Old 03-31-2009, 11:43 PM   #1
discopotato03
Member#: 67934
1986 L Ser RX Turbo
Default Any Pics of VF10 compressor wheel ?
Hi all , I need some pics of a VF10s comp wheel as in comp housing removed .
What they have is a 56mm major dia wheel but in ~ 50T so smaller on the inducer than VF8s or VF12s 56mm compressors .
Also a pic of down the exhaust inlet hole would be good too - need to compare to tiny VF4/6/7 from EA82T .
Cheers A .
discopotato03 is offline   Reply With Quote
Old 04-01-2009, 12:18 AM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I won't need to show you a pic you because they are actually bigger than the 7.
i_c_the_light is offline   Reply With Quote
Old 04-01-2009, 02:40 AM   #3
discopotato03
Member#: 67934
1986 L Ser RX Turbo
Yes I realise that .
Old 04-01-2009, 09:55 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
this won't help
but there are 2 versions of th vf-10 (auto and manual)
IIRC the manual had 10 blades on the turbine and the auto has 9
this could be backwards though ///
Old 04-01-2009, 11:30 PM   #5
smh0101
Member#: 138160
'94 Legacy Turbo
White ej20h w/vf28
Not so. The vf-8 was found on the Liberty/Legacy RS and the RSs only came with either a vf8 OR vf12. The L RS had about 220hp ish.
The Legacy/Liberty GT of the same year was the Automatic version. This came with the vf10. It only had 200hp.
The vf10 a turbo with a vf8 cold side. and a vf11 hot side with a slightly larger hot side wheel.
And I'm running a vf10 right now. Not a terrible little turbo. Pushing out 16lbs and it spools right the **** up! lol Full Boost by 2k on a ej22t.
And the vf10 is definitely WAYY bigger than the ea82t because the vf11 (which is the worlds ****ty and tiniest turbo) is bigger that the ea82 turbos.
Hope this helps.
Oh, and some pics.
smh0101 is offline   Reply With Quote
Old 04-04-2009, 08:25 AM   #6
discopotato03
Member#: 67934
1986 L Ser RX Turbo
Thanks for those pics .
What I was asking after was compressor wheel pics of the FV10 with the comp cover removed .
I know for a fact that VF8 VF10 and VF12s all have 56mm major diameter compressor wheels but the VF10's is a significantly smaller trim than the 8 or 12 which is why from the outside (housing on) that the compressor doesn't look significantly larger than an EA82's compressor or probably the VF11's one .
I have pics here of my friends VF8 and VF10 and you can see distinct differences in the castings of the 15R and 20R , its not just an A/R ratio change .
Also from pics you can see another distinct difference in the compressor housings of Subie RHB5's , ones with 52mm dia compressors ie EA82T's and VF11's have a more distinct flange where they bolt to the cartridge . The ones on the turbos with 56mm dia comps ie VF8/10/12 just seem to curve around on the outside of the housings casting .
So I think we can safely say you can identify these turbos by looking at the housings , big series 10 blade turbines go with the 20R housing and small series 9 blade ones go in the 12-15R turbine housings .
If the unit has the larger "wrap around" compressor housing it has the larger major diameter compressor , if not the smaller major diameter wheel .
Another thing I'd really like to see is a pic of a VF11 compressor wheel with its housing removed because I'd like to know approximately how much larger its trim/inducer is compared to the EA82T's wheel .
IHI compressor designations .
VF2/3/4/5/6 - 3911EZ
VF8 .......... - 4625CFZ
VF10 ........ - 4225 CFZ
VF11 ........ - 4016EZ
VF12 ........ - 4726CFZ
I'd like to know what these numbers mean and all you can tell is that they go up in size with an increase in airflow pumping capacity .
From lowest to highest flow the models would read :
VF2-6
VF11
VF10
VF8
VF12
Not surprisingly those first three use the smaller 9 bladed turbine in firstly 12R (some rare Euro Spider XT4 EA82Ts were 15R) and in the second and third cases EJ flanged 15R housings .
The last two both use the larger 10 blade turbine in the larger series 20R EJ flanged turbine housing .
Cheers , Adrian .
PS . I should have a complete VF10 and VF8 here next week and I am getting messages to say that VF10s are being rebuilt here .
If I can do something about extra fueling I may be able to have a hybrid made up of a VF8 cartridge with the VF10's compressor wheel and housing on its front . Basically a VF8 with an ~ 50 rather than ~ 60T compressor end on it .
Any pics of 18" black wheels on a gc? 2slofouru Tire & Wheel 2 09-03-2006 02:42 AM
Any pics of STi BBS wheels on 02-03 WRX? Butt Dyno Member's Car Gallery 19 06-05-2004 07:01 PM
Any pics of a 2002 2.5 RS with stock 2001 wheels? driver Brakes, Steering & Suspension 0 05-27-2001 01:51 AM
Any pics of powdercoated wheels? Rickd General Forum Archive 4 10-08-2000 12:50 AM
