Old 04-02-2009, 02:08 AM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default which clutch... 02-03 right?
well soon i fear i have to change my clutch...
i have a 94 wrx with the 94 wrx tranny as well...
unknown miles on the clutch....i just used what came with the front clip...
any suggestions on what i should get? store? site?
what about flywheels... would it be worth putting in a light weight, since i will have the tranny and engine separated...
or do u feel having a light weight flywheel is not fun....
azn0boi04 is offline   Reply With Quote
Old 04-02-2009, 02:20 AM   #2
RallyColtTurbo
Member#: 16819
WRX clutches and flywheels are what you want.
If you get a flyhweel you can save the downtime it normally takes to get yours resurfaced. Something to think about.
RallyColtTurbo is offline   Reply With Quote
Old 04-02-2009, 03:19 AM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
there is a slight difference between jdm wrx clutches
- early (93-96, v1-2ish) clutch is 225mm
- 97-00 (v3ish-6ish) clutch is 230mm
flywheels are all the same between them though, oddly.
USDM wrx clutch is 230mm
you COULD reuse your flywheel but if its decently used then you might just want to replace it. idk how accurate it is but ive heard its not really worth resurfacing subaru flywheels.... (?)
at any rate, a 02-04ish (ish=maybe 05) clutch kit will work.
heres some part #s since i JUST looked all this up a few days ago
Exedy lightened flywheel FF01T about $280 street price
Exedy organic/stage1 kit 15802/15802HD - about $425 street price
Exedy OEM replacement kit KSB03 - about $190 street price
strangely i found the KSB03 oem replacement clutch kit on amazon for only $150 even though it was over $185 everywhere else
http://www.amazon.com/EXEDY-KSB03-OE...8656773&sr=8-1
^^ BEST DEAL
elislider is offline   Reply With Quote
Old 04-02-2009, 05:59 PM   #4
gongeuzler
Member#: 16103
GC's
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
Thats what I went with in my 94 WRX swap, have about 15k on it now, no complaints.
gongeuzler is offline   Reply With Quote
Old 04-03-2009, 04:11 PM   #5
98jdmwrx
Member#: 146962
i got the ebay stage 2, works fine in my 98 wrx
98jdmwrx is offline   Reply With Quote
Old 04-28-2009, 07:36 PM   #6
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
So this is true with the USDM WRX clutches fit with a V6 STi??
MonikAWD is offline   Reply With Quote
Old 04-28-2009, 07:50 PM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
^^ BEST DEAL
Too many ishes!
i_c_the_light is offline   Reply With Quote
Old 04-29-2009, 04:27 PM   #8
ckcadavona
Member#: 135730
93 L
Yes...thats what I'm running in my V5
ckcadavona is offline   Reply With Quote
Old 04-30-2009, 05:31 PM   #9
elislider
Member#: 133923
03 Legacy GT wagon
Originally Posted by i_c_the_light View Post
Too many ishes!
haha well im trying to just be safe and not say "all XX year works!" and have someone come in a say "no i have XX year and it doesnt!"
because as ive come to learn with everything jdm (and even some usdm) in subaru land, 98% of the time what is documented is correct, but sometimes its not, for who knows what reason
Old 05-01-2009, 10:08 PM   #10
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
FWIW... Ver 2 ('96 JDM 4.11) using JDM flywheel and '02 USDM STi 5MT clutch/pressure plate.
beaviscih is offline   Reply With Quote
Old 05-02-2009, 03:49 AM   #11
sniper512
Member#: 189923
1993 JDM WRX
02-04 is a for sure fit. I put a Southbend Sgt1 Rally in my car and a centerforce stg1 in a friends car as well. Both cars were a 93 JDM WRX.
sniper512 is offline   Reply With Quote
Old 05-02-2009, 01:06 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
All that really matters is that you keep them mated. So, if you buy an '02 WRX clutch kit for your 1995 EJ20G swap, you probably want to buy a new flywheel for it as well and not reuse the one that came on the swap from the importer. Sort of.
We've debated this issue in the USDM 91-94 Legacy circles for a few years now. What we have found is that even though the Legacy uses the earlier smaller diameter clutch disc, you can use the later larger clutch on the original flywheel. Technically the friction surface on it is too small but if the flywheel doesn't have excess wear on it you will be fine. I will mention that some people report chatter when doing this and suggest you resurface the flywheel. I don't like to resurface Subaru flywheels. I've seen issues with doing that resulting in chatter because of the change in depth. Basically, you are kind of rolling the dice either way. If it's not pretty pristine, I would just buy a new flywheel and use it as an excuse to go lightweight.
So, having said all that confusion convoluted stuff, this is the bottom line. You can use a USDM Ej205 '02-04 clutch kit and flywheel (stock or lightweight) on ANY JDM WRX swap. They never changed the bolt pattern on the crank. As long as it's mated to the type of transmission is all that matters. If you did a swap and left a push style clutch, then get an upgraded clutch kit for the 2.5RS. If you put in a pull style tranny, then get the USDM WRX clutch kit.
02/03 mirror glass drivers side hybrid gti 2 SCIC Private Classifieds 1 06-11-2010 12:10 PM
SOLD (ME)- 02/03 WRX WRB Stock Hood Scoop dlewis Exterior/Styling 8 06-01-2010 01:06 PM
SOLD (ME)- 02/03 WRX UTEC with map switch dlewis Engine/Power/Exhaust 8 05-25-2010 01:24 PM
SOLD ME: 02/03 WRX UTEC with map switch dlewis NESIC Private Classifieds 6 05-25-2010 01:24 PM
WTB: WRB 02-03 Right Fender kirkeemonster NWIC Private Classifieds 3 03-20-2008 01:46 AM
