#1 |
Member#: 188405
did timing belt, put new water, and oil pump, thermostat, and new belt tensioner.. The timing is perfect and all correctly aligned. It has gas and spark as well. Im hoping it's just flooded so i'm letting it sit for an hour to let the gas evaporate.
It backfired a couple times while trying to start it. Fuses are all fine and I know there is gas. I also physically checked for spark and I have that too. please help im about to try to keep starting it here soon and could use some input
#2 |
Member#: 188405
bump help!
#3 |
Member#: 141672
Vehicle:07' wrx Uncle Scotty 5W30 |
Backfiring = you probably screwed up the installation.
Flooded? It can only happen on a fuel injected vehicle with a faulty sensor(s) or whacked computer, leaking injector for the most part. Try flooring the car while you crank it over. The computer will fire the ignition and shut off the injectors while you do this on many vehicles. Last edited by mikeythejew; 04-02-2009 at 05:03 PM. Reason: why ask why? |
#4 |
Member#: 188405
ok well i replaced both cam and crank postion censor and i though i did **** up the install but a mechanic came over and redid it and lined up every thing and put the timing belt on and when i do start it i gas it and still doesnt start!
ive even unpluged the fuel pump relay b/c when i was trying to starting it aafter it reeked of gas! Im stumped! |
#5 |
Member#: 22399
Vehicle:2002 wrx 200k mile high club |
Did you turn the motor by hand? If not turn it for several revolutions to make sure you have no type of interference. If it binds up something is wrong just don't force it.
#6 |
Member#: 114609
Is it throwing any codes? Check that first, otherwise it's like finding a needle in a haystack.
#7 |
Member#: 188405
thanks guys well i figured it out i guess the timing belt was off by one tooth! in the process i got my finger smashed between the gears but it was all worth it! lol
| Thread Tools | |
| Display Modes | |
| 04 wrx wont start after accident | Skiracer8148 | Factory 2.0L Turbo Powertrain | 27 | 03-21-2009 03:05 PM |
| Help 03 WRX wont start after new battery! | newgensti | Factory 2.0L Turbo Powertrain | 18 | 01-20-2009 01:58 AM |
| car wont start now.. txic please help :( | ohxietviet | Texas Impreza Club Forum -- TXIC | 27 | 08-19-2007 04:06 AM |
| 02 WRX wont start ( Video Inside ) | 04.STI | Factory 2.0L Turbo Powertrain | 25 | 06-07-2007 07:21 AM |
| 02 wrx wont start!!!!!! | jnizzle | Factory 2.0L Turbo Powertrain | 0 | 04-09-2007 10:53 AM |
