Old 04-01-2009, 11:49 PM   #1
snbco07
Member#: 191846
2002 WRX WAGON
Smile LC-1 Wideband replacing factory o2
So my question is... How would I go about wiring up the analog output(yellow wire aka narrowband output) to my factory rear o2 harness? Which plug would I use, and what happens to the other plugs on the sensor connector? I plan on putting the wideband sensor in my factory DP location, it seems the right thing to do if the LC-1 can do narrow and wideband. Thanks for any input!
snbco07 is offline   Reply With Quote
Old 04-02-2009, 12:02 AM   #2
snbco07
Member#: 191846
2002 WRX WAGON
Or better yet, can I leave the factory o2 disconnected altogether, turn off the CEL's and call it good with just wideband?
Old 04-02-2009, 12:10 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you have to use the stock front o2
the rear can be done away with on the pre-04's
Old 04-02-2009, 12:35 AM   #4
snbco07
Member#: 191846
2002 WRX WAGON
Awesome thats exactly what I was hoping. Just for the record though, if I did have an 04+ how would I go about wiring that? Or could I even? Thanks Scotty
Old 04-02-2009, 01:51 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
the front o2 is used by the ecu to control the engine operating parameters and must be used....and only a subaru sensor should be used----others usually cause issues of some sort or other.
on the 02-03 the rear o2 only monitors cat function and you can do away with it and kill the code with opensource and forgetaboutit---on 04+ cars, the ecu uses the rear o2 to adjust fuel trims and getting rid of it can be problematic....but you can turn off the 'cat inefficiency' code with open source and run catless---but keep the rear o2 in place to keep the ecu happy...and just have another bung welded in for the wideband....the bung can be bought for >$10 and a competent muffler shop can install it easily
____________________________
with the progress of opensource tuning and its capabilities using any kind of mechanical or 'wired in' so called 'fix' to run catless is just plain stupid
get a cable and a laptop and kill the code and done
Old 04-02-2009, 11:52 AM   #6
snbco07
Member#: 191846
2002 WRX WAGON
That solves it for me, thanks!
Old 04-02-2009, 04:43 PM   #7
steverx05
Member#: 128269
'13 VW Golf R
How much is it hurting the car to run the "mechanical" fix on an 05? I went with that to make sure I would pass emissions tests but if it's causing harm then I want to take it off and clear the code some other way.
steverx05 is offline   Reply With Quote
Old 04-02-2009, 06:25 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
well....turning the code off with open source is the best solution
you would have to log your fuel trims to see what they are and what they become after you remove the mechanical fix
Can a LC-1 wideband replace the OEM sensor on a 2005 RS? colorfull Normally Aspirated Powertrain 5 08-06-2009 10:42 AM
FS: LC-1 Wideband o2 i0nic NESIC Private Classifieds 0 11-16-2006 06:34 PM
FS: Innovate LC-1 Wideband O2 sensor controller kit NicFunkadelic Engine/Power/Exhaust 22 09-13-2006 11:09 AM
ONE DAY LEFT! - FS: NEW Innovate Motorsports LC-1 Wideband o2 sensor kit! dexterous Private 'For Sale' Classifieds 0 04-09-2006 09:48 PM
FS: NEW Innovate Motorsports LC-1 Wideband o2 sensor kit dexterous Private 'For Sale' Classifieds 5 04-06-2006 10:06 PM
