Old 04-01-2009, 02:38 AM   #1
don_radeon
Member#: 202583
2004 Legacy GT
Black w/Domo on back
Default Pistons and Rods
I'm looking for a good piston and rod setup. I'm assuming eagle and CP or JE. Just looking for some experienced words on this, I'm new to replacing engine components within the block.
Also, would 92.5 pistons work in the stock block or do you have to get it machined to fit?
One more thing, Crower makes stage 2 cams with a ~270 duration. Are these, or any other cams, worth doing which the block is apart?
don_radeon is offline   Reply With Quote
Old 04-01-2009, 12:26 PM   #2
ScorpionT
Member#: 195677
92.5 would need a slight overbore. GSC also makes very nice cams, but they cost a bit more.
ScorpionT is offline   Reply With Quote
Old 04-01-2009, 05:09 PM   #3
don_radeon
Member#: 202583
2004 Legacy GT
So 92 would be perfect I'm assuming. What kind of benefits would I be looking at with cams?
Old 04-01-2009, 05:46 PM   #4
methaddict
Member#: 159738
2004 WRB STi
OFCD V3, FR TS, BW8374EFR
If you want economy rods I'd check out the Manley's.
methaddict is offline   Reply With Quote
Old 04-01-2009, 05:46 PM   #5
don_radeon
Member#: 202583
2004 Legacy GT
I'm not looking for economy rods, if I'm pulling the block I might as well put the best in there.
Old 04-01-2009, 06:34 PM   #6
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
and the eagles are on your list???
gto7419 is offline   Reply With Quote
Old 04-01-2009, 06:37 PM   #7
InfiniteMotorsports
Member#: 85354
Crower makes some pretty beefy and expensive rods.
If your attitude is to sort of "take care of it while it's apart", then you would be looking for 92.5mm pistons and a machine shop to bore your block. That is of course unless your block is brand new.
Also consider what compression ratio you're looking for.
-Jake
InfiniteMotorsports is offline   Reply With Quote
Old 04-01-2009, 06:39 PM   #8
don_radeon
Member#: 202583
2004 Legacy GT
Well it's a good thing I'm asking what i should get then, huh?
Old 04-01-2009, 06:40 PM   #9
don_radeon
Member#: 202583
2004 Legacy GT
-Jake
My block isn't brand new, 28k miles on it, so I'll probably get it machined then. So Crower would be a good choice? I'm trying to find out the best brand for the money, something people have actually used and have experience with.
Building my sti block, and suggestions for pistons and rods? wrxwagon253 North West Impreza Club Forum -- NWIC 5 11-25-2007 03:08 AM
Are we getting the forged pistons and rods too? Speedy02wrx STi Forum Archive 3 01-06-2003 10:48 PM
To the guys who bought pistons and rods DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 8 10-07-2002 11:50 PM
about to take the plunge and buy pistons and rods. suggestions wanted. DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 24 07-13-2002 02:38 AM
Forged pistons and rods, make me a list WRXwannbe Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-09-2001 04:01 AM
