Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-30-2009, 09:51 PM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Are these allowed? (AutoX question)
I'm wondering on the legality of these two components in regards to Street modified
1.) The cusco front Type 2 Lower Arm bar which is the 4 point unit.
2.) Cusco Trunk Power Brace
Any help is much appreciated
JDMFLCL is offline   Reply With Quote
Old 03-30-2009, 10:35 PM   #2
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
nope....puts you straight to prepared class
Old 03-31-2009, 01:42 AM   #3
JDMFLCL
Member#: 180513
Baby Baby C'mon!
thanks for the help
i assume the same goes for fender braces? regardless if its just an oem replacement style one, or the triangulation kind.
And then, i guess while we are at it, the cusco subframe brace to which the rear diffuser mounts to?
Old 03-31-2009, 01:52 AM   #4
BlueDominion
Member#: 73591
Up Back in Boston
Rollin the RSX
If they don't say it's allowed, it's not allowed. The Rulebook is both your best friend, and your worst enemy.
BlueDominion is offline   Reply With Quote
Old 03-31-2009, 02:05 AM   #5
JDMFLCL
Member#: 180513
Baby Baby C'mon!
i'm reading the rule book
and i don't see what the issue would be with a subframe brace as its just going between the 2 sides of the subframe.
the fender braces are illegal though.
Help on the cusco subframe brace?
Old 03-31-2009, 11:40 AM   #6
Crawdads
Member#: 30907
SWP GDB-G
Rule 15.2.E - specifically #2 and #5
Crawdads is offline   Reply With Quote
Old 03-31-2009, 11:51 AM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
care to elaborate
i don't have the pdf.
I assume this is the worst news for the straight across subframe brace?
its just attaches @ 1 point on each side.
its this one
Old 03-31-2009, 12:07 PM   #8
Crawdads
Member#: 30907
SWP GDB-G
care to elaborate
its this one
I thought we were still talking about the FRONT subframe brace (aka H-brace) and responded based on that.
I still think that rear brace is illegal based on the same rule...only Longitudinal braces are explicitly allowed.
Old 03-31-2009, 12:25 PM   #9
JDMFLCL
Member#: 180513
Baby Baby C'mon!
how about the brace like the cusco type 1 or that stock STI brace that goes just straight across like an underside strut bar.
clarified on the attachment thing, not really a big deal to take off.
so i take it as "SFC"s these arent allowed per #5
but they are as close to a underside strut bar as exists....do they count as that?
Old 03-31-2009, 12:39 PM   #10
68Cadillac
Member#: 95901
care to elaborate
This will help. It'll help you will all your Solo Rules Questions.
Remember to chant this mantra:
If the rules do not specifically authorize a modification, it is not permitted.
Do not try to read between the lines. There's no "between". There's no "spirit of the rules". The rules are VERY clear on what is allowed. Everything else is NOT.
68Cadillac is offline   Reply With Quote
Old 03-31-2009, 12:39 PM   #11
neilschelly
Member#: 94902
1988 911 Carrera 3.2
A bar that goes from one side of the car to the other, and only attaches on 1 point at either side of the car should be legal in SM. It's legal in SP and ST.
-N
neilschelly is offline   Reply With Quote
Old 03-31-2009, 12:53 PM   #12
JDMFLCL
Member#: 180513
Baby Baby C'mon!
alright i'm totally confused at this point, i read the rules (15) , i read the next set of rules(16) that contradicted the first set of rules....i need to talk to someone physical. Searching has done nothing as the thread's ive come up upon all turned into flame wars.
i did clarify the front end though, a front tie bar is allowed since it connects the front 2 suspension pickup points. Still absolutely clueless on the rears, but my guess is a resounding no at this point.
whats the difference between this...a front arm bar
and this a Front tie bar
because truth be told they look almost identical to me
i take it #2 is legal because it ties the suspension pickup points together ala strut tower bar, whereas the #1 is tieing together the SF which is a no no unless longitudinally.
Old 03-31-2009, 01:07 PM   #13
68Cadillac
Member#: 95901
i take it #2 is legal because it ties the rear suspension pickup points together ala strut tower bar, whereas the #1 is tieing together the SF...
