Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-01-2009, 01:42 PM   #1
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Default WTF Boost searching 07 WRX? HELP!!!!!!
Ok so I have no clue whats going on.
First Ill list my mods as I know you will ask for them so here is all the info you should need.
2007 WRX.
STI IC.
STI BPV.
Samco IC hoses.
Titek Catted DP.
SPT cat back.
SPT intake.
SPT intake heat shield.
Cobb AP V2.
Cobb OTS stage 2 Tune 93 LC. (Its up to date as well.)
My Problem:
Car will over boost (target is 16psi) to as much as 19psi at times then under boost as low as 12psi then finally settle around 16psi then fall off like it should.
It dose this in any gear. 4th and 5th it will search 2 times before it settles.
Now I have not changed any thing on the car in almost 19 months and the problem just started 2 months ago.
Car has 14K on the clock and has thrown an over boost code 2 times in the last 2 months.
Any Ideas?
Badmunky is offline   Reply With Quote
Old 04-01-2009, 01:46 PM   #2
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Mods please Delete!
Wrong forum.
Boost searching 07 WRX! HELP!!!!! Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 04-02-2009 07:07 AM
boost control 07 wrx?? subiesoho Newbies & FAQs 4 02-20-2009 11:00 PM
Add more boost to 07 WRX Veloxity Newbies & FAQs 3 06-09-2008 01:28 PM
Wtf Is Wrong 07 Wrx xreign Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-10-2007 06:19 AM
Starting preliminary search for WRX...help with pricing! john_matrix Newbies & FAQs 26 05-29-2005 05:45 AM
