Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 03-31-2009, 05:57 PM   #1
Member#: 51500
1999 impreza rs-t
Default project mongrel???
Last year I build this MONGREL setup!
Performances modifications:
SOHC head (RS Stock)
Block ej257
Stock 99 RS intake manifold
Stock 99 RS exhaust manifold
TWE Stage 3 turbo Cams(272 HKS)
Wiseco [email protected] compression Piston
K1 Carrillo Rod
Cosworth bearing
Cometics head gasquet
ARP stud
Lachute Hi-Flow oil pump
Cosworth belt retaner
Gates Racing Belt
Lachute 3" Turbo/Back Exhaust
Zero Sport Radiator Wind Deflector
Halley Fuel Pump (650 hp)
K&N Air Filter and Intake
Go Fast Bits Blow Of Valves
Custom Up-Pipe and Down-pipe
Gready Front Mont Intercooler
Garrett GT3076R ar.82 Turbo
Turbonetics Delta-Gate Wastgate
Turbonetics Manual Boost Controler
FAL Engine oil Cooler
Unorthodox Racing Full Pulley Kit
Power Entreprise 850cc Injectors
HYdra Nemesis EMS
This setup was good for 348WHP an 401TQ at 22pis of boost!
This year I replace the X-member to install a real reversed mont turbo kit from Lachute Performance (wrx style), replace the WG for a Tial 44mm, replace the exhaust manifold for a (Fullrace style) Lachute Preformance headers, replace the RS Intake manifold for a 2005 2.5I manifold and install a Hydramist kit! I also replace the smal (23*9.5*2.5) greedy IC for a bigger garret (26*12*3.5) IC!
How much HP and TQ should I targuet to have or gain???
OB2 is offline   Reply With Quote
Old 04-01-2009, 04:13 AM   #2
Member#: 30798
2001 RS-T Hybrid
If you have a true garrett core and no problems with the heads flowing you should be able to pick up atleast another 50 hp.
speed_freak27 is offline   Reply With Quote
My rs project rs420 Vancouver Impreza Club Forum -- VIC 31 06-07-2010 12:12 AM
Project Mongrel 370WHP OB2 Proven Power Bragging 5 07-15-2009 10:16 PM
Project CASPER.....Complete!.....Project Garfield started jimtweet Member's Car Gallery 67 06-29-2006 01:53 AM
Updated project pics on the 2.4 Ej22 project M3GTR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-22-2005 05:27 PM
Project 2.5 Turbo L Wagon project Complete! yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-29-2003 04:27 PM
