Old 04-14-2002, 07:59 PM   #1
2000RS
Member#: 1633
Default Can I change my idle speed?
I know idle speed has been addressed here before but I didn't see any suggestions on how to change it. Is it possible to bump it up a little with a stock '00RS? Thanks.
2000RS is offline   Reply With Quote
Old 04-14-2002, 10:18 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
IIRC there is no adjustement screw because it is set by the ECU.
jeremy
Old 04-15-2002, 09:13 AM   #3
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
From 2000 onwards, you can adjust the throttle stop screw. it is a philips head screw locked in by an 8mm nut.
Adjusting this is not as simple as you think. Cause there is a fine line between idle and high idle (tps related).
But anycase, you can adjust is to a point. After making the adjustment, the idle will surge up and down. You must reset the ecu after adjusting so that it can get used to the new position.
The throttle stop screw is located immediately under the place the throttle cable is secured. The airbox has to be removed to make adjustment easier.
Hope this helps.
JoeT is offline   Reply With Quote
Old 04-16-2002, 09:46 PM   #4
2000RS
Member#: 1633
Hope this helps.
Old 04-16-2002, 09:53 PM   #5
2000RS
Member#: 1633
Hope this helps.
OK this time I'll actually include some text. How much of an increase can you get before the surging and cold morning high idle antics become really noticable? I'd like to be able to add maybe 200 RPM. Is that realistic? Thanks...
Old 04-17-2002, 03:04 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
nope...the ECU is eventually going to throw a code for idle circuit too high.
jeremy
Old 04-17-2002, 10:33 AM   #7
JoeT
Member#: 3956
Titanium
The amount of change you can affect is in the range of 100 - 150 rpm. If you try anymore than that, yes it will throuw a CE light for Idle circuit too high. That's why I mentioned that it is touchy, really touchy, but it can be done.
I've been running this setup for over 8 months, no problems. Yes the ECU does pull it back but not as much as you think.
Hope this helps. Been there, done that, still doing it, haven't touched it, works great, originally did it when experimenting with Cams, and just left it in place.
No adverse effects, been through Cobb spicy, Cobb milds, TWE Cams, and now JA HP Cams.
That's the reason the idle was changed. As you know running Cobb Spice results in lumpy idle, we changed the throttle stop to prevent the engine from almost shutting down when you released the gas pedal same goes for the TWE cams.
Hope this helps.
Old 04-17-2002, 06:23 PM   #8
2000RS
Member#: 1633
Hope this helps.
Thanks a bunch. It's nice to finally get a real answer on this.
My idle speed is inconsistent at Idle, is this normal? LisaPhish Legacy Forum 17 07-15-2003 02:01 AM
Q : How can I change my WRX engine within warranty? GTKim Service & Maintenance 1 09-17-2002 01:06 PM
can i change my username? mario Newbies & FAQs 12 01-30-2002 07:48 AM
Can I change my I-club name? Boom New England Impreza Club Forum -- NESIC 8 02-04-2001 11:47 AM
Can I change my UserName? new2roo Newbies & FAQs 5 11-21-2000 01:34 PM
