#1 |
Member#: 176422
NWIC
#2 |
Member#: 53558
NWIC
Vehicle:2002 WRX Wagon Silver |
Honestly, I'd suggest tossing the cams you have and finding something a little more mild. Stock cams probably aren't what you want, but what you have is certainly overkill for the output. Keep the built bottom end for sure, unless that drives you crazy too.
Why just swap the cams? Maybe the PO proted your heads, upgraded valvetrain, etc. Be a shame to just toss or sell that if you've already got it. |
#3 | |
Member#: 176422
NWIC
#4 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
Try another tuner?
#5 |
Member#: 176422
NWIC
#6 |
Member#: 71374
SCIC
Vehicle:2005 impreza wrx aspen white |
im pretty sure if you run a smaller cams itll be smoother.
im running an almost similar setup with 276's and you can hear and feel a slight lope but its not noisy or annoying. |
#7 | |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
Add some fuel, 13.5:1 and I would bet that the engine would be happier. That's a nice looking built motor, save the other long block till you realy need it. |
#8 | |
Member#: 176422
NWIC
#9 |
Citizen Mick
Member#: 27646
NWIC
Of course you could have a plain and simple mechnical issue and nothing to do with tuning. Just thought I would mention that
#10 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
#11 |
Citizen Mick
Member#: 27646
NWIC
Ahah.... When you are ready to be tuned let me know and I'll try and be at Surgeline at the same time. I know Tim and the crew very well.
#12 | |
Member#: 176422
NWIC
yep thats my car.. |
#13 |
Member#: 53558
NWIC
A friend got his EVO X tuned at Surgeline and it was an awesome experience, wished I could have been there.
#14 |
Member#: 107569
NWIC
Vehicle:1998 Forester S SRP |
Try 264 cams and a re-tune. My motor with 272 cams started up and idled well in 12 degree weather. Coldest it gets here in portland. This was on a AEM standalone. So you should be able to get the same results with a good tune.
#15 |
Member#: 176422
NWIC
how are there so many people from portland on here?
#16 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
Not from Portland, but I found this comment funny
![]() I would try switching to a less race-oriented set of cams, such as the 264's. u should be able to make similar power to what u make at the moment, with a wider powerband. u can try going richer with the cams u have, and that will smooth them out a bit, but u will notice that ur fuel economy suffers, especially in the city, and u go through spark plugs a bit faster than usual due to the rich fuel mixture fowling them up. Last edited by jigga; 04-01-2009 at 08:11 AM. Reason: Now why is it that everytime i type "y o u", it shows up as "u"? |
#17 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
Is there 93 octane in Oregon? Florida has 93 octane and if Oregon doesn't have 93 octane then your tune is way out of whack....
#18 |
Member#: 176422
NWIC
#19 |
Member#: 85813
South East
That 'could' be your problem. You best bet in your area is to contact Surgeline Tuning. Or call Topspeed and they can remote tune your car on any dyno if the dyno owner will help them set it up
#20 |
Member#: 176422
NWIC
#21 |
Member#: 159454
SWIC
Vehicle:2006 WRX CGM 6SPD Cornfed GT30R |
#22 |
Member#: 176422
NWIC
#23 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
I wouldn't expect 280 cams to idle like a stock DD. You sacrifice a little to get that top end so swapping them out for the stockers won't net you the same power without a bigger turbo.
#24 |
Member#: 126112
TXIC
Vehicle:93.5 Toyota Supra Red |
I would keep it the way it is now and get a retune to see how that goes. You've got a built motor with the works so why not use it? I would save the sti long block for down the road...
#25 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
+1 for what mick said the car probably needs retuned just like he said big cams like to idle around 1000 rpm and af's around 13.5-13.8.
| Thread Tools | |
| Display Modes | |
| Tune problems- 280 cams, 63lb turbo, built block | godforbid67 | Open Source Reflashes | 74 | 02-11-2010 05:22 PM |
| Built 2.0 heads (Ti valves, springs, retainers) 280 cams | selvar05WRX | Engine/Power/Exhaust | 3 | 06-30-2009 11:37 PM |
| If you have a Maxwell Power built engine chime in | CoolRex | Built Motor Discussion | 23 | 06-21-2009 04:46 PM |
| built motor thinking of getting BC 280 cams | moorebl | Built Motor Discussion | 1 | 03-29-2009 01:14 PM |
| Have a 4 Puck; now I want something less aggressive | Tattoo Collector | Transmission (AT/MT) & Driveline | 5 | 09-28-2005 09:39 PM |
