Old 04-01-2009, 11:40 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default "Cam Plugs" Reusable?
So I'm about to tear into my heads to swap cams. I was working from a parts list that turned out to be incomplete. The list was lacking the "cam plugs". These are apparently plastic/rubber cap/plug things that go on the rear end of the cam to create an oil seal at the back of the head. This is on a EJ253 if it matters.
If I manage to remove the existing ones from the current cams without damaging them, is it reasonable to re-use them?
Old 04-01-2009, 11:59 PM   #2
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
My service manual says you don't need to replace the cam plugs, but there is a seal underneath the plug that you should replace if removed, they mention that you should only remove said seal if necessary.
Merp is offline   Reply With Quote
Old 04-02-2009, 01:11 AM   #3
n2oiroc
Member#: 141952
15 legacy 16 wrx
i dont see why not. just clean all the old silicone off and clean them up good. the silicone does all the sealing.
n2oiroc is online now   Reply With Quote
Old 04-02-2009, 01:29 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Supposedly you're not supposed to put RTV on these things though.
Specifically, the only place these things are mentioned is on page ME(H4SO)-52 of the 2005 service manual. The entirety of the text is:
4)Install the plug using ST.
ST 499587700 CAMSHAFT OIL SEAL INSTALLER
The only time RTV is mentioned is when re-installing the "cam cap" (metal frame that hold the cam in place and gives a mounting for the rocker assy) and that's over and done with a page before these cap things are mentioned.
Old 04-02-2009, 02:22 AM   #5
n2oiroc
Member#: 141952
15 legacy 16 wrx
oh crap, i was thinking the half moon rubber plugs at the back of the heads. im not familiar with the 253, does it use a different setup? if its actual oil seals then get new ones.
Old 04-13-2009, 08:11 PM   #6
jester409
Member#: 64376
04 WRX
I am doing a 2.5L swap and noticed that my donor motor has the passenger side cam plug knocked in unevenly at least 1/8" on one side. I would like to pop it out and replace it with a new one but can't locate them anywhere online. I finally gave up and came to search NASIOC which brought up this thread.
Question #1: What is the part number for a replacement plug (engine is a 2005 EJ253 SOHC)?
Question #2: Will having this plug knocked too far in damage anything, assuming it doesn't leak of course.
jester409 is offline   Reply With Quote
Old 04-13-2009, 08:21 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
2) From taking it apart, twice, if it's sealed and not rubbing against the cam, I can't think of anything it can hurt.
I'm not a professional, though, so you may not want to take my word on this one since I'm don't have a huge amount of engine building experience.
Old 04-13-2009, 08:59 PM   #8
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
They get brittle when they get old and the the edges break off easily when you remove them. I install them with Honda Bond, works good. If they are not damaged it wouldn't hurt to reuse but, why chance a leak on a $5 part?
slowmike is offline   Reply With Quote
Free! "How to install a TMIC and Spark Plugs" training class. mav1c Mid Atlantic Impreza Club -- MAIC 26 01-20-2007 06:07 PM
quick question...are "cam seals" called something else in subie world? kaisersouse General Community 7 07-22-2005 08:47 PM
Source for "cam tools" for dohc ej25 timing belt replacement lag Legacy Forum 8 04-20-2004 10:39 AM
Source for "cam tools" for dohc ej25 timing belt replacement lag Service & Maintenance 1 04-17-2004 06:11 PM
What's the deal with "Performance Plugs"? oney01 Normally Aspirated Powertrain 2 10-08-2002 01:44 PM
