Old 04-15-2002, 12:37 AM   #1
Mugen13
Member#: 11169
Default Why do Vishnu and TurboXS have different stock WRX dyno #'s?
Vishnu says that the WRX makes 183.5hp and 186ft-lbs TQ and Turbo XS says their WRX made 168.0 hp@ 5733 rpm and173.0 ft-lbs @ 3518 rpm.
that is a huge difference. So what are other i-club members putting down stock?
Vishunu stage 0 vs. stock http://i-club.com/imprezer/stage_0_vs_stock.jpg
Turbo XS stage 1 vs. stock http://www.turboxs.com/turboxs_2002_...ge_1_hp_vs.htm
Mugen13 is offline   Reply With Quote
Old 04-15-2002, 01:36 AM   #2
Subi-fied
Member#: 13483
Because Vishnu is too cheap to buy an AWD dyno.
Subi-fied is offline   Reply With Quote
Old 04-15-2002, 01:38 AM   #3
Subi-fied
Member#: 13483
....Vishnu disconnects the rear drivetrain and turns the car into a FWD for testing purposes. This causes higher numbers since the loss isn't as great.....
Old 04-15-2002, 03:48 AM   #4
eric m.
Member#: 14872
06 legacy GT black
accessport stage II.
it's just a reference point to see how much improvement the "stage" kits provide over stock. just look at the before and after numbers for each vendor respectively, instead of comparing one to another, or else results will not be accurate. the best thing would be for all the vendors to get together at the same dyno and do a test to see what the numbers are. that's the only way they will be somewhat accuarate, and still dyno results can vary as much as 5HP or more.
eric m. is offline   Reply With Quote
Old 04-15-2002, 07:16 AM   #5
Chris02WRX
Member#: 3716
Vishnu uses a Dynojet. TurboXS uses a Dynapack.
Chris02WRX is offline   Reply With Quote
Old 04-15-2002, 09:48 AM   #6
z&cobb
Member#: 12344
2002 2JC
blue
At least no one is using a one-wheel dynamometer, but I suppose that would get closer to the "crank" HP.
z&cobb is offline   Reply With Quote
Old 04-15-2002, 09:51 AM   #7
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
Thumbs down
vishnu uses 2wd dyno
misleading
elgorey is offline   Reply With Quote
Old 04-15-2002, 09:54 AM   #8
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Not only that but TXS's had LOW numbers. Not just peak, but the curve is not at all like the others. I think they might have used a weak WRX (not to mention they use a diff dyno). at Cobb stock WRX's were at ~178 with 1000 miles and some at 193whp with a GOOD amount of miles (30K+).
-C
TypeC is offline   Reply With Quote
Old 04-15-2002, 09:55 AM   #9
SW00P_G
Member#: 5591
EJ257 Gt35r
So you can't tune on a 2 wheel dyno??
SW00P_G is offline   Reply With Quote
Old 04-15-2002, 10:41 AM   #10
Subi-fied
Member#: 13483
Sure you can. Tuning has nothing to do with the way the dyno is setup. As long as there is an accurate before and after result then tuning can be done.
I just wish Vishnu would invest in an AWD dyno.
Old 04-15-2002, 10:52 AM   #11
Big Bear uk
Member#: 15344
2004 STi type uk
Talking
would you not break/overheat the centre diff by running the car in 2WD ????
Big Bear uk is offline   Reply With Quote
Old 04-15-2002, 10:53 AM   #12
titsataki
Member#: 4402
2009 Outback XT
Vishnu has access to a dyno (2WD). Then they occasionally have access to an AWD dyno (DynoJet I believe). They have run their stage 0 at both and have published results.
Every time I have gone that route people came back to say that the numbers are not reliable and that dynos are more of a tuning tool than a standard way of measuring hp. Even same dynos can produce diff results and also same car can even produce different results. Shiv has mentioned that as much as a ECU reset can change the results. This is part of tuning on a piggy back ECU.
An AWD dyno is I heard around $100k. Not realy pocket change. Plus maintainance and service etc... Also the shop to base the dyno is needed. I can't imagine running this babay all day for several days off someones house/garage. People/neighbors will be very unhappy
Cheers
Nick
titsataki is offline   Reply With Quote
Why do 06 and up wrxs have a redline at 6.5k? wrxgeneration Newbies & FAQs 51 12-12-2008 12:45 PM
'04 WRX dyno #'s w/ stock turbo CWReX86 Proven Power Bragging 11 05-10-2007 03:51 PM
STOCK sti dyno #'s ***! wrxtremeWGN Proven Power Bragging 40 11-11-2004 12:16 PM
why do 02 and 03 wrx's have different rear O2 sensor part numbers? Homemade WRX Factory 2.0L Turbo Powertrain 2 09-13-2004 08:53 PM
Quick..whats the difference btw Vishnu and Turboxs unichips. enewtabie South East Region Forum 4 12-03-2002 06:43 PM
Message Board Statistics All times are GMT -4. The time now is 08:41 PM.
