Old 04-03-2009, 10:22 AM   #1
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
Question Will my 2006 WRX ECU control an EJ257 longblock?
I searched, but could not find the answer.
Will a 2006 WRX ECU safely control an STi engine?
Thanks!
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 04-03-2009, 11:31 AM   #2
Member#: 82064
2011 sti & evo ix
white
sure it will if its tuned
Ray@revitup is offline   Reply With Quote
Old 04-03-2009, 02:17 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
Thanks!
sotc
Yes, ej255 and ej257 = same engine except pistons.
Tossing the ej257 onto your 2006 wrx (i'm assuming) will raise the compression.
So have it retuned.
Nuke209 is offline   Reply With Quote
Old 04-03-2009, 03:09 PM   #4
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
So have it retuned.
ej257 has lower compression. the compression ratio on the 255 is 8.4-1. the compression on the 257 is 8.2-1.
different pistons, different crank, different cams, different heads, they are not the same motor
ronzogonzo is offline   Reply With Quote
Old 04-03-2009, 04:10 PM   #5
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Here we go......
Team Scream is offline   Reply With Quote
Old 04-03-2009, 07:56 PM   #6
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Yes with a retune and the right sensor placements. The wrx heads only have 1 Cam sensor while STI has 2 and the placement is a little bit different. You can buy a bracket to compensate for this and then run the sti longblock. also, plug up the avcs oil holes since the wrx ecu has no control for this.
Fongers is offline   Reply With Quote
Old 04-03-2009, 08:28 PM   #7
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
I thought my 06 2.5L had AVCS?
sotc
Old 04-03-2009, 09:16 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
same rods, same block, same valvetrain/cams, same avcs cams.
different head casting with combustion chamber, different pistons different avcs lines
More importantly, what year EJ257?
FuJi K is offline   Reply With Quote
Old 04-03-2009, 10:46 PM   #9
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
06 wrx = avcs
godforbid67 is offline   Reply With Quote
Old 04-04-2009, 01:41 PM   #10
Nuke209
Member#: 108089
2003 WRX
NF Performance
yes, but the combustion chambers are different in the sti heads.
So are the pistons.
Find the thread about the ej255 & ej257 difference, sponaugle posted some great info.
Old 04-04-2009, 02:30 PM   #11
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
The shortblock is a brand-new 2004.
Have not bought the heads yet, but I'm looking for '06 heads.
I want to keep the stock engine intact, and build a badass STi engine.
I'm not against using WRX 06 heads, but I would prefer the lower compression of the STi engine and NOT the raised comp of the WRX heads/STi block.
Also, I want better flow without machine work.
I'm not looking for physical differences, but whether the 2006 WRX ECU is fully able to control the 2006 STi motor.
It'd be way easier, I suppose, to drop WRX forged pistons in the block and have a set of 'o6 WRX heads machined to flow better.
I'd really like the STi motor, as I've found very good prices on pistons and heads for that particular app.
SOTC
Old 04-04-2009, 02:49 PM   #12
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
To my knowledge the ecu will work, but you ought to check the pinouts in the corresponding manuals to verify that all the sensors and controls have the same voltage ranges since there's a 2 year gap on the equipment.
Does anyone make forged WRX pistons? Aside from a custom set, all I've found were 257 pistons listed as 257/255. That is, less dish volume than the actual 255, so you'll end up with an even higher CR running on WRX heads as you said, 8.7:1 range.
Also, I've read that the 255's combustion chamber is slightly more insensitive to the tuning strategy used than the 257's. I don't have a link, but it was in PPB.
I really wish people would stop talking out of their ass about these motors. If you don't know for sure, don't spread misinformation. The facts are here: http://forums.nasioc.com/forums/show....php?t=1667168 There's a link to Sponaugle's thread in there as well. Someone really should sticky that.
Merp is offline   Reply With Quote
Old 04-04-2009, 02:54 PM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
Originally Posted by Merp View Post
To my knowledge the ecu will work, but you ought to check the pinouts in the corresponding manuals to verify that all the sensors and controls have the same voltage ranges.
+1
Old 04-04-2009, 05:01 PM   #14
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
Beginning to agree, only 257 pistons. Sounds dangerous.
I'd REALLY like to run a full STi motor, complete with the 07 heads.
Merp, I appreciate your answer!
SOTC
Old 04-04-2009, 07:06 PM   #15
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Yes, your ECU will control the EJ257 based engine just fine, as long as you are talking about an 04-07 STI longblock.
Clearly it would not work with the dual AVCS 08.
There are a few minor things you need to consider however. If my memory serves me right, the 06 WRX 2.5s has the air pump. If you get an STI EJ257 long block, it will not have the air pump or support for it (the head casting)..
Simple to disable the codes of course, but just so you are aware.
Other then the smog pump, the control mechanisms are the same. Obviously you will have to get a tune.
Jeff
sponaugle is offline   Reply With Quote
Old 04-05-2009, 02:23 AM   #16
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
Talking
Jeff
Thank you!
Yes, I have the air pump. Not for long, though.
Oh, and I won't just be getting a "tune."
I'll be coming to Surgeline for a tune.
SOTC
Old 04-05-2009, 10:08 AM   #17
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Thank you somebody for not posted wrong info. The 06+ wrx motors are not all that different from sti. If you think otherwise your of in fairyland or something. Thank you merp for posting correct info.
talvai is offline   Reply With Quote
Old 04-05-2009, 10:42 AM   #18
mls1
Member#: 167607
2008 WRX
Originally Posted by Team Scream View Post
Here we go......
FUNNY ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
mls1 is offline   Reply With Quote
Will 2006 STI suspension fit on my 2006 wrx? COBOMO Brakes, Steering & Suspension 2 01-27-2010 01:27 AM
Will the 2006 STI Rear Underbody Diffuser direct bolt to my 2006 WRX? jay25RS Interior & Exterior Modification 24 11-01-2007 11:37 PM
Where to get an EJ257 Longblock?? Ghost Rider Tri-State Area Forum 16 06-22-2007 08:56 PM
noob-ish question: What sti motors will 05 wrx ecu control? saab-on-the-cobb Engine Management & Tuning 7 09-06-2006 03:19 PM
will a 04 WRX ecu work in an 05? GT40R Engine Management & Tuning 1 09-04-2006 01:29 PM
