Old 04-02-2009, 01:42 PM   #1
JustinJS
Member#: 170855
2017 WRX
Question strange rattling noise.
I noticed today that their is a rattling noise coming from my engine. I dont know if i has always done this as i normally drive with the music up. But it is only when i hit around 2150 to 2300 rpm and then again 4200 to around 4350 rpm. It does not matter what speed i am traveling at if im on the gas in the ranges as stated it will just make a rattling noise.
Any idea what it could be and if i should worry about it.
Btw no CEL is on and all fluids are fine.
JustinJS is offline   Reply With Quote
Old 04-02-2009, 08:15 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
worn or broken engine and or transmission mount(s) is my best guess for a place to look first. sounds like certain harmonics are just right to vibrate the cabin. My Group-n mounts do this a little bit right at 3k and again near redline, where as my sock mounts never did, so im pretty sure the mounts caused it.
Maybe a bad pulley or beltcover?
Old 04-03-2009, 01:02 AM   #3
tomthedancinghobo
Member#: 207473
Default Obvious but...
A loose bolt somewheres.
tomthedancinghobo is offline   Reply With Quote
Strange rattling noise at low RPM koblerone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-22-2007 09:55 PM
Strange rattling noise nicktckhoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-25-2002 03:13 PM
Can anyone help? Strange underhood or underbody squeaky rattle noise beachbum General Forum Archive 11 03-10-2001 08:30 PM
Stromung Installed ==> Strange rattling noise? Bobalouy Technical Forum Archive 3 06-28-2000 08:31 PM
