Old 04-03-2009, 01:13 AM   #1
STIBungy
Member#: 51684
Default Cylinder Roughness (Misfire) Prior to Being Broken In?
I just got my built 04 STI running and did some datalogging while I worked on a good basemap for it. In datalogging, I turned on cylinder roughness in all 4 cylinders and it picked up counts in all 4 cylinders. The datalogger is Romraider. Is this normal since the motor has yet to be broken in?
Here's a list of my motor mods:
Wiseco pistons
Helix rods
BC valve springs and retainers
Cometic head gasket
BC 272 cams
Exedy twin disc clutch
modded 07 STI injectors (1000cc)
topfeed TGVs
Agency Power fuel rails
Aeromotive FPR (38psi)
Gruppe-S equal length header
Perrin GT3076R turbo kit
STIBungy is offline   Reply With Quote
Old 04-03-2009, 11:37 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I've seen it in a broken in engine which was perfectly fine. I've also used it in the past to diagnose broken ringlands which is not the case with you. I would bet it's just picking up piston slap
mick_the_ginge is offline   Reply With Quote
Old 04-03-2009, 01:48 PM   #3
flycaster
Member#: 60142
2011 WRX
Grey
So you think piston slap might cause this? I didn't realize that cold slap would have that much influence on the crank sensor, but with the slugs initially wobbling around I guess that makes some sense...
flycaster is offline   Reply With Quote
fs socal: used clutch master cylinder sti 04, needs to be rebuilt. cheap price 949 SCIC Private Classifieds 2 10-06-2009 12:52 PM
Off-road MINI will be the first of the brand to be built in the US. NYCshopper Non-Subaru News & Rumors 6 11-28-2007 12:22 PM
Do glowsticks have to stay in the wrapper prior to being activated? Sephro Off-Topic 19 08-23-2007 01:59 AM
How to be clowned in public by a mom or how not to act in court... Janq Off-Topic 115 06-17-2006 03:55 PM
Subaru found my downpipe to be broken only problem? you tell me WRC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 10-21-2002 03:12 PM
