Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-31-2009, 10:44 PM   #1
weston666
Member#: 198759
Default Baja "shaking" at an idle
My 03 Baja seems to be idling quite rough when i'm sitting at a stop light in Drive gear. It will not however shake when it is in neutral or park gear. It only does this after the engine has warmed up and the choke has gone away. Has anyone had these similar problems?
Thanks for all the input people.
Weston
----It does not shake while im driving it either, only when im idling in Drive
weston666 is offline   Reply With Quote
Old 04-01-2009, 12:03 AM   #2
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Could be plugs. Ive seen bad plugs give some strange symptoms
Buck Rogers is offline   Reply With Quote
Old 04-01-2009, 10:45 AM   #3
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I'd say pull out your MAF sensor and see if it's dirty. That's one thing that might cause it and would be simple to clean. It'll be somewhere in your intake plenum past the air filter - not sure exactly where it's located on N/As.
moonzie is offline   Reply With Quote
Old 04-01-2009, 04:27 PM   #4
weston666
Member#: 198759
I'm putting new spark plugs in and gonna clean the MAF sensor tonight, ill let you know how it goes
Old 04-01-2009, 08:54 PM   #5
weston666
Member#: 198759
NO luck with the plugs and cleaning the maf. Maybe my engine mounts are toast? The car has 120k miles
Old 04-01-2009, 09:28 PM   #6
WYSubaru
Member#: 154884
2005 Baja turbo
Our turbo was doing the same thing and I replaced the plugs first but it ended up being a bad injector.
WYSubaru is offline   Reply With Quote
Old 04-10-2009, 04:48 PM   #7
Alpha Wolf
Member#: 140505
2005 Baja Turbo
Pearl Blue
Cool
This normally due to the car dropping a cylinder and at idle it is more noticeable.
It is either spark or fuel.
Check plugs
Check plug wires
Check injectors
Alpha Wolf is offline   Reply With Quote
Baja Competitors at NAIAS fdg008 Baja Forum 8 01-14-2005 11:27 AM
Somewhat of an idling problem when I get out of gear SloWrX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-18-2004 12:46 AM
Saw the first BAJA Sport at a local dealer.... Kostamojen Baja Forum 13 06-26-2003 09:42 AM
Where is/ or is there an idle adjustment screw for 02' Wrx? PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-14-2003 06:19 PM
'03 Legacy GT, Forester, Baja, etc. at the NY auto show rsholland News & Rumors 9 04-09-2002 04:06 PM