Yep, It's as simple as that.
Old 03-31-2009, 01:15 PM   #14
JDMFLCL
Member#: 180513
Baby Baby C'mon!
as for the rear subframe brace....it mounts in the same mounting position as the Rear sway bar.....does that help its classification?
would it fall under the "RSB" classification?
it goes pretty much
crossmember-subframe mount-plate-swaybar mount
Old 03-31-2009, 02:03 PM   #15
68Cadillac
Member#: 95901
it goes pretty much
Do the rules state you can run a brace between the swaybar mounts?
Old 03-31-2009, 02:28 PM   #16
JDMFLCL
Member#: 180513
Baby Baby C'mon!
they specifically state you can run a cross chassis brace if it mounts to the suspension pickup points ala a normal strut bar/ hence why the tie rod bar is ok, and i figured since the swaybar/rear subframe brace bar do likewise on the rear...same deal.
Old 03-31-2009, 02:34 PM   #17
68Cadillac
Member#: 95901
Yes or No, Do the rules state you can run a brace between the swaybar mounts?
Old 03-31-2009, 02:39 PM   #18
neilschelly
Member#: 94902
The rear subframe brace goes from one swaybar pickup point to the other? If the brace connects between the inboard sides of that lateral links or suspension arms, I think it would count as suspension pickup points. I don't know why it would connect to the sway bar mounts though, or am I missing something? Do you have a picture of it installed?
-N
Old 03-31-2009, 02:42 PM   #19
PolarisSnT
Member#: 85905
2004 WRX
The first bar pictured attaches to the rear control arm mounts.
The second bar pictured attaches the subframe together.
Based on what you stated about tying suspension pickups together being legal than bar one should be fine. Bar two is out because it only attaches to the subframe.
Both of those bars installed together pretty much equal the H-brace.
PolarisSnT is offline   Reply With Quote
Old 03-31-2009, 02:42 PM   #20
JDMFLCL
Member#: 180513
Baby Baby C'mon!
product description from JSC
"The Cusco WRX/STi rear subframe brace joins both sides of the rear subframe to reduce flex and movement associated with larger diameter swaybars and other rear-suspension components. It is designed to bolt under the stock swaybar mounts, it will NOT fit with any afermarket swaybars that come with upgraded mounts (i.e. Hotchkis, Cobb, and Perrin) and will improve feel and traction by reducing unwanted flex. With some additional components, this brace will allow for installation of the OEM 06 STi rear diffuser."
i see so i got it mixed up, so its the type 1 bar i want.
Old 03-31-2009, 03:24 PM   #21
Davidss
Member#: 27446
Those bars aren't going to make a difference in your autocross times. Save your money and buy better tires.
Davidss is offline   Reply With Quote
Old 03-31-2009, 03:32 PM   #22
Crashmaxx
Member#: 94028
2002 Porsche 911
I think he wants it so he can have the super cool sti diffuser.
Crashmaxx is offline   Reply With Quote
Old 03-31-2009, 03:34 PM   #23
JDMFLCL
Member#: 180513
Baby Baby C'mon!
yeah kinda... i'll admit it somewhat because of the nice aesthetic (widebody wingless...completes the look) + buttdyno chassis stiffening.
i ordered some 255/40/17 Federal RS-R's to learn on this year, and hopefully sooner or later, graduate to R comps (prob after two season).
ugh i feel ricey, prob should just stick with the original plan and upgrade from a 20mm to a 22mm RSB.
the more i read, the more it seems that my big swaybars negate any real gain these would do.
Old 03-31-2009, 04:01 PM   #24
PolarisSnT
Member#: 85905
2004 WRX
Well the two bars I were talking about were for the front of the vehicle. This one is in the rear. Which end of the car do you want to brace?
Old 03-31-2009, 04:08 PM   #25
JDMFLCL
Member#: 180513
Baby Baby C'mon!
i was talking about both of them, but i resolved the front end situation, now im just focusing on the rear
are these mods allowed in SM? Homemade WRX Motorsports 13 09-23-2004 10:25 AM
Office toys. Are you allowed to have them, and what are they? bruticus Off-Topic 19 12-24-2003 10:52 PM
