Old 04-01-2009, 08:10 PM   #1
mystilexzero
Member#: 154674
2007 wrx
ugm
Default the start of my rebuild
Hey everyone, to start off i have a 2007 wrx with an 05 sti tranny, and bought an 04 sti bare block. i will be running a minimum blouch dom3 at 26 psi w/ meth, maybe e85 as well, or if funds are alot better ill go with a gt35r with meth and e85/pump.
so far i have bought the following:
-a crank that will be cut .01 over
-acl race bearings main and rod both .01 over
-eagle rods
-wiseco 100mm pistons
-arp headstuds
-gates timing belt
what other things do you recomend for the bareblock?
-I'm thinking new oil pump, the 08 11mm sti one
-a new water pump
-and 10105AA590 subaru overhaul gasket kit from subaru genuine parts
-new oil pan and oil pick up tube? if so what are the 04 sti part numbers?
-new oil cooler? if so what are the 04 sti part numbers?
however upon reading i might skip the oem oil pickup tube, not sure yet as the cheapest aftermarket tube ive seen is 195 dollars.
a friend of mine who builds 4g63's and supra motors claims that i dont need a new oil pan, just to clean it out really well with brake cleaner and wipe it clean
another thing i read was to change out the oil cooler, you can build one on summit racing for around 200-300 dollars, anyone recomend this as well?
mystilexzero is offline   Reply With Quote
Old 04-02-2009, 01:38 AM   #2
mystilexzero
Member#: 154674
2007 wrx
ugm
anyone got the part numbers? im searching around and only come up with wrx part numbers, are they all the same?
keep in mind all i have is the 2004 sti bare block and my heads, if theres anything else i should be needing, such as certain connectors or anything please chime in.
Old 04-02-2009, 04:16 AM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Oil pan - 11109AA131
Go with an aftermarket pickup tube or maybe just get the Moroso oil pan.
Did you spin a rod bearing or something on your 07 block? Just clean up the old parts if you didn't so you can reuse the oil pan and oil cooler or just go aftermarket.
People recommend the 11mm 08 pump if you've got looser bearing clearances so I just got that one and shimmed it.
While you pull the motor out you might as well remove the air pump system. Buy the block off plates for the heads from KS Tech or something and remove the whole system.
alcoolaid is offline   Reply With Quote
Old 04-02-2009, 11:52 AM   #4
mystilexzero
Member#: 154674
2007 wrx
ugm
no my 07 block is still running strong! the reason why i wanted the 04 sti oil cooler is for the clearance of the perrin equal length headers, it says it doesnt fit with the 06/07 wrx oil cooler, so if someone has that part number id appreciate it, perrin only shows the 02-05 wrx one.
yea i think i will re-use my oil pan, ill flush it clean with brake fluid and call it a day.
but i still need the water pump number, i keep searching and find the 02-05 wrx one, are they the same water pump?
Old 04-03-2009, 11:45 AM   #5
mystilexzero
Member#: 154674
2007 wrx
ugm
anyone else have something to chime in?
Old 04-04-2009, 02:47 PM   #6
mystilexzero
Member#: 154674
2007 wrx
ugm
upon reading i also see that everyone is also replacing timing belt tensionors? is there any thing else as well? it seems alot of info is scattered between the built motor discussion and the 2.0 and 2.5 litre discussion
i just talked to my engine builder, he said my since my motor only has 20k miles i should be fine using my water pump, and all tensioners and pulleys until my next 60k mile service
The start of my custom exhaust CenCali07sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 107 06-17-2008 10:36 AM
Questions at the end of my rebuild auditech28655 Built Motor Discussion 1 01-13-2008 10:45 PM
The start of my day xtheviperx Texas Impreza Club Forum -- TXIC 15 12-14-2004 07:38 PM
The start of my day xtheviperx Off-Topic 4 12-13-2004 11:54 AM
Rebuild the front of my wrx!!! Silky Bay Area Impreza Club Forum -- BAIC 2 04-04-2003 06:20 PM
