Old 04-02-2009, 11:09 AM   #1
CHEWY911
Member#: 179450
2004 WRX
Default Manley Pistons, STi Rods, OEM crank
Hi Eeveryone,
Rebuilding my 2.0 from my 2004, does this sound like a decent combo for a reliable 300whp - 350whp motor?
Thanks!
CHEWY911 is offline   Reply With Quote
Old 04-02-2009, 11:48 AM   #2
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
the wrx rods are the same as the sti. don't bother buying sti rods to try to upgrade.
that is a fine setup, all you really need is forged piston for the motor for that power.
kevinh211 is offline   Reply With Quote
Old 04-02-2009, 11:51 AM   #3
06njsti
Member#: 150986
06 #001 LSB STi
you will be fine, im pretty sure you can go 350whp on a stock block with somewhat low miles and be fine all day. pistons are all you need until you start talking 400whp+
06njsti is offline   Reply With Quote
Old 04-02-2009, 02:18 PM   #4
CHEWY911
Member#: 179450
2004 WRX
Should I just stick with a new OEM shortblock then and skip the hassle of a built motor?
Old 04-02-2009, 02:24 PM   #5
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Nope...at a minimum you should do forged pistons if you plan on going with a bigger turbo at all.
Team Scream is offline   Reply With Quote
Old 04-02-2009, 03:26 PM   #6
kelley05
Member#: 174596
2005 WRX
From experience I can tell you that I just rebuilt my stock 2.0L bottom end, using STI rods, and Mahley 93mm bore pistons. Also had the entire rotating assembly balanced. Im running a 18g turbo and my bottom end should be able to take whatever I can throw at it.
kelley05 is offline   Reply With Quote
Old 04-02-2009, 04:25 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
This maybe true for the 2.5L WRX blocks but it's not true for the 2L blocks. 2L WRX rods are very weak.
mick_the_ginge is offline   Reply With Quote
Old 04-02-2009, 05:28 PM   #8
CHEWY911
Member#: 179450
2004 WRX
Good to know, as I have an 18G set up too.
What bearings did you end up using?
Also, do I have to worry about the gunk in my block from spinning a bearing or will the hot tank process flush all of this out?
Old 04-02-2009, 06:49 PM   #9
kelley05
Member#: 174596
2005 WRX
The hot tank process should take care of any gunk, I dont know that for a fact though. When my machine work was done the block halves were very clean from the hot tank process. Sorry I forgot to add that the bearings I used were ACL race series both rod and mains.
Old 04-02-2009, 08:12 PM   #10
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
toss the oil cooler, you will never be able to clean it out
PA: OEM EJ257 Pistons and rods, OEM EJ205 head gasket. Richie03 Engine/Power/Exhaust 28 04-13-2010 09:33 PM
EJ257 STI Rods & Crank Crankshaft Hayaboosted Engine/Power/Exhaust 11 08-05-2008 11:14 PM
CP 9:1 Pistons/STI Rods/Perrin Blow-Thru BlackSubie06 Engine/Power/Exhaust 0 09-18-2007 04:13 AM
Built 2L long block, JE pistons, STI rods, DPR stage 4 cams mick_the_ginge NWIC Private Classifieds 42 02-17-2007 09:49 PM
FS:OR: Built 2L long block, JE pistons, STI rods, DPR stage 4 cams mick_the_ginge Engine/Power/Exhaust 25 02-16-2007 02:02 PM
