Old 03-30-2009, 11:11 PM   #1
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
Default CEL with Cruise Blinking
Well saturday night I get out of work started up my car and the CEL came on with the cruise control light blinking. Drove home car seemed to be running fine nothing out of the ordinary. So i figured ok I'll just go have the code pulled at autozone tomorrow. The next morning I head over to autozone CEL light still on with the cruise blinking, Go inside and the guy tells me they are too short handed to do it today. So I figured I'd just go to a differnt autozone. I get back in the car and there is no more CEL and cruise is working fine and not blinking. WTF. So sunday goes by with no CEL or nothing. Today was good until tonight and the light came on again with the cruise blinking as I was heading home. Im going to try to get the code pulled tomorrow if its still on lol. Any ideas of whats going on guys ? BTW only mods done to the car are Borla Headers, Stromung Dual Tip Catback
CODE THROWN IS P0031
chop204 is offline   Reply With Quote
Old 03-30-2009, 11:58 PM   #2
colorfull
Member#: 136688
2005 Impreza RS
probably the coil pack... they fail frequently on the 2005, and I had the same symptoms when mine failed...twice!
colorfull is offline   Reply With Quote
Old 03-31-2009, 12:12 AM   #3
wmdoucette
Member#: 192709
2007 2.5iSE Wagon CG
2001 2.5RS Coupe RBP
Blinking cruise is to notify you that your computer is sorry, but it can't allow you to use your cruise right now, as there may or may not be something amiss under the bonnet. it's like an initial stage of limp mode, without the limping. Check the code and see where that points you. I hate to ask, but have you checked your gas cap?
wmdoucette is offline   Reply With Quote
Old 03-31-2009, 12:27 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Scan it anyway. The code that previously illuminated the CEL will still be in the ECU. It might give you a head start on ordering parts or allow you to carry a spare in the car for whenever it actually does fail.
Old 03-31-2009, 09:33 AM   #5
STiluv55
Member#: 206102
1999 2.5 RS
If your gas cap is loose, it will set the CEL and not make the cruise light blink. If the cruise light is blinking, there's a problem in that system. If your CEL is blinking, I'd pull over quick as it could be massive amounts of knock or misfires or anything else destructive going on. When it's blinking it means the malfunction in that system happening at that moment. If it's just on stable it created a hard code to memory. Plus if you have less than 15% or more than 85% fuel in the tank, the evap test won't run and therefore a loose gas cap may not show up as a gross or small leak in the evap system code.
STiluv55 is offline   Reply With Quote
Old 03-31-2009, 09:43 AM   #6
scprs
Member#: 172359
2005 STi
I bet you money its just a cat effinciecy or something along that (dealing with the exaust). Seeing that you have an RS that is more than likely it-if you dont have tuning. As for the cruise light it will always blink like stated above its a saftey feature of your cruise control. The newer models have that.
btw i used to have an rs with boria headers along with an n1 cat-back
only way to get rid of that is to use a o2 extension i think fastwrx may sell them.
scprs is offline   Reply With Quote
Old 03-31-2009, 01:34 PM   #7
colorfull
Member#: 136688
2005 Impreza RS
soooo many things can be wrong... You're better off pulling the code first to get an idea.
Old 03-31-2009, 03:49 PM   #8
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
yo it usually goes off for exhaust codes.. mine was when i put my trackpipe on and it just blinks on and off and its a pain in the ass i know haha, you cant use your cruise control either it sucks, and then the cel is on too, it shouldnt be harmful but check it anyways, i deleted mine twice and it comes right back on so its no biggy
smithrcing17 is offline   Reply With Quote
Old 03-31-2009, 03:54 PM   #9
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
ohh and for the MY05 the cel eliminator that you splice in doesn't work, it actually hurts your car.. it throws another code and its p2096 Post Catalyst Fuel Trim System Too Lean so according to williaty that is a bad code because it can potentially hurt your car.. so just let the code go
Old 04-01-2009, 10:03 AM   #10
chrisf_l
Member#: 207292
My wife's '06 2.5i did the same thing this morning. CEL and cruise blinking, with the engine suddenly running rough. She was only a minute from home so turned around came back.
I'm thinking coil pack? Is this common on '06 models?
chrisf_l is offline   Reply With Quote
Old 04-01-2009, 11:33 AM   #11
Odyknuck
Member#: 192866
2006 Impreza
My 06 did this after an accident were the canister was damaged several times and the code was evap failure. It did not effect the way it ran at all. The dealer reset the code ands its been ok for abouit 3 weeks now. Man I hope I did not Jinx myself lol.
Odyknuck is offline   Reply With Quote
Old 04-05-2009, 06:26 PM   #12
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
well the CEL light has been on constantly for the past few days and I went to get it read at autozone and the code that it has been throwing is P0031 which is defined as
Heater Control Circuit Low
with the following probable causes
-open or short circuit condition
-poor electrical connection
- failed H02S11
Any ideas whats going on guys Im prob taking my car in to get looked at later this week
Old 04-05-2009, 06:56 PM   #13
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
- failed H02S11
It's your front o2 sensor, the heater part of it isn't working correctly. replace it and see if that solves your problem. Checker auto parts has universal replacements for about $60.00
Vizzionz is offline   Reply With Quote
Old 04-06-2009, 10:38 PM   #14
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
anyone else ? I'm prob gonna bring my car In for the new o2 sensor Friday
Old 04-07-2009, 08:52 PM   #15
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
anyone?
cel and cruise blinking?~! mcyyy123 Service & Maintenance 7 05-25-2009 01:23 PM
CEL with cruise control lights goign on and off bnr34rb26dett Newbies & FAQs 10 02-12-2009 08:58 PM
06 2.5i CEL with cruise flashing letospeace Service & Maintenance 2 01-28-2007 09:17 PM
CEL and Cruise blinking elitescouter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 11-06-2006 10:46 AM
CEL on, Cruise blinking, and NO CODE SpaldingSpeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 09-09-2005 08:09 PM
