Old 03-30-2009, 04:53 PM   #1
Marcos Peguero
Member#: 114653
Default front suspension
I have a 96 Sti type RA. need the front shocks...
Does the american RS 2001 fit?????
ho can help me with that.
My car came with blistein suspension stock. I just need to replace them with something hard.
Marcos Peguero is offline   Reply With Quote
Old 03-30-2009, 05:40 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The RS will fit, but it is far from hard. Replacement bilsteins are expensive but good stuff. If you want to keep the springs, you could do Koni inserts to a stock RS/L strut body. KYB AGX would work but they are not the greatest. Coilovers are likely your best bet for something hard.
linsavy is offline   Reply With Quote
Old 03-30-2009, 05:47 PM   #3
Marcos Peguero
Member#: 114653
linsavy
Im not an expert.. but I have 2 problems
1- not a lot of $$
2- I drive somtimes hard..
So I cannot use sotck RS shock... please guide me as I where a 6 year old.
I can buy the KYB AGX for RS?
coilovers? where do I buy them? I have seen some in a page and they are like 2K all 4. certantly out of my league...
Where can I see options?
thanks
Old 03-30-2009, 07:44 PM   #4
jaimebenlasnow
Member#: 188065
Well if your budget is in the 1000 and under go with kyb agx they are adjustable and they seem to be a great setup
jaimebenlasnow is offline   Reply With Quote
Old 03-30-2009, 08:10 PM   #5
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
if your budget is under a $1000 you could get megan coilovers for about $850...
or if your budget is more around $600 you could get kyb agx adjustable + eibach/perrin/h&r springs or something along those lines (probably a used set for $400)
elislider is offline   Reply With Quote
Old 03-31-2009, 08:31 AM   #6
Marcos Peguero
Member#: 114653
I found a place that sells each kyb for 150 each. I can buy the 2 fronts and use the same spring I already have.
Old 03-31-2009, 09:31 AM   #7
linsavy
Member#: 11620
The KYB AGX is adjustable with 4 settings. The KYB GR2 is non-adjustable and about 15% stiffer than stock RS struts, but they cost half as much as the AGX. You could use either, but the AGX would allow you to stiffen them for track use.
No need to change springs, but there are stiffer and lower springs available, but then you would need to change all four.
There are some good sellers on ebay.
Old 03-31-2009, 09:49 AM   #8
Marcos Peguero
Member#: 114653
I think the stock blistein springs are nice for the setup...
I havent seen the GR2??
where can I buy them?
remember I will buy only the front ones....
Front suspension creaking/groaning noise after some suspension work Somboa Brakes, Steering & Suspension 6 06-22-2011 02:45 PM
WTB - CT: Front OEM Subframe / Front suspension U-Brace biggitybakes Private 'Wanted' Classifieds 2 02-17-2009 12:21 AM
Front Suspension brace d00f Brakes, Steering & Suspension 6 10-07-2001 02:31 PM
popping from front suspension... couldnthinkaone Brakes, Steering & Suspension 5 03-23-2001 10:22 PM
Any advice on lowering front suspension (STi)? mpaone Brakes, Steering & Suspension 11 10-20-2000 12:52 AM
