Old 04-01-2009, 08:07 AM   #1
stitchbad
Member#: 177527
2004 STI
Default How to lap valves?
So I got my heads back from the machine shop and they still have very small leaks, I asked if they lapped the valves and was told that they don't do it anymore because it takes to long and the valves will stop leaking when you run the motor. So I need to know how to lap them myself, I got all the tools and lapping compound from NAPA but just need to know if you have to take out the valve seals or oil the stem or what other tricks there are. Any help would be great.
Thanks
stitchbad is offline   Reply With Quote
Old 04-01-2009, 09:47 AM   #2
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
I've seen a video on youtube on how to do it, it seems simple to do.
kevinh211 is offline   Reply With Quote
Old 04-01-2009, 03:46 PM   #3
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Definitely take out the oil seals, and DO NOT use too much compound.
It does not take much nor does it take a lot of work to get them right if the seats and faces were ground properly.
You really want to avoid getting too much compound down in the bowls so that your clean up is easier.
Basically the valve and seat angles will have a shine to them before you start.
You smear a little compound on the valve face all the way around.
Place the valve in the hole, stick your suction cup tool on the top of the valve and starting from the top of your tool you spin back and forth with both hands. As your hands reach the bottom of the tool from the back and forth motion you stop and start at the top again.
Do this 2 or 3 times, then take the valve out, inspect the face of each angle on both the valve and the seat and when you have "matted" the finish evenly you are done with that valve and seat.
If when you take it out and look at the valve/seat they are still shiny or have grind lines in them rinse and repeat until the surface is a matte finish on each angle/face.
The first few rotations of the tool you will feel a gritty grinding sensation which gets less as you continue to rotate.
This is the grit in the compound grinding itself smooth.
You don't feel nearly as much of this when using the fine compound in the 2nd step.
Pretty easy process. take your time, and do not use too much downward pressure while spinning the valve, let the weight of the valve plus the tool be the downward force applied and do this consistently for each valve so you are repeating the process exactly ,.
It is pretty hard to screw up this process.
You will do this in 2 steps.
One is a coarse grit lap (120 grit compound)
Two is the fine grit lap (280 grit compound)
Clean the heads and valves really well when you are done.
Team Scream is offline   Reply With Quote
Old 04-01-2009, 04:46 PM   #4
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
For the compound I use permatex lapping compound first. Loctite makes an abrasive compound called "clover". I use that last. It does take a while. Afterwards,I hot tank the heads.
PSolbergfan is offline   Reply With Quote
Old 04-01-2009, 10:00 PM   #5
gumby647
Member#: 2532
2001 2.5RS-T
BRP
Be aware that some valves are coated to increase their durability. If you lap such a valve you'll cut the coating and the valve will wear out sooner. Most new valves are very good and don't need lapped. Normally I use one of the old valves and lap all the seats using 800 grit clover compound. I'll only use a coarser grade of compound if necessary to get a good seat.
gumby647 is offline   Reply With Quote
Old 04-02-2009, 03:55 AM   #6
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
I watched those videos on youtube and they really helped me understand the process of what is involved. Hey I actually feel like I could do it now, it isn't that hard! All I need is a couple simple tools.
This video explains almost completely how to do it, but of course they went quick and you would take more care on your own motor:
http://www.youtube.com/watch?v=6-cJq...eature=related
GodSquadMandrake is offline   Reply With Quote
Old 04-02-2009, 08:13 AM   #7
stitchbad
Member#: 177527
2004 STI
Thanks for the help I'm sure that I can do this and not mess anything up. Are the STI valve coated?
Old 09-03-2015, 11:20 PM   #8
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
bump from the dead!
Will valve lapping decrease my lash clearance? In other words, would I have to re-shim?
simer1228 is offline   Reply With Quote
Old 09-04-2015, 05:42 AM   #9
unoracing
Member#: 359289
2002 WRX STI Prodriv
blue
Hello,
I did mine a couple of Month ago and yes you have to re-shim...
unoracing is offline   Reply With Quote
How to Determine Valve Stem Size? UI Vandal Tire & Wheel 18 01-10-2016 11:14 AM
Degreeing a camshaft - how to measure valve position. 2milehi Built Motor Discussion 7 08-13-2011 09:22 PM
how to adjust valves AndrewF844 Normally Aspirated Powertrain 1 11-29-2006 06:59 AM
02 WRX...how to check valve clearance? Judge Service & Maintenance 3 07-18-2006 03:59 PM
Trackwhores, AM I going to die? And how many laps will it take? Davenow Motorsports 32 03-29-2004 12:03 AM
