Old 04-02-2009, 12:20 AM   #1
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Default 95 WRX RA into 98 forester, help?
so the current car is a 95 coupe with a swapped ej20g from a 95 RA front clip. so i want to put it all into the forester which i have stripped to the shell but the wiring harness is still there. i want to just swap my whole harness and everything , but would like to integrate the dash harness of the forester with the engine harness of the impreza.
i don"t remember if there is a super multiple junction there that might be interchangeable. plus its a real shame to give up OBD2
help
AsphaltsCry is offline   Reply With Quote
Old 04-02-2009, 02:01 AM   #2
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
Look in the main swap threads. You can find wiring diagrams for the Forester, etc.
Carter is offline   Reply With Quote
Old 04-02-2009, 10:13 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
smj is not interchangeable and your going to lose the obd-2 with a ej20g no matter what
Old 04-02-2009, 11:16 AM   #4
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
i assumed ob2 would be going bye bye. i wonder if i could re-pin either end of the SMJ? i wanted to keep the forester dash harness for things like the cruise control and HVAC. plus do i use my cable driven speedo adapted to the forester harness or .... speed sensor ....
thanks for all the responses
Old 04-03-2009, 10:14 AM   #5
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
you really should do a remerge. the forester has stuff in different locations then the Impreza and I'm sure that a lot of harness plugs have changed shape. Regarding the VSS you can swap the Forester VSS into the V2 and use that. You can also do the same for the neutral and reverse switches.
Z
Zephyr is offline   Reply With Quote
95 WRX RA, Z5 ECU, turbo? cams? wrxtypr Pre-2002 Factory Turbo Powertrain 2 05-10-2009 06:53 AM
02WRX catback into 98 GC---HELP! minhha2006 Subaru Conversions 0 05-03-2008 04:59 PM
Swapping a 99RS guage into a 98 forester, help please snowjob Electrical & Lighting 0 03-13-2006 09:10 AM
WRX turbo in 98 Forester? joenationwide Forester Forum 0 09-19-2004 12:36 AM
WRX swap into a Forester. omahasubaru Forester Forum 5 03-23-2001 05:11 AM
