Old 04-02-2009, 05:49 PM   #1
Ultimate Collision Center
Member#: 69072
Default Snow Performance Q&A
I am here to answer any questions you may have about the alcohol methanol water injection kits...
Ultimate Collision Center is offline   Reply With Quote
Old 04-02-2009, 06:13 PM   #2
vatorn10
Member#: 124724
Yay Snow is on the fourm now!
vatorn10 is offline   Reply With Quote
Old 04-03-2009, 11:09 PM   #3
neorex
Member#: 106478
STi 1.5 xt-r
i have a stage 2 kit with the 150+psi shurflo pump...the pressure adjustment screw on the pump has stripped out/jammed....
it is this common issue...?
are the pumps serviceable...?
neorex is offline   Reply With Quote
Old 04-03-2009, 11:12 PM   #4
Member#: 69072
We are excited too, we had been for a while but I took the past several months off due to personal but I am back for good again
Old 04-03-2009, 11:13 PM   #5
Member#: 69072
Drop me a pm with when you bought it and from where and I will see what I can do. You are the first that I have heard of this. Pumps are definitely serviceable.
Old 07-15-2009, 02:30 PM   #6
Member#: 69072
pmed fellas
Old 07-15-2009, 10:02 PM   #7
deanwrx
Member#: 188997
2007 STI
Hi there,
I was thinking of meth injection. I just started modding my car (02 wrx - 120k miles). I'll have stage 2, which is uppipe, downpipe, and mapping.
So the question is can I do meth injection at this point? And will I need any special tune for it?
In a few months, I'm putting on a vf39 turbo and larger injectors/fuel pump. Will it work with this future combo? I'd remap for this. Again, will a special tune be necessary with meth injection at this point?
This is still my daily driver so reliability is an issue. And final question, if I run out of the meth mixture while driving, will I be in trouble?
Thanks for your help,
Dean
deanwrx is offline   Reply With Quote
Old 07-15-2009, 10:05 PM   #8
Member#: 69072
You can certainly add a kit to your car and your mods, it can help clean up any carbon build up as well. This will also work for your future plans but it may need a retune for the turbo when that time comes around. If you run out and you have a failsafe then it will protect your motor but then I would either fill up the system or switch to a different map to run regular pump gas.
Old 07-15-2009, 10:23 PM   #9
deanwrx
Member#: 188997
2007 STI
That's great to know. Thanks. So with my current mods (stage 2), would I need any special mapping/tune for the meth kit?
I was looking at the "Stage 2 WRX Boost Cooler" and I believe the failsafe you mentioned is the SafeInjection?
Old 07-15-2009, 10:52 PM   #10
Member#: 69072
yea with any system your going to want a tune to run it safely and yes i was referring to the safeinjection
Dan
Old 07-16-2009, 08:05 AM   #11
deanwrx
Member#: 188997
2007 STI
Great. Thanks again.
Old 07-16-2009, 10:08 AM   #12
Member#: 69072
no prob, glad i could help
Old 07-17-2009, 08:45 PM   #13
JSarv
Member#: 163445
l33t *******
[email protected]
any recommendations for E85+ 40+lb turbo... ?
Would be running 100% meth.. Have you done any testing with this?
What setup would you recommend?
JSarv is offline   Reply With Quote
Old 07-17-2009, 09:09 PM   #14
Member#: 69072
are you talking about a 40lb wheel or about 40lbs of boost, i am assuming a 40lb wheel but let me know
Old 07-17-2009, 09:11 PM   #15
JSarv
Member#: 163445
l33t *******
[email protected]
40lb wheel Around 25-28psi...
Old 07-17-2009, 09:35 PM   #16
Member#: 69072
yea thats what i thought, but with that setup i would go with a stage2 boost cooler 20010 and then there are various options that you could add depending on your needs and budget...i haven't personally used e85 + meth but i have heard back from customers of mine that the gains were great with that combo...i personally am not a huge fan of 100% meth i am more of a 50-75% type of guy but everyone has their own preference on that...
Old 09-08-2009, 07:17 PM   #17
Member#: 69072
New, more advanced proprietary pump makes Boost Cooler® even more powerful with increased pressure, more reliability
Snow Performance has developed a new pump for its’ Boost Cooler® water-methanol injection system that promises to take water-methanol injection to the next level and is significantly better than the pump it replaces.
