Old 04-15-2002, 12:40 AM   #1
AFireInside
Guest
Member#:
Default driver's side window diagram
I was wondering if anyone has a diagram for the driver's side window in a MY00 RS sedan. Or if anyone has the shop manual if you will please scan it and send it to me. My regulator unbolted itself again today and i am going to try to fix it .
Thank You!
Old 04-15-2002, 12:58 AM   #2
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
That would be a great help for me too
Thanks to whomever may provide the info
moogooob is offline   Reply With Quote
Old 04-15-2002, 03:00 AM   #3
Avenger
Member#: 1234
Default Re: driver's side window diagram
Thank You!
Are you looking for a wiring diagram?
Avenger is offline   Reply With Quote
Old 04-15-2002, 03:04 AM   #4
AFireInside
Guest
Member#:
anything you got, mostly a mechanical dia gram
Old 04-15-2002, 01:15 PM   #5
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
I have a diagram but the program it is in will not let me copy it. I can print and slow mail it. I don't have a scanner either, so that's out of the question. What did you need anyway?
www.bannerglass.com
Stealthbmbr is offline   Reply With Quote
Old 04-15-2002, 01:26 PM   #6
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
I guess I should read the whole thread before I post. I always put lock tite or w/s sealer (urethane) on the threads so they don't back out again. Should be 4 bolts on the head of the regulator(by the motor) and 2 on the third (adjustment) arm. The third arm adjustes the front to back pivot. (Front down, back up or front up, back down). I have to get a scanner.
Old 04-15-2002, 11:13 PM   #7
AFireInside
Guest
Member#:
anyone anyone............. Bueller?
Old 04-16-2002, 04:29 AM   #8
outback2.5HO
Member#: 15135
95 GF WRX
If you get things tight the first time, they shouldn't come apart.
Why are you messing with your regulator anyway?
outback2.5HO is offline   Reply With Quote
Old 04-16-2002, 05:20 AM   #9
AFireInside
Guest
Member#:
it fell ou on its own. Like the WHOLE window and i have fixed it once already.
thank you abyways newbie,,,,,,,,,,(not to be a d**k)
Old 04-16-2002, 07:49 AM   #10
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Got a fax machine. I can fax it to you.
driver's side window for Impreza coupe FujiHeavyFreak Private 'Wanted' Classifieds 5 03-05-2004 10:27 PM
Please advise, driver's side window overdose Service & Maintenance 6 12-07-2003 08:31 PM
So they broke my driver's side window.........(no pics yet) Mauricio Texas Impreza Club Forum -- TXIC 8 04-24-2002 12:57 AM
Driver's side window doesn't work WRXVII Service & Maintenance 3 04-07-2002 02:43 PM
Driver's side window clunking Big Tee Technical Forum Archive 6 09-17-2000 12:15 AM
