Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-02-2009, 06:10 PM   #1
theleveler
Member#: 138681
05 9-2x aero
"Sand"
Default Dead light in my Gauge Cluster. Stoopid problem but what will it take?
So the LED(s?) on the far right of my gauge cluster on my 03 N/A mt baja are dead. Basically I cannot see my Oil Temp at all, and the high revs of my Tach are dark at night.
Ugh... Is it possible to just get to the LED's and solder in new ones? Or do I have to buy a whole new gauge cluster. I hope it's the former, since I see lots of color change mods floating around. But I can't find any fix discussions. Then again, I suck at searching this place.
If it is possible, anyone know how I go about doing it? I have to take apart the WHOLE console huh? Is there a guide somewhere for that?
I appreciate any help anyone can offer!
theleveler is offline   Reply With Quote
Old 04-03-2009, 09:07 AM   #2
YBajaSteve
Member#: 184040
. 03' Baja- Sold
83' Datsun 280ZX
ok well since I have the main dashboard color conversion thread, I know from experience, its alot easier than it looks. if you have any experience in taking interior panels out of a car for like a stereo install or something you can do this. currently, if they are still stock, you just have regular bulbs in the back of your gauges. in my color conversion i replaced them with LED's. You can easily buy the bulbs from any auto store. the replacement is easy, you just pop the new bulb in, no soldering at all. ill link you to my other writeups since ive described the process a few times. A haynes manual gives you the step by step so i would highly suggest getting one. (its just good to have anyways) this is a couple threads over on scoobytruck.com, http://scoobytruck.com/bb/viewtopic.php?f=2&t=1077 the bulb number should be #194.
heres another thread - http://scoobytruck.com/bb/viewtopic.php?f=3&t=1092
edit* i just saw you did a stereo install so you know how to get into the dash, its only a few more screws once youre in there. hope this helps. im going to update my dash sometime this week i think,, and ill do a writeup with pics just to have a Baja specific one for everyone. GL
YBajaSteve is offline   Reply With Quote
Old 04-03-2009, 12:25 PM   #3
theleveler
Member#: 138681
05 9-2x aero
"Sand"
Thanks for the response! Your light mod is very nice. It actually seems a bit easier than I had anticipated. I'll give it a shot this weekend with my trusty haynes manual. Thanks a ton!
Old 04-05-2009, 05:12 PM   #4
Alpha Wolf
Member#: 140505
2005 Baja Turbo
Pearl Blue
Cool
I just went through this.
You do not have to pull the steering wheel.
Upper bulbs are large, blue covered and $6, the two lower bulbs are tiny clear and $15. Both go in and out with 1/4 turn.
Disconnect the battery ground
Pull the console cover.
Pull the left side dash cover
Pull the right side dash cover
Pull the gauge cluster bezel
Pull the gauge cluster unit
Turn around remove/replace bad bulb
Reverse.
Took me about an hour total.
Alpha Wolf is offline   Reply With Quote
what will it take for the sue happy culture to go away azn2nr Off-Topic 10 06-13-2007 04:10 AM
Colin Powell at UN: What will it take to convince you? YoungWilliams Off-Topic 43 07-17-2006 12:44 PM
What will it take to....... Boltz Proven Power Bragging 10 04-24-2005 02:10 PM
What will it take to move this? The Enemy Off-Topic 68 01-11-2005 06:07 PM
What will it take... iNfEk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-14-2004 12:41 AM
