Old 04-03-2009, 12:39 AM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default ej22 phase I head gasket vrs phase II
is the head gasket on the ej22 phase I the same as the phase II? thanx a lot, cheers
alejo is offline   Reply With Quote
Old 04-03-2009, 07:05 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
There may be a slight difference in the size of a coolant passage, but otherwise, they are the same.
Jay
Old 04-03-2009, 11:02 AM   #3
alejo
Member#: 170081
2004 2.5RS
blue
that means I can usea the phase I head gasket on my phase II?
Old 04-03-2009, 12:59 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yes. I've done it many times.
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
EJ22 phase 2 heads on phase 1 block WoodsWagon Built Motor Discussion 5 11-07-2011 05:54 PM
Head Gasket on Phase 2 engines cardin555 Legacy Forum 19 01-13-2003 10:34 AM
Phase I heads on Phase II block? Don Normally Aspirated Powertrain 38 07-16-2001 12:15 AM
Ralli Spec says I have a Phase II block with Phase I heads? Have you investigated? MY99 2.5GT Legacy Forum 3 05-22-2001 12:17 AM
Message Board Statistics All times are GMT -4. The time now is 04:22 PM.
