Old 04-01-2009, 01:28 PM   #1
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Default Dangerousatom's new turbo crap box "91 Leg SS"
- 91 Legacy 2.2L Turbo 165k
- AWD Auto......swapping in a 06RS Manual due to teh Autos clutch packs are blown
The car is getting teh full motor rebuild clean up and once over minus piston rings. It is unbelievably filthy ( the motor looks like its covered in greasy brownie batter ) It is leaking from just about every seal that is oil related . I have already gone through a gallon of Simple Green and Purple Power
dangerousatom is online now   Reply With Quote
Old 04-01-2009, 01:29 PM   #2
dangerousatom
Member#: 70710
Old 04-01-2009, 01:30 PM   #3
dangerousatom
Member#: 70710
Old 04-01-2009, 01:33 PM   #4
dangerousatom
Member#: 70710
Auto Trany is out ( what a boat anchor!! ) and the bay is still quite filthy
After about a gallon of paint thinner and then a gallon of simple green it was finally clean!!
Cut the bumper beam out and mounted up the home brewed FMIC.....I'll finish the pipe routing after the motors is back in
Old 04-01-2009, 01:34 PM   #5
dangerousatom
Member#: 70710
2004 Impreza SOHC Heads......unbelievable valve size difference from the 91 Leg Turbo heads
All new H2O and oil pumps - Timing Belt Kit - WRX H2O cross over pipe - home made upper and lower UHMW 1/8" intake manifold gaskets
When swapping over from the 91 turbo heads to the newer 04 SOHC heads the issue of intake manifold bolt patterns became obvious. The old bolt pattern is smaller and tighter than the new TGV type manifolds. Therefor a WRX - STi - Leg GT TGV type manifold was needed. In addition to finding that out there were some throttle body issues as well. I had hoped to continue the use of the 91 Legacy SS throttle. It does bolt on, but the linkages hit the intake runners and the cables need to be pulled form a directions that can not be hard mounted......so a WRX throttle body was need. None of the sensors are wiring plug compatible, but they are not necessarily needed for OBD1 either, in exception of the throttle position sensor. The old sensor is for the most part "same same" in mounting and mechanical turning connections as the WRX....minor mounting location modifications where needed.
WRX Alternator & Power Steering Pump......stock AC Compressor will not fit with new intake manifold....will have to get WRX compressor
WRX Header & UP .......the UP needed modification ( 1-1/2"-2" addition to the length and minor angle articulation for proper turbo mounting ) due to the SOHC Heads
Transmission - Clutch Master & Pedal Set are in
WRX Cat Back - Shorty DP and custom extra long flex connection ( where the CAT would be ).....oops!! need to get the rite pic in here
I had some minor hick-ups with the drive line conversion Luckily I had a 04 RS rear to swap out the connections The 91 Leg rear is not a square bolt up, and due to the shorter length of the manual trans I needed to get a drive shaft extension.....this could have been quite a nightmare!!
Installed!!
Old 04-01-2009, 01:44 PM   #6
02fastWRBLUE
Member#: 52590
siqqqqqqqqqqqqqqq
02fastWRBLUE is offline   Reply With Quote
Old 04-01-2009, 01:46 PM   #7
scrape
Member#: 163720
2001 Legacy Outback
sweet project, im definitely a fan of the older legacy.
scrape is offline   Reply With Quote
Old 04-01-2009, 03:23 PM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Dude, this is SWEET...
Your pics also allowed me to better understand where my coolant leak is and what I need to do to fix it.. (first pic, post #5) The little extension off the coolant crossover pipe, I would guess there is just an O-ring in there.. THANKS..!!
Oh, you plannin on painting the FMIC? totaly stealth mode.. lol..
Old 04-01-2009, 04:12 PM   #9
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
nice project. annnnnnnd Subscribed!
blakkboxer is online now   Reply With Quote
Old 04-01-2009, 04:25 PM   #10
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
Wow nice project man !
vik_wrx is offline   Reply With Quote
Old 04-01-2009, 04:27 PM   #11
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
One word. Awesome.
JC is offline   Reply With Quote
Old 04-01-2009, 04:52 PM   #12
dangerousatom
Member#: 70710
Thanks guys....
Hope to be on the road in a week or two, as long as I dont have too rich a fuel mix. The old side feeds are 300cc the WRX top feeds are 380cc. I dont feel that it will be too much of an issue. Its nice to find out the old side feed wiring plugs are the same pattern minus the guide barbs ( slicing them off the top feeds ) to accommodate the old harness. Hopefully I wont have to swap +/- wires around even though its a 180 flip from side feed plug to top feed plug.......I'll have a few pic's to better explain the scenario
Old 04-01-2009, 04:54 PM   #13
White out
Member#: 46277
** LP640
Viper GTS
Great build!
