Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 04-02-2009, 11:44 PM   #1
mostasz
Member#: 170512
2012 WRX
Ice Silver
Default Washed engine, had oil pressure light kind'a on...
I washed engine today, sprayed with degreaser, waited, rinsed off...
Started engine, and had oil pressure light on, but very dimmed. I let engine idle for few minutes, and then drove it for few miles to dry everything off.
Light went completely off after maybe 4 miles...
I think it was just water messing electrical connection on sensor.
Did it happen to anybody?
By the way: how is oil pump driven in 2.0 subaru?
mostasz is offline   Reply With Quote
Old 04-02-2009, 11:46 PM   #2
darksc00by
Member#: 102140
2015 yoga pants
creepin' is life
timing belt/crankshaft. there is a sprocket on the crank in front of the timing belt that comes off the crankshaft.
bad news could be in your future if that light came on for the right reason. I think it comes on when it detects 2psi, which is not enough for your bearings to survive long.
darksc00by is offline   Reply With Quote
Old 04-03-2009, 12:29 AM   #3
mostasz
Member#: 170512
2012 WRX
Ice Silver
Cool, so there's no freaking way the belt has slipped, and oil pump was not working efficiently. cause if so, my valves would be already kissing pistons.
I'm sure it was some moisture caused short/electrical issue.
Old 04-03-2009, 01:05 AM   #4
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Happend to me once after washing the engine bay, about 40k ago. Surprised me to, the light was very dim and went away after awhile. I sprayed/washed my bay at least 10 times to date. I wouldn't sweat it.
rexman2002 is offline   Reply With Quote
Old 04-03-2009, 06:29 AM   #5
mostasz
Member#: 170512
2012 WRX
Ice Silver
Cool, good to know
Old 04-03-2009, 07:08 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The light is an LED and does not require much current to illuminate visibly. If enough conductive liquid gets on the sensor connections this can happen.
Old 04-03-2009, 07:38 AM   #7
CynicX
Member#: 48199
06 WRX
This guy knows what he is talking about....
The sender for the oil pressure light is under the alternator on its left side. Take a flash light and look at it. Its a normally closed switch that opens on +/- >5psi. So disconnecting the wire from the sender will turn the light off permanently, touching it too the block (ground) will turn the light on...
I think you fine, just watch your oil level to be safe....
CynicX is offline   Reply With Quote
Old 04-03-2009, 09:17 AM   #8
Mr.Sparkle
Member#: 83725
Happens to me from time to time. Not a big deal as my engine has 140k on it now.
Mr.Sparkle is offline   Reply With Quote
Old 04-03-2009, 09:24 AM   #9
ChronoX720
Member#: 184105
2015 WRB WRX Limited
Still Unamused
And that sir, is thinking outside the box
That answer makes the most sense
ChronoX720 is offline   Reply With Quote
Old 04-03-2009, 10:01 AM   #10
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Mulder is the man!
Im too scared to degrease my engine bay. Steam Clean any better?
JoeSUBARU is offline   Reply With Quote
Old 04-03-2009, 11:51 AM   #11
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
^same here. I've seen it done but never tried it. I've seen guys at the do-it yourself wash bays pressure washing their engines.
trueno16v is offline   Reply With Quote
Old 04-03-2009, 12:03 PM   #12
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
If you ask me using degreeser is a better option than a pressure washer. Blasting your engine bay w/ a pressure washer can drive water into places it shouldnt be. Getting it wet is no problem. I use degresser and a hose on a low to medium setting.
181stLeader is offline   Reply With Quote
Old 04-03-2009, 02:24 PM   #13
mostasz
Member#: 170512
2012 WRX
Ice Silver
That's what I did, except not high pressure wash... I used king of "idle" of pressure washer. It was strong enough to do the job.
oil pressure light turned on after going threw a puddle greco2030 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-14-2011 12:17 AM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-05-2010 03:25 PM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Electrical & Lighting 1 02-14-2010 12:58 AM
Oil pressure light comes on for a split second WS6toWRX Service & Maintenance 12 02-06-2004 02:47 PM
Oil pressure light on, need opinions Keiho Normally Aspirated Powertrain 12 02-24-2001 07:08 PM
