Notices
Old 03-31-2009, 08:35 AM   #1
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Default Building a high rev motor
My tranny took a dump like 2 weeks ago and I got something that can take some abuse.
I want to start buying stuff for a build motor, I read the stickies.
1st should I just buy a pre build block or build a custom one.
2nd the car is my daily driver.
3rd I want something that I can rev high
4th I would like to run a 35r or a 6262 on e85 with high boost.
About how much will this cost me? Should I start with a used block?
Thanks
Old 03-31-2009, 09:43 AM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Hey Juan, how high do you want to rev? Things you need to consider are oiling and valvetrain. Upgrading the valve springs and cams will give you the top end high rev capability you want. Raw1performance sells a really good block that revs to 8500.
http://www.raw1performance.com/index_files/Page580.html
I just tuned one in an 07 STi with a 35R, stock heads, and BC 272 cams. He made 577whp on E85.
If you start with your own motor, you're going to spend a lot on machine work and balancing.
06rexwagon is offline   Reply With Quote
Old 03-31-2009, 09:58 AM   #3
juanmedina
Member#: 133146
Wow that's not bad at all, do you recommend sleeves as well? Did you take the beast to the track last saturday?
Old 03-31-2009, 10:14 AM   #4
06rexwagon
Member#: 114730
[email protected]
I am not an expert on sleeved motors, but everything I've read says that for a daily they're not a good idea. They tend to have cooling issues and the dissimilar metals expand at different rates, which can cause to head gasket failures. There are plenty of threads on nasioc about it. I didn't take my car Saturday because I blew the rear diff on Thursday. I'm in the process of swapping in my R180.
Old 03-31-2009, 01:46 PM   #5
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
how high do you want to rev? i will be revving to about 8,000 rpm on my new motor which costed just short of 7 grand. its going to be pretty damn expensive to go beyond that. my build is
cp pistons, brian crower rods, brian crower 280/280 cams, brian crower springs and retainers, jdm 12mm oil pump, brand new oem crank, arp head studs, cosworth bearings, and some more little things im sure im forgetting. all that installed was just short of 7 thousand. my tuner said its good to 8k rpms and will make much much power up there on the turbo im goin with (atp 35r).
godforbid67 is offline   Reply With Quote
Old 03-31-2009, 02:56 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
how high do you want to rev, how lumpy of a cam can you stand and how much port velocity can you bear to loose at low rpm?
all questions that should come to mind when deciding on how to go about running high rpm and then actually making beneficial power at high rpm; on a street car.
I think everyone can guess my solution if they regular the built motor threads
Old 03-31-2009, 03:52 PM   #7
godforbid67
Member#: 137168
06 Built SGM WRX
what is port velocity at low rpm???? also what is your cam set up homemadewrx??
you got any sort of videos of it idling?
im so excited to get my car back and cant wait for the lumpy idle!!
Old 03-31-2009, 04:35 PM   #8
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
2.3!!!
kevinh211 is offline   Reply With Quote
Old 03-31-2009, 06:29 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by kevinh211 View Post
2.34 long rod!!!
Fixed if for you
port velocity is the speed of the air through the cylinder heads ports.
that comment was really more to just show the trade off's that can be associated with making a high rpm motor that works well at high rpms. The shorter the rod ratio the bigger the cam and more aggressive the port job needs to be to keep the VE's up...those are essentially your torque curve.
As for video, I'm finally getting time to get my personal motor together I'm have a scheduled break after my current customer's build...I'll be putting the heads and starting on accessories tonight.
Old 03-31-2009, 07:25 PM   #10
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Depends on how high you want to rev. 8k on a motor with high quality bearings and properly selected oil pump shouldn't be a problem.
You could always buy an EJ207, they are designed from the factory to go to 8,500 rpm. I do recall hearing about some of them having problems with thrust bearings, so be careful.
I want to build an EZ30R twin turbo that revs up to 10k. But, feasibility, money, and sanity come into play (it also doesn't have the right bore x stroke for that, no?)
There's a bit of a barrier around 9k, to get past it, you may need a specialized oiling system, or even a dry sump system.
Personally, I'd choose an AVCS 2.0 closed deck turbo motor. Tear it down, put forged everything into it, blueprint the block and heads, and go crazy with cam profiles. There's a lot of specifics to worry about when building a high revving motor, too many to really get into here.
Chi_San is offline   Reply With Quote
Info on higher compression EJ20T high REV build quikcobra Built Motor Discussion 5 03-03-2010 08:35 PM
Build my 2.0l EJ207 or 2.2 Stroke it for 400+ whp and high rev??? prokaw875 Built Motor Discussion 20 11-24-2009 12:10 PM
Damage to motor from high revs? BlkTS02 Normally Aspirated Powertrain 5 04-18-2006 08:36 PM
High REV starts and quick shifting NEWAGEWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 08-02-2001 07:08 AM
('93-'01) sulfur smell with high revs? (going too fast too quick?) nkodemus82 Impreza Forum 5 04-18-2001 05:44 PM
