Old 04-15-2002, 10:57 AM   #1
jbdesros
Member#: 10290
2000 2.5rs
blue ridge pearl
Default no fuel ????
Ok i have had a serious stalliing problem for a year now. Finally figured out that its the fuel pump shutting off. after a few cycles of turning the key off then on. off then on, finally i'll hear the fuel pump whine and some relays click. and all is good until the next time it stalls and i have to cycle the ignition a few times and then she fires up again. I am finallly fed up and i am going to fix it this. any help on where to start or any possible solutions are appreciated PLEASE NO "JUST TAKE IT TO THE DEALER" PLEASE, its out of warranty and its not an option unless your willing to pay. thanks guys and girls
jbdesros is offline   Reply With Quote
Old 04-15-2002, 12:33 PM   #2
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Default Re: no fuel ????
Too bad I'm not rich, cause I'm willing.
Evan J. Kelly is offline   Reply With Quote
Old 04-16-2002, 08:02 AM   #3
jbdesros
Member#: 10290
2000 2.5rs
blue ridge pearl
Default any ideas on where to start???
any ideas anyone???
Old 04-16-2002, 01:22 PM   #4
jbdesros
Member#: 10290
2000 2.5rs
blue ridge pearl
Default bueller???
anyone?????? bueller?????? hello?????
Old 04-17-2002, 01:50 PM   #5
jbdesros
Member#: 10290
2000 2.5rs
blue ridge pearl
anyone know how the pump is wired to what relay and what connection on the key switch???? c.mon i thought you guys were the guru's here.????
Old 04-17-2002, 03:12 PM   #6
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Your best bet is to get ahold of a service manual for your car year. That will give you a definite wiring diagram and will show you all the different connections in the car. I don't have a set for my car yet, but I've used a friend's set to do some wiring stuff in my car. It helps a ton and if you're going to be working on your car's subsystems like that, I'd say it's a wortyh investment.
I can't help otherwise, as I'd need to look at those diagrams to figure things out. But I can definitely say those books will have the answer. YOu can most likely order them from the dealer's service desk.
AJ711 is offline   Reply With Quote
Old 04-21-2002, 07:25 AM   #7
jbdesros
Member#: 10290
2000 2.5rs
blue ridge pearl
anyone know where i can get a service manual (used, copied, burned onto a cd....etc...anything cheaper than the dealer)???
Old 04-22-2002, 08:59 AM   #8
jbdesros
Member#: 10290
2000 2.5rs
blue ridge pearl
please someone help, i have never had to bump myself so much......bump
Old 04-22-2002, 09:04 AM   #9
NNeves
Member#: 4973
2000 2.5 RS
dont know, ive been looking for one, for 1 yr now, and chilton doesnt make one.
NNeves is offline   Reply With Quote
Old 04-22-2002, 12:12 PM   #10
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
You can look at subaruparts.com but you'll have to buy all the accompanying books from the previous years. However, if you make a trip to the dealer, you can get the specific year books (there are 8 or so, each covering different parts/systems of the car) for cheaper. There is nothing out from Chilton or any other kind of service book.
No Fuel, no codes. The saga continues Noizemaker Normally Aspirated Powertrain 2 04-11-2006 05:58 PM
after motor reinstall, no fuel pressure, no start. help me diagnose! jared nelson Factory 2.0L Turbo Powertrain 74 11-04-2005 01:36 AM
no spark & no fuel = no start Annoying Eric Normally Aspirated Powertrain 7 08-30-2005 08:58 AM
fuel rail or no fuel rail WrxRacer305whp Factory 2.0L Turbo Powertrain 4 09-08-2004 05:22 PM
No fuel pressure = no bill at the rally-x bill harvey New England Impreza Club Forum -- NESIC 19 11-05-2001 06:44 PM
Message Board Statistics All times are GMT -4. The time now is 10:09 PM.
