Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 03-30-2009, 09:57 PM   #1
JOE_1985
Member#: 154035
05 Legacy GT
Garnett Red Pearl
Default 97 legacy gt swap questions
ok heres the scoop. My red 05 was involved with a hit and run last october by a semi. i was going to fix the car myself (long story really dont want to get into it) but then i decided to sell it as is and use the money to fix a toyota mini truck im currently restoring and use the left over money towards school.
while browsing today i found a local 97 legacy gt awd 2.5 auto for 500. The trans is shot and the engine is knocking. Im thinking of swaping the ej255t and 5speed manual from my lgt into this 97 ive found.
im pretty good at mechanical work, the wiring id send off to a pro (im up for recomendations). so im looking at swaping the engine and trans myself. Is there anything that needs to be fabbed ,swapped or will they just drop in?
Im going from a automatic to a manual, whats involved in changing over the bits. ive done similar work in the past but it involved toyota and rwd. Also would i be able to use the front brakes from the 05 legacy gt on the 97?
im very serious about this and would like helpful imput.
thank you
JOE_1985 is offline   Reply With Quote
Old 03-31-2009, 04:19 PM   #2
JOE_1985
Member#: 154035
05 Legacy GT
Garnett Red Pearl
bump: or of anyone can point me in the direction of a newer sti drivetrain swap it would be helpfull. my doner car is a 2005 lgt with almost the same ej25t cept it has a weaker intercooler , manifold an vf40 turbo
Old 04-01-2009, 01:47 AM   #3
iluvdrt
Member#: 46248
2012 outback 2.5
sky blue
The motor will fit provided you get the turbo cross member, or notch the 97's for the uppipe, and of course the ECU.
The 5 spd conversion isnt bad. The 97 will have all the holes and such to do that conversion. You will have to get the pedal box and slave cylinder resevoir to mount on the 97 plus the lines. Cross member should be the same. You will need the axles. The hubs should be the same and work. You will need the rear diff from the 05 as well, and the driveshaft. The rear axles should be the same since it is a R160 rear end. You will also want the interior bits like the console and shifter boot from another 97.
For the harness ECS (east coast swappers) will merge the harness for around $700-1000 (Last I checked). You send them the harnesses and they will will do it so that when you get it back it is plug and play.
I am sure there are a few things I am forgetting, but this is the jist of it.
iluvdrt is offline   Reply With Quote
Old 04-01-2009, 10:25 AM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Joe,
Since you have the complete LGT you can swap all the mechanical aspects over. You'll probably want to do the fuel tank as well since the 97 does not have all the emissions stuff that the 05 has and you'll need to upgrade the fuel pump on the 97 as well. You can pretty much unbolt the crossmember with the motor and trans on it, drop it out and do the same on the new car. It is a straight forward swap mechanically. Wiring is the killer, you might want to send that out.
Z
Zephyr is offline   Reply With Quote
Old 04-01-2009, 11:01 AM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
uh.. a few things that are ugly in this swap
the imobilizer and can bus will be a killer .. as far as i know it has never been done
you will also have to figure out the rear abs sensors.. the lgt has differnt hubs
lgt uses the abs system as a speed sensor
Old 04-01-2009, 02:32 PM   #6
JOE_1985
Member#: 154035
05 Legacy GT
Garnett Red Pearl
is tehre a way around the immobilizer? As for teh speed sensors, i may see if there is a way to swap those over or the whole rear knuckle
whats a can bus
Old 04-01-2009, 02:44 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I'd send that wiring to Zephyr.
jamesfacts is offline   Reply With Quote
Old 04-01-2009, 02:58 PM   #8
JOE_1985
Member#: 154035
05 Legacy GT
Garnett Red Pearl
if i do this i probally will.
now for the clutch petal assembly and whatnot, would i have to sorce one from a 96-99 manual or can i use my 05 parts?
Old 04-01-2009, 04:44 PM   #9
iluvdrt
Member#: 46248
2012 outback 2.5
sky blue
I have heard the pedal boxes are all the same, but I dont have any hard proof on that.
Old 04-13-2009, 01:44 PM   #10
charliew
Member#: 125304
Why not just swap the entire dash and wiring?
charliew is offline   Reply With Quote
EJ20TT swap into a 97 Legacy GT, would it have the same difficulty as swapping in RS Deucalion Legacy Forum 2 11-09-2009 03:25 AM
ej20tt swap into a 97 Legacy GT, would it have the same difficultys as swapping in RS Deucalion Subaru Conversions 1 11-09-2009 02:19 AM
97 Legacy GT Transmission Swap Questions 97_GT Subaru Conversions 5 04-16-2008 08:20 PM
97-05 legacy gt swap, will i need new fuel pump warped-v Legacy Forum 10 06-01-2006 12:39 PM
('93-'01) ne1 know gear ratios for 97 legacy GT? 2.5GT Impreza Forum 0 06-08-2001 09:43 AM
