Old 04-02-2009, 08:40 AM   #1
INFMIS
Member#: 174494
Default Engine Loom problem?? PLEASE HELP
Hey NASIOC,
I have a 1995 WRX STI RA (verson 2).
I removed the engine loom a while ago when rebuilding the engine, whilst the engine loom was off i decided to strip all the factory tape from the wires to check the condition of the loom and then i re-covered it with new tape.
Now the problem..
I went to fit the engine loom to my newly built engine and i don't know what injector plug goes to what injector? and what coil plug goes to what coil? Even some of the other sensors have the same plugs and i dont want to connect them to the wrong plug.
If anyone has encountered this problem before or there is a rule to engine looms or even a diagram of the pin layout of the entire loom to help me see this through i would be extremely thankfull
Thankyou!
INFMIS is offline   Reply With Quote
Old 04-02-2009, 11:20 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
trace the plugs back to the ecu pins using a meter ..
Old 04-02-2009, 02:17 PM   #3
MasterKwan
Member#: 98961
2003 WRX
Or use the wiring diagram and check the color codes. That's WHY the wires are color coded.
Old 04-02-2009, 03:23 PM   #4
INFMIS
Member#: 174494
MasterKwan, do you know where i can find a wiring diagram for this?
Thankyou for your help.
Old 04-02-2009, 03:59 PM   #5
Sparky280
Member#: 69896
98 WRX Swapped "L"
VF39 294HP/277TQ @19psi
Sparky280 is offline   Reply With Quote
Old 04-02-2009, 05:43 PM   #6
MasterKwan
Member#: 98961
2003 WRX
I have a manual that claims to be an '95 WRX manual. Not sure I believe it.
Ignition Coil
#1 Y,RG
#2 Y,WR
#3 Y,L L is Blue in subaru colors
#4 Y, Lg Lg is light green
Connector Colors
#1 and #2 - Gray
#3 and #4 - Black
Injector
#1 Br,YR
#2 Lg,YR
#3 LR,YR
#4 LB,YR
Connector Colors
It says #1 and #2 are light Gray
and #3 and #4 are Dark Gray
Old 04-02-2009, 09:49 PM   #7
INFMIS
Member#: 174494
masterkwan my friend you are a genius!!
Those colors match up perfectly and make sense
Thanks alot dude
Old 04-03-2009, 10:49 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um no
do not trust the wire color in a subaru harness
i know from personal experience subaru will splice the wires mid run
start with the color but use a meter
Old 04-03-2009, 11:07 AM   #9
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Originally Posted by Jaxx View Post
um no
I'm going to have to agree 100% with Jaxx. Double check with a meter.
Zephyr is offline   Reply With Quote
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 10:59 AM
Engine Loom problem?? please help INFMIS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-01-2009 10:23 PM
engine problem please help . vf22 owners moorebl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-12-2004 08:12 PM
Engine/Boost problem, please help trehlo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-05-2004 10:56 PM
Engine Problem. PLEASE help. james_gt Normally Aspirated Powertrain 5 11-04-2002 02:19 PM