1. Higher pressure – 20 psi higher than even the competitors’ “250” pumps. This equates to better atomization and more power potential.
2. Constant pressure – maintains set pressure and doesn’t cycle like other commonly used designs for even injection, less oscillation.
3. More robust – double seals are used within to ensure long life even in the highest duty cycle applications and environments.
4. More reliability – more pressure with less current draw and improved thermal loading capability. This equates to less heat build up for longer life and the ability to run for extended periods compared to other pumps. This is especially important in road racing and commercial trucking applications.
The new “SHO” (Super High Output) pump will be used across the Boost Cooler® product line and is the outcome of the development effort for the commercial truck/ fleet market where reliability and robustness are mandatory.
Designed as a chemical intercooler for gasoline applications to increased air density, timing, and power, the Boost Cooler® is used in naturally aspirated, boosted and nitrous applications to “add octane”. The system injects a fine mist of water/methanol into the intake tract providing anti-detonation.
In diesels, increased fuel economy and power as well as reduced emissions and exhaust gas temps are the result.
The system comes with everything needed for installation, including a water/methanol specific 220psi high pressure/high volume pump and specially designed nozzles to atomize the mixture completely. Installation takes just 2-3 hours.
Snow Performance has been designing and manufacturing well engineered injection kits for over 8-years for many different types of vehicles with 100’s of hours of dyno and data sharing to ensure maximum performance. Snow Performance- the water-methanol injection experts®
Old 09-22-2009, 03:42 PM   #18
STiyiyi
Member#: 88067
I am currently running one of your kits on my '05 STi. Is your new pump a direct plug and play with the old style pump? Also, are your spray nozzles the same style as I bought in your Stage 2 Boost Cooler kit almost a year ago? I also have your V-100 boost controller upgrade and Safeinjection.
STiyiyi is offline   Reply With Quote
Old 09-22-2009, 03:59 PM   #19
Member#: 69072
The pump is as direct bolt on as you could get for a pump. The nozzles and still same style the holders have been upgraded though.
Old 10-03-2009, 01:43 PM   #20
Member#: 69072
After a rigorous approval process where virtually every aspect of the product and company were discerned, Automotive Accessories Marketing, USA, Inc. (AAM) has approved Snow Performance as a program vendor for each of its’ 23 member automotive/truck aftermarket warehouse distributors opening up distribution potentially to over 700 outlets.
AAM was chartered in 1988 to create a medium through which they might achieve scaled buying advantages for it’s members. Currently the group is comprised of twenty-three member-companies operating twenty six distribution centers throughout the United States and Canada.
The marketing alliance functions primarily as warehouse distributors (WD) and retailers of Automotive and Truck High Performance Parts and Accessories. AAM markets to the performance marketplace under the trade name Parts Pro Performance Centers and Total Truck Centers. Member warehouse distributors currently service approximately 400 Parts Pro program affiliated Jobber/Retailers in addition to thousands of unaffiliated outlets. This population is comprised of approximately 300 well chosen, independently owned Jobber/Retailers who are furnished with a complete marketing plan designed to attract customers to their stores and pull products through their stores. In addition, member WDs operate 100 company-owned stores that also fly the Parts Pro Banner.
Old 10-04-2009, 07:22 AM   #21
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Snow is excellent in marketing than anyone in the meth industry. Well done!
Aquamist is offline   Reply With Quote
Old 10-13-2009, 08:22 AM   #22
Member#: 69072
Snow Performance Holiday Season Rebate!
Snow Performance is offering a $30 rebate on all Boost Coolers purchased from October 1 to December 31! This includes every system from a Stage 1 to a MPG-MAX!
Simply buy your Boost Cooler, make a copy of the invoice, and send it in with the rebate form in PDF format below to get your $30!
Official PERRIN™ Performance Q&A Thread.. PERRIN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1907 01-07-2016 01:49 PM
NEW Snow Performance Safeinjection Q&A... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 15 06-30-2007 05:54 PM
Contiextreme snow performance Jamesdak Tire & Wheel 17 12-17-2003 09:16 PM
Will swaybars affect snow performance? Darkelf_99 Brakes, Steering & Suspension 8 07-14-2003 12:36 PM
Tire pressure and snow performance wwwwc Brakes, Steering & Suspension 1 11-27-2002 03:45 PM
