once run in? Also any comments the run in process??
#2 |
Member#: 118239
SCIC
Vehicle:2002 Built Wagon Wife- 2004 Outback SE |
cheap dino, 5-30 IMHO. Don't start pushing it at all until after 500 mi. Then start adding light boost until 1K
#3 |
Member#: 59238
SWIC
i change my oil frequently.after the first 200 miles then 500 miles and then 2k miles. i also didnt go past 3krpm. its good to give it a little boost here and there. my motor burns no oil and runs well.
#4 |
Member#: 174494
Me engine builder said:
"Use Valveline XLD 15w-40 Non-synthetic oil" Does this sounds rite? All help appreciated! |
#5 |
Member#: 103320
Vehicle:2005 wingless aspen white |
you trusted your builder with $15,000 dollars already, why would you stop listening to him now?
A) he knows your clearances, and what weight of oil is required for proper lubrication B) he likes the composition of that certain type of oil C) he will have the best input on engine break-in, so ask him! For my engine my builder and I elected to run the engine relatively hard, letting it see 4-8 psi of boost quite often, and lots of engine braking to seat the rings. We changed oil at 150, 300, and 1,000 miles. I now have 2,000 miles and will be switching to synthetic on the next change. |
#6 |
Member#: 174494
yea im allways getting seccond and third opinions though. do it rite the first time is what im trying to do as this is my first build
#7 |
Member#: 141952
Vehicle:03 emo 8/2011 wrx |
benw is on the right track. baby it and it WILL burn oil. the rings need cylinder pressure to push them into the cylinder walls. dont beat the piss out of it, but do run it under mild boost and vary the throttle position and load a lot.
#8 |
Member#: 185347
Vehicle:2002 EVO3 bugeye wag EG33 Swapped 2 dr RS |
i babied mine for the 1000 miles, with also some some what hard pulls and engine breaking to get the rings set. My builder also said to run cheap 5-w30 dino oil, then change at 100, 500, 1000 miles then at 1000 i could run any oil.
| Thread Tools | |
| Display Modes | |
| 1st drag run in my built car !! VIDEO | brokenarrow | Proven Power Bragging | 27 | 06-22-2008 06:08 AM |
| New Motor Built and Running. Details Inside. | kharris4 | Built Motor Discussion | 45 | 09-11-2007 11:57 AM |
| high speed run in sti..then check engine light and engine sputters then runs fine? | mpower22 | Engine Management & Tuning | 7 | 02-07-2006 06:57 PM |
| First 1/8 mile runs in new STi... | SpaldingSpeed | Proven Power Bragging | 2 | 05-12-2005 03:17 PM |
| installing my built engine in my garage in feb, need some help or just hang out | STEALTH-WRX | Southern California Impreza Club Forum -- SCIC | 30 | 01-30-2003 11:33 PM |
