Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 04-01-2009, 10:18 PM   #1
veener79
Member#: 204304
2008 WRX 4D Stage 2
Default Tire PSI for Kumho Ecsta MX 225-45-17 08 WRX
I just had my Kumho Ecsta MX 225-45-17 installed. I am not sure what tire pressures to run off the track.
From posting before it looks like when I autocross I should run the tires at 40 in the fronts and 45 in the rears. When I am off the track what pressure should I run these tires at?
Thanks
veener79 is offline   Reply With Quote
Old 04-02-2009, 05:33 AM   #2
StuBeck
Member#: 19546
2009 Honda Fit
Normal as other tires.
StuBeck is offline   Reply With Quote
Old 04-02-2009, 03:42 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
no....I dont think so.....and 'normal' is a nebulous answer
When I used the MX....they seemed to like more pressure.....like 39-41psi and also more negative camber than some tires I've used
Old 04-02-2009, 03:57 PM   #4
veener79
Member#: 204304
2008 WRX 4D Stage 2
If I am running autocross and daily driving what is a good setup for my car? I would like to get the most out my my car and tires. Does the 08 need camber bolts or is that something that is built in to be adjustable?
Old 04-02-2009, 06:30 PM   #5
tuskenraider
Member#: 65699
15 WRX
WR Blue
The best setup for both with the stock suspension is as much camber as you can get up front and as little as possible in the rear. The front has camber bolts for adjustment, you can take it to an alignment shop(one that actually has some experience in race applicatons) and hope to get about -1 or so and you'll want 0 toe. Rear has no adjustment, but you can loosen bolts and tighten the slop, 0 toe as well. Adding rear bolts would boot you from stock class.
tuskenraider is offline   Reply With Quote
Old 04-03-2009, 10:35 AM   #6
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Not to derail your topic, but be careful with these tires.
I had a set installed (225/40/18) when my Pilot Sports wore out, mainly because they seemed to offer a lot of the performance of the PS at about half the price.
At the time, the local highly respected performance tire dealer told me I would not be happy with them. I didn't have much of a choice so I told them to put them on anyway.
Camber was set to -0.5. 8000 highway miles later, the inner 1/2" edge of BOTH fronts actually delaminated while I was on the highway doing 70.
Called the tire store, who gave me the Kumho customer service/warranty number. Called 6 times in a week - no response, no call back, nothing.
Went back to the tire dealer and they gladly replaced all four of them at no cost (yay for customer service!). In my conversation with them, they implied that they had a LOT of trouble with these tires, "they can't handle ANY camber", etc. They verified the previous alignment was still good before replacing and re-aligning. I was in the shop and saw the results so it wasn't word of mouth.
Perhaps it was a bad batch, I don't know. I don't want to speculate on their QA or tarnish the Kumho name. In fact, I run Victoracers for track days! I'm just letting you know to keep a sharp eye on the inner edges if you are running any camber at all.
PM me if you want the tire dealer info.
Back on topic -- when I had them, I ran 32 pounds F/R on the street.
sdecker is offline   Reply With Quote
Old 04-03-2009, 10:52 AM   #7
Big_DeWeY
Member#: 37078
95 L
Blue-ish
I assuming 51 PSI isn't correct then Neil?
Scott, these were the same tires you had issues with? That's good to know.
Big_DeWeY is offline   Reply With Quote
Old 04-03-2009, 10:55 AM   #8
sdecker
Member#: 14717
2002 WRX, WR Blue
Correct. Fortunately my tire guy is 'da man' and made it right for me.
Old 04-03-2009, 11:13 AM   #9
dan240
Member#: 57969
2004 WRX
sdecker---
Many people run ALOT of static camber on dual duty street cars all the time. I've gone through two sets of kumho MX's running 3.5 degrees of camber in the front. With a little bit of autocrossing and rotating my tires I have not had any abnormal tire wear. I do see a lot more tramlining with this set up.
Camber doesn't kill tires, Toe kills tires. A half a degree of camber is nothing. I believe Subaru's allowance for a factory alignment allows for almost 1.5 degrees in the rear.
I suspect you either got part of a badge batch of tires or you had some toe issues.
Sorry I added to the thread jack.
dan240 is offline   Reply With Quote
Old 04-03-2009, 12:06 PM   #10
sdecker
Member#: 14717
2002 WRX, WR Blue
Rally Stuff
Originally Posted by dan240 View Post
sdecker---
I'm assuming bad batch. I watched the alignment tech take measurements before the new tires were put on, specifically because I thought alignment was much more likely than a bad batch. Everything was right on including toe.
I now return you to your regularly scheduled thread.
Old 04-03-2009, 12:46 PM   #11
StuBeck
Member#: 19546
2009 Honda Fit
Asking in the wrong forum is a silly place as well
Old 04-03-2009, 12:51 PM   #12
veener79
Member#: 204304
2008 WRX 4D Stage 2
Only reason I posted on this area instead of the tires was because when did a search for the correct PSI most of the things that came up where from this section.
Old 04-03-2009, 01:54 PM   #13
BSTON
Member#: 178954
2008 WRX
2008 Forester Sports X
Like tuskenraider said, the rear has no bolts so you won't be able to adjust camber on the rear. On mine it was set at -1.3 deg.
You can adjust the front but you can't change the bolts or add anything if you want to keep the DS PAX index in the street tire class in Milwaukee. If you change any parts it will most likely bump you up to STU where you won't even have a chance to be competitive. If you want the car to handle better and don't care about competition you could do that.
On my car the front camber maxed out at -0.7 deg...not much at all.
I don't have much to add to the tire pressure thing. I would start in the upper 30's and see how it rides.
BSTON is offline   Reply With Quote
Old 04-03-2009, 05:52 PM   #14
veener79
Member#: 204304
2008 WRX 4D Stage 2
Thanks BSTON. I was wondering the most I could do with stock parts. Will see what the alinment shop can do for me with the front with the stock parts.
I do want to stay competitive so that is why I am asking so many questions on what I can do stock.
Old 04-04-2009, 11:47 PM   #15
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you almost certainly had a toe issue that killed your tires
I ran -3 camber and never had any issues......I HAVE had issues with toe eating tires VERY quickly
Old 04-06-2009, 03:53 PM   #16
sdecker
Member#: 14717
2002 WRX, WR Blue
I thought so too, which is why i looked at the alignment *before* any changes were made. No unusual toe was found.
I'm thinking bad batch of tires as they commented they had seen a lot of them come back.
Either way, OP -- just a heads up. Do with it what you will and good luck.
WTB - Kumho Ecsta MX - 225/45/17 fish917 Private 'Wanted' Classifieds 4 05-01-2009 12:38 PM
5 kumho Ecsta MX 225-45-17 Jack NESIC Private Classifieds 3 12-25-2007 08:45 PM
Tires For sale in NNJ: Kumho Ecsta Supra 225/45/17...&!! DriftRS Tri-State Area Forum 3 05-29-2005 09:47 AM
FS: Kumho Ecsta MX 225/45/17 NEW 02 T-WREX Private 'For Sale' Classifieds 0 05-17-2005 12:28 AM
