Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 04-02-2009, 07:52 PM   #1
streetrcer909
Member#: 171301
2011 wrx
Default Help With Compression Test Results!!!
if i posted this in the wrong section im sorry i just dropped my 04 sti of with 65000miles to get a compression and leak down test done to check the motor before i do my build...
The subaru dealership i brought it too said the results were horrible and if i keep driving the car like i am ill blow the motor i do drive the car hard but i dont beat the **** outta it theres a big difference...the results of the compression test are-
Cylinder 1- 132 psi
Cylinder 2- 125 psi
Cylinder 3- 130 psi
Cylinder 4- 130 psi
i just figured id check with you guys on the forums who probably know how to read these better than me and the tech i just want a second opinion...what do you guys think am i really close to blowing the motor? should i continue witih the build? if you can pm me what you think it would be easeir im not on the forums much basically just to check pms...thanks
streetrcer909 is offline   Reply With Quote
Old 04-02-2009, 08:26 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
From the service manual:
Compression (350 rpm and fully open throttle):
Standard;
951- 1,147kPa(9.7- 11.7kgf/cn?, 138-
166 psi)
Limit;
834 kPa (8.5 kgf/cd, 121 psi)
Difference between c linders;
49 kPa (0.5 k g f / c d 7 psi)
I would say you are ok. There is some variation from gauge to gauge so I wouldn't worry about the numbers being slighty lower since the are all so close and within 7psi from the lowest to the highest.
The main cause of low compression is a broken ringland and with that you would see something like 130,130,130,90.
LiquidForce is offline   Reply With Quote
Old 04-02-2009, 08:29 PM   #3
streetrcer909
Member#: 171301
2011 wrx
haha thanks i have no clue how to read that but guess ill take your word on it...like i said i just wanted a few second opinions from some people on the fourms
Old 04-02-2009, 08:43 PM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
You said you had a leak down test. What were those numbers? They tell a more complete story than a compression test.
Old 04-02-2009, 09:03 PM   #5
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Isn't it also a possibility, when number are low across the board with little deviation, that the motor was simply not warm when the test was done?
If you car sat around outside and the tech only had it running to drive it in and do the test then that would explain the low results. It also seems pretty unlikely that you would have bad leakdown issues equally on all 4 cylinders.
As was already stated, I wouldn't be concerned, but I would find a new dealer to service the car.
CKxx is offline   Reply With Quote
Old 04-03-2009, 12:32 AM   #6
flycaster
Member#: 60142
2011 WRX
Grey
OK, I'll bite...how much did they want to "fix" the car?
PS - there's nothing wrong with it: a little wear, sure, but nothing wrong.
flycaster is offline   Reply With Quote
Old 04-03-2009, 10:36 AM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Ditto, those numbers look good to me, very small spread
mick_the_ginge is offline   Reply With Quote
Old 04-03-2009, 10:45 AM   #8
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
the compression numbers are fine and nothing to worry about. but what about the leakdown numbers?
kevinh211 is offline   Reply With Quote
Old 04-03-2009, 12:26 PM   #9
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Looks ok here as well. Pretty even man. If you see more than a 15# diff, I'd be a bit concerned but its really when one is like 30+ less that you know there is a problem.
Fongers is offline   Reply With Quote
Old 04-03-2009, 03:04 PM   #10
streetrcer909
Member#: 171301
2011 wrx
they didnt want to fix it just told me that if i kept driving the car like i was the motor would blow in a couple months
Old 04-03-2009, 03:11 PM   #11
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
those are all within spec as far as i can tell....
Team Scream is offline   Reply With Quote
Old 04-03-2009, 04:27 PM   #12
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Why would they tell you those result are horrible???? Maybe the leak down test has shown something we are not seeing here??
hustleshark206 is offline   Reply With Quote
Old 04-03-2009, 05:42 PM   #13
Chi_San
Member#: 53558
2002 WRX Wagon
With compression like that, I'd expect good leakdown numbers as well.
Chi_San is offline   Reply With Quote
Old 04-04-2009, 12:52 AM   #14
flycaster
Member#: 60142
2011 WRX
Grey
Uh, money maybe?
Old 04-04-2009, 01:05 PM   #15
jarencibia
Member#: 187021
2004 WRX Sedan
Those numbers aren't bad. Your engine isn't going to spontaneously explode.
When auto service employees make statements like that it makes me angry.
jarencibia is offline   Reply With Quote
Old 04-04-2009, 06:16 PM   #16
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Given my propensity to break things, I do compression tests all the time.
Engine temperature can make a difference, by my tests, of perhaps 5-10psi. A larger difference can come from battery voltage. Most shops remove the battery as it makes it easier to get to the plugs. Some people slide the battery back in place and hook it up to spin the motor,while others use a jump box or jumper cables.
In my experience, if I use jumper cables (so no battery in the car) the voltage drop across a 6 foot cable makes the starting RPMs about 100 lower, which results in compression numbers that are consistently at least 10psi less.
Some shops will test the passenger side first, then remove the battery, so the drivers side reads less. Others don’t run long enough to get a good reading. Others don’t put a charger on the battery and the voltage lowers by the time you get to the last cylinder.
Oh and my gauge at home reads about 6psi less then the one at the shop.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
help with compression test results streetrcer909 New England Impreza Club Forum -- NESIC 5 04-03-2009 12:08 AM
new to boxers. help with compression test wildacex187 Newbies & FAQs 19 02-27-2007 11:03 PM
compression test results, help analyze? Toahk Normally Aspirated Powertrain 25 12-28-2006 06:37 PM
Help me diagnose my compression test results cwepruk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 12-24-2006 03:55 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
