Old 03-30-2009, 03:37 PM   #1
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Default how high to rev?
haha this is about my 4th thread this week in here but w/e. my build is
Cp custom cut pistons
brian crower rods
arp head studs
new oem crank
jdm sti oil pump
280/280 custom brian crower cams
brian crower springs and retainers
cosworth bearings
full gaskets including cosmetic head gasket
i think thats it
what do you think i could rev it out too? my builder/tuner says its good to 8k.
i will be running the bolt on atp 35r on meth 25 pounds or so daily. thanks for any help.
godforbid67 is offline   Reply With Quote
Old 03-30-2009, 04:06 PM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
you should state in this thread which block this is?
Nuke209 is offline   Reply With Quote
Old 03-30-2009, 04:10 PM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
sorry its an ej257 out of an 08 sti. does that really even matter if everything has been replaced?
Old 03-30-2009, 04:18 PM   #4
jays05
Member#: 78165
05 STI 35r + e85
Listen to your engine builder / tuner but take into account your oil pressure (which you won't know till it is running).
jays05 is offline   Reply With Quote
Old 03-30-2009, 04:20 PM   #5
godforbid67
Member#: 137168
06 Built SGM WRX
yeah i plan to listen to him, just wanted to see what some of you guys think of revving it that high.
what exactly is your concern with the oil pressure?
Old 03-30-2009, 04:24 PM   #6
jays05
Member#: 78165
05 STI 35r + e85
The old 10psi/1000rpm rule of thumb. So if you see for instance 70psi oil pressure up top, it might not be wise to rev to 8k.
FWIW I have pistons/rods/oem crank/10mm pump, rev to 7800 (max redline per my engine builder) and have around 85psi oil pressure up top.
Old 03-30-2009, 04:25 PM   #7
godforbid67
Member#: 137168
06 Built SGM WRX
hmmm and the jdm pump is 10mm right?? so basically we are in the same boat. do you have cams?
Old 03-30-2009, 04:32 PM   #8
jays05
Member#: 78165
05 STI 35r + e85
jdm = 12mm. I have cosworth cams, supertech valvetrain, etc. and an ATI Balancer which makes me feel better about pushing the rev limit.
Old 03-30-2009, 05:02 PM   #9
godforbid67
Member#: 137168
06 Built SGM WRX
so personally what would you rev with my motor if it was in your car?
Old 03-30-2009, 05:33 PM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
It really depends on what bearing clearances you have.
alcoolaid is offline   Reply With Quote
How high to rev a V7 heads/ej257 motor Javier Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 09-30-2006 03:25 PM
Such a noob. How high to rev? IceWind Newbies & FAQs 23 12-14-2005 10:23 PM
how high to turn boost gain??? TexRex2002 Engine Management & Tuning 1 11-19-2005 02:19 PM
Headlights.. how high to aim? Jonn Newbies & FAQs 5 07-27-2003 09:46 PM
How high a rev can an EJ20T take without damage? Mr. Ixnay Mid Atlantic Impreza Club -- MAIC 3 03-22-2002 08:30 AM
