Old 04-15-2002, 01:35 PM   #1
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Default piston/rod/crank help for my frankenstein
Fisrt off... will these parts fit together?
Phase II 2.5 block
'91 Turbo Legacy Crank
'91 Turbo Legacy Rods
Paeco pistons
And if so...
I know the stroke for the Legacy Turbo is a bit shorter than the 2.5... can that slack be compensated by some custom piston work? Otherwise the compression ratio will be way too low. I want the CR to be at about 9.0:1.
Thanks!
Chuck is offline   Reply With Quote
Old 04-15-2002, 04:07 PM   #2
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
I did some measurements on a 2.2L Legacy block the other day. It's 97mm like my EJ25. The extra displacement seems to come from the stroke. The 2.5L crank would definitely not clear the 2.2 block. Now, you're going the other way, it would probably clear, but would yield a compression ratio way too low for what you're looking for.
Why not stick with the EJ25 crank with lower-compression, lighter weight pistons? 9:1 should be easily feasible.
(And while you've got it open, dig up a set of corillo rods )
Really_Soaked is offline   Reply With Quote
Old 04-15-2002, 04:25 PM   #3
Happy
Member#: 12115
RS,
I think you'll find that the EJ25 is closer to 100mm bore. I also think that you'll find, that with a bit of work, the EJ25 crank will fit the EJ20/22. Most of stroker stroker kits use the EJ25 crank, with some using an even longer stroke crank.
Chuck,
If you've got a VERY GOOD engine builder, the phase 1 EJ20 crank can be made to fit into the phase 2 block, but it's not ideal. I would go for either a phase 2 EJ20, or EJ25 crank.
I agree with RS about junking the rods too. Any good piston manufacturer will be able to make a set of suitable custom pistons. Or speak to Trey Cobb.
Happy.
Happy is offline   Reply With Quote
Old 04-15-2002, 11:14 PM   #4
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
I am wondering why you want to use T Legacy crank and rods? They are NOT forged like some want to believe. The cranks main bearings are different sizes on Phase II, but the block can be machined. Why bother doing extra machine work when its really not nessasary. I think the 2.5l crank will spin no problem in 2.2l block. I will try it and get back to you
Scoobie Steve is offline   Reply With Quote
Old 04-16-2002, 01:01 AM   #5
XT6Wagon
Member#: 524
04 STi
I'd use the EJ-25 crank, custom EJ-25 rods, and pistons.
The EJ-25 bottom end will spin to 8,500 easy, while the top end will definitly need some work to reach that.
I'd only use the EJ-20 crank for a 10K rpm motor.
XT6Wagon is offline   Reply With Quote
Old 04-16-2002, 01:44 AM   #6
inpreza kid
Member#: 3334
if you want to go all out, why not get a set of sti heads too. built up low compression ej25 bottom end with sti ej20 heads. can spin 8000-9000rpm.
inpreza kid is offline   Reply With Quote
Old 04-16-2002, 09:51 AM   #7
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
OK... I guess I was under the same misinformation about the parts being forged.
I was already planning on new pistons, but the cost of rods is a bit astonomical, from what I've found. If it comes to paying about $100 each, that would be do-able. But $570 each.... there's just no way.
Can anyone recommend some decent rods in the $100 range?
Old 04-16-2002, 10:00 AM   #8
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Mine were around $750 for the set of Carrillo rods.
Old 04-16-2002, 10:19 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Chuck - $570 each? Most places have them for about $200-$250 each... even if you custom make them, I believe.
Really_Soaked - Where did you get Carrillo rods for $750? Best I've seen is a dealer account for just over $900 for the set.
Old 04-16-2002, 10:42 AM   #10
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Well, I'm converting back from CDN prices. I got them some time ago and the exchange rate might have been different. Though I'm sure they were less than 900.
I got them locally through a performance engineering shop. They seem to have a relationship with Carrillo where they do some of their testing. If anyone is looking for rods I'm sure I could have them price them out again.
Old 04-16-2002, 11:35 AM   #11
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Heh... Yeah, Paeco's Titanium rods go for $570 each. That number just stuck in my head.
Since you guys seem to have done all of this already, I've got another question. Are there any bolts in the engine that require less than 25 ft/lbs of torque? I'm hoping I won't have to go out and buy another torque wrench.
Thanks!
Old 04-16-2002, 12:03 PM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Actually, in the head torqueing procedure, I think there is a section where you tighten the outer bolts to 12 ft.lbs. and the inner to 22 (25?). Other then that, anything that is looser then that can probably be hand-tightened with good judgement.
Old 04-16-2002, 04:38 PM   #13
XT6Wagon
Member#: 524
04 STi
Uhh, you NEED a torque wrench that is good down to 8 ft-lbs or so if you plan on ever working on a AL motor. I've even encountered places where you need to only run 10ft-lbs instead of the reccomended 12ft-lbs because the AL gets a little weak over the heat cycles, and the spec was written on a fresh motor.
Old 04-16-2002, 04:45 PM   #14
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Hmmm... that's what I figured, I was just hoping. Off to ebay I go.
Thanks!
Old 04-16-2002, 05:02 PM   #15
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
If you can wait a week or two, try www.harborfreight.com - they usually have real cheap tools that work pretty well. I haven't had any problems with my 1/2" torque wrench just yet.
XT6Wagon - I'm going to kick myself for asking, but... AL?
Old 04-16-2002, 05:21 PM   #16
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
8- AL= Aluminum.
XT6 Wagon knows his periodic table.
tcs007 is online now   Reply With Quote
Old 04-16-2002, 05:43 PM   #17
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Doh! I knew I'd kick myself for asking.
Fs: pistons, rods, crank turbotimein253 NWIC Private Classifieds 7 08-20-2009 11:04 AM
Pistons / Main Rod Bearing Help for Subaru Impreaza WRX STI GC8 (1999 Mdel JDM) viraju Built Motor Discussion 36 08-03-2009 02:36 AM
EJ205 Pistons, Rods, Crank cooleys04 Engine/Power/Exhaust 28 04-17-2009 11:07 AM
FS: STI Parts! Bare Block, Pistons, Rods, Crank, Injectors makalu Engine/Power/Exhaust 6 10-02-2008 07:35 AM
WTB: Looking for upgrade Pistons, Rods, Crank. Hotrodguru Private 'Wanted' Classifieds 1 04-13-2004 11:53 PM