What turbo are you running, VF11, or bigger?
Nick
White out is offline   Reply With Quote
Old 04-01-2009, 05:10 PM   #14
dangerousatom
Member#: 70710
Stock WRX TD04 The stock VF11 is in good shape with 168k but I had a TD04 with under 25k so it was a no brain-er.....more efficient and more boost 12-15lbs Its going to be a daily beater. . . . . I have a good car for big boost:
http://forums.nasioc.com/forums/show...t=swap&page=12
Old 04-01-2009, 05:27 PM   #15
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
nice project...!
shadowmd is offline   Reply With Quote
Old 04-01-2009, 06:25 PM   #16
sparspecker
Member#: 130554
2004 Forester XT
It's odd to see the charged air go straight from the turbo to the intake manifold.
sparspecker is offline   Reply With Quote
Old 04-01-2009, 06:31 PM   #17
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
looks great that'll be a nice sleeper!
pearljam11 is offline   Reply With Quote
Old 04-01-2009, 06:39 PM   #18
turntable
Member#: 103622
awesome build!
can't wait to see more pics as time goes on
turntable is offline   Reply With Quote
Old 04-01-2009, 09:02 PM   #19
rice h8r
Member#: 94524
Wait so what are you using for rear diff and driveshaft? GL finishing up the project.
rice h8r is offline   Reply With Quote
Old 04-01-2009, 09:07 PM   #20
grippy monkey
Member#: 131067
your "stance"
sucks
coming along really nice man!
grippy monkey is offline   Reply With Quote
Old 04-01-2009, 09:20 PM   #21
fzel07wrx
Member#: 150710
2012 SWP WRX Hatch
2005 Lotus Elise
props to you for pulling through that leaky engine, the results are looking great!
fzel07wrx is offline   Reply With Quote
Old 04-01-2009, 09:57 PM   #22
naggg
Member#: 146395
2009 Subaru STi
Satin White Pearl
wow that looks like a whole bunch of work. all fun tho i bet!
naggg is offline   Reply With Quote
Old 04-01-2009, 10:56 PM   #23
Flat4TW
Member#: 200456
0295 WRX
nice restoration
Flat4TW is offline   Reply With Quote
Old 04-01-2009, 11:03 PM   #24
ReubenH
Member#: 172522
1998 Legacy GTB Ltd.
Great work. Pitty you didn't stick some more "exciting" heads on there though
ReubenH is offline   Reply With Quote
Old 04-01-2009, 11:43 PM   #25
dangerousatom
Member#: 70710
Originally Posted by rice h8r View Post
Wait so what are you using for rear diff and drive shaft? GL finishing up the project.
97-98ish Forester drive shaft from the look of what I pulled it out of at the junk yard
Rear Diff is the stock 91 Leg SS.......the 90-93 Legacy SS auto's and oddly enough manuals too where 390:1 final drives and the 06RS manual trans is a 390:1 as well. I have already made sure the final drive ratios are same same on top of spinning the drive line numerous time after getting things all connected.
I should mention as well:
The installation of the 06RS trans into the 91 auto was not as difficult as I was assuming it would be. The newer Subaru transmissions ( 05-ish I believe was the switch year ) went to axles that inserted into the trans but the older transmissions where with front studs/splines for axle connection. All that was needed to be done was to pull the front studs from the old 91 auto trans and insert them into the new 06 with the "C" clips in place...... like popping in 05 and up front axles. Older style transmission seals where needed to take up the gap around the front studs ( the seals exterior diameter has remained the same, its the inner hole or axle/stud size that changed to about 1/8" larger)
The 91 leg transmission is a cable driven speedo and the 06RS is an electronic but they both work in the same fashion. ( cable driven = speedo turns a flat key that connect to and spins the cable . . . electronic driven= speedo turns a magnet that in-turn is picked up by the electronic sensor ) So all that is needed is the guts/sensor from one to go into the other.....thread patterns are same same.
new turbo time for my OBS. SwappedOBS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-05-2010 05:50 AM
Innotvative TURBO BRAND NEW in the Box Custom Built 60 TRIM.. MASSIVE TURBO.. iwanasubi Engine/Power/Exhaust 9 06-05-2007 05:14 PM
FS: 1992 Leg SS Turbo 5spd & 1991 Leg Turbo SS AT Phx,AZ JapCarRealGood Private Vehicle 'For Sale' Classifieds 15 12-21-2006 03:39 PM
FS: 1992 Leg SS Turbo 5spd & 1991 Leg Turbo SS AT Phx,AZ JapCarRealGood SWIC Private Classifieds 13 12-21-2006 02:52 PM
FS: Blitz Version one style BOV brand new in the box fix all Subaru Turbo Model JunGdb Private 'For Sale' Classifieds 0 04-12-2005 07:31 AM
