Old 03-30-2009, 11:45 PM   #1
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
Default 182.491mph @ The Texas Mile
I got a chance to test the new motor at arguably one of the funnest race events in the US - The Texas Mile. I've participated in this event since 2007 and like many others that have discover this event, are hooked. In October 2007 I managed 170mph on the stock motor with a Perrin 35R and FMIC with a solid tune from Top Speed and backed that up in March 2008 with a 169mph run.
With the same turbo / FMIC combo and a new motor built by Engine Logics the car ran 182.491mph this past weekend. Those familiar with land speed racing will attest to the amount of power needed to make a 12mph improvement. Hats off to Chris at Engine Logics for a top notch build and Brad for a solid tune. I'll post the speed slip shortly, but here is the in-car video.
beaviscih is offline   Reply With Quote
Old 03-30-2009, 11:49 PM   #2
bgod
Member#: 100274
Very cool and congrats on the speed.
Would personally love to do this event one day.
bgod is offline   Reply With Quote
Old 03-30-2009, 11:51 PM   #3
Sleward
Member#: 107233
2005 Sti
Wrb
Flippin sweet!
Sleward is offline   Reply With Quote
Old 03-31-2009, 12:53 AM   #4
RC0310
Member#: 63479
08' WRX
Can you show us your mod list? thanks!
RC0310 is offline   Reply With Quote
Old 03-31-2009, 01:07 AM   #5
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
Here are the basics...
2.5L pinned block with Darton sleeves
99.5 mm Forged CP Piston and Ring Set
Balanced and cross-drilled crank
Pauter 4340 Billet Connecting Rods
ACL High Performance Bearing Set
ARP Main Stud Kit
Cobb High Flow Oil Pump with additional porting
2007 2.5L Full Port Corrected Cylinder Heads
ARP Head Stud Kit
Cometic head gaskets
Kelford 272/272 non-AVCS cams
75 LB Valve Spring and Titanium Retainer Set
1600cc injectors
EngineLogics top feed fuel rails
JDM Spec C Intake Manifold
Ford Mustang 70mm 4.6L throttle body
Link Engine Management
Walbro fuel pump
Perrin FMIC
Perrin GT35R w/0.82
SMC Meth kit (trunk tank)
Old 03-31-2009, 04:12 AM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Looks fun. What did you rev out to in 6th gear?
alcoolaid is offline   Reply With Quote
Old 03-31-2009, 05:14 AM   #7
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
wow thats cool, id love to run in that event one day.
toutanje is offline   Reply With Quote
Old 03-31-2009, 07:42 AM   #8
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
The RPM limit was set to 8K and I was shifting around 7200-7500 and believe the RPMs were around 7300 when I crossed the mile marker. We looked at the logs and I probably left a little on the table by not shifting a little higher in the RPM range.
Old 03-31-2009, 08:33 AM   #9
mls1
Member#: 167607
2008 WRX
Bad ass. Speed like thet is addictive.
mls1 is offline   Reply With Quote
Old 03-31-2009, 09:06 AM   #10
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Shannon has a very nice signature.
wcbjr is offline   Reply With Quote
Old 03-31-2009, 09:09 AM   #11
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
And nice MPH.
Old 03-31-2009, 09:55 AM   #12
mike1023
Member#: 94790
thats sweet! so for tuning reasons what gear do you tune and do you log when your going at it in the mile? just wondering if you have any logs just to see what is it like 100% throttle in all of 6th gear.
mike1023 is offline   Reply With Quote
Old 03-31-2009, 09:56 AM   #13
mike1023
Member#: 94790
I see you have no wing what kind of down force do you have for the car to keep it stable up top?
Old 03-31-2009, 10:08 AM   #14
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
What kind of power were you making?
Nice job btw!
def
dug-e-fresh is offline   Reply With Quote
Old 03-31-2009, 10:23 AM   #15
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
I logged all but two runs, I even have the two runs made at 50mph (bad TPS and crank trigger threshold issue) lol. Ill see if I can post the 182 run.
As for down force I use a Beatrush front under panel and a carbon fiber rear diffuser. The wing does add rear down force but tends to have the opposite effect on the front. Dropping the front suspension helps if I run with spoiler but then I've added a boat load of drag. IIRC the drag increases as a function of the velocity cubed or something outrageous like that. I remove the mirrors, whipers and speed tape all the seams on the fascia.and pray for a tail wind - which we had Saturday.(very rare this time of year).
Old 03-31-2009, 10:30 AM   #16
gnomodom
Member#: 199478
2009 WRX
Obsidian Black Pearl
I like your reaction when you were told your time..
That's pretty fast too... nice stuff.
gnomodom is offline   Reply With Quote
Old 03-31-2009, 10:48 AM   #17
06njsti
Member#: 150986
06 #001 LSB STi
182 is moving, ive hit 165 (not on 1/4 or 1/8th mile) in the sti but another 15mph has to make a big difference
06njsti is offline   Reply With Quote
Old 03-31-2009, 10:56 AM   #18
bigb402
Member#: 137974
2000 Impreza 2.5rs
STM
Very good job! Congrats!
bigb402 is offline   Reply With Quote
Old 03-31-2009, 11:06 AM   #19
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
i see you just took off not launching the car any reasons why? i would have figured that would help you get up to speed and build boost in 1st gear faster
looks like a lot of fun...awesome run btw!!!
blowbyu24 is offline   Reply With Quote
Old 03-31-2009, 11:19 AM   #20
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
Nice job btw!
def
The car made 502 @27 psi on C16 - dyno dynamics dyno. The dyno charts are in the sticky at the top of this forum.
I'd like to break the 190 mph mark. I wouldn't be shocked if I need at least another 75 to 100 HP at the wheels which means a bigger snail and something other than one Walbarrito and probably larger fuel lines. Chris indicated the rails and injectors have more than enough room.
Old 03-31-2009, 11:28 AM   #21
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Congrats!! I have been very tempted to bring our race car out and run the mile events. I would like to break 200mph with it.
Doug
TopSpeed is offline   Reply With Quote
Old 03-31-2009, 12:13 PM   #22
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
some taller tires might help you with the MPH, but you're right that 25mph tailwind doesn't happen often.. that probably helped a lot.
wrxwhat is offline   Reply With Quote
Old 03-31-2009, 12:19 PM   #23
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Damn, nice run!
gabedude is offline   Reply With Quote
Old 03-31-2009, 12:39 PM   #24
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
You are corrct, It looks highly addictive!
Good job with the drag/wind restriction mods. Thats huge (more than weight reduction) and I have no idea what else you can do to her except make sure she is CLEAN and WAXED like crazy! ANy body prep? I wonder if a diffuser/vortex off the rear window would help with the turbulance in the rear.
Get a BIGGER turbo. the engine will hold up , esp with a great tune and good gas...even if its just for this one event per year. And get some sponsors on that car! haha.
c'dalerider is offline   Reply With Quote
Old 03-31-2009, 12:54 PM   #25
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
A few of the guys run taller tires I just need to break down and spend the money. The tail wind gave me a few mph because we had a 10mph headwind Sunday and I ran 179.
