Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 04-03-2009, 07:39 PM   #1
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
Default Questions about o2 sensors!! help :)
ok, i need your help here
what is the difference between 05 2.5rs o2 sensors and 06/07 2.5i o2 sensors?
i ain't paying no $218.00 for a new rear o2 sensor, where as i can get a universal type FRONT o2 sensor from a 05 2.5rs for $58.00....
Vizzionz is offline   Reply With Quote
Old 04-03-2009, 10:45 PM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Universals tend to bonk out faster. You can definitely give it a shot.
There is a difference between 05 and 06/7 sensors though. I believe it might have to do with the change in exhaust design.
formula91 is offline   Reply With Quote
Old 04-04-2009, 01:15 AM   #3
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
the only difference i have seen is that the 06-07 has about a 2" washer on both sensors.
subiidude is offline   Reply With Quote
Old 04-04-2009, 06:14 AM   #4
Vizzionz
Member#: 139109
2007 Impreza 2.5i
i'm only at 32K and alreay killed my front o2 sensor with a "low votage" code. wanted to try the 05 2.5rs sensor since it was cheap to see if my low votage CEL went away...
Old 04-04-2009, 07:19 AM   #5
piker28
Member#: 22664
Those universal ones tend to really suck
piker28 is offline   Reply With Quote
Old 04-04-2009, 07:54 AM   #6
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Warranty?
Burnout is offline   Reply With Quote
Old 04-04-2009, 10:04 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
i ain't paying no $218.00 for a new rear o2 sensor, where as i can get a universal type rear o2 sensor from a 05 2.5rs for $58.00....
So let me see if I follow here. You killed your front sensor so your fix is to try and replace the rear sensor? You're stupider than I thought.
Old 04-04-2009, 12:32 PM   #8
Vizzionz
Member#: 139109
2007 Impreza 2.5i
i meant the front, not the rear. thank you for pointing out the typing mistake
Old 04-04-2009, 12:35 PM   #9
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Originally Posted by Burnout View Post
Warranty?
One word "modified".....I'll let you figure it out...
Old 04-04-2009, 05:26 PM   #10
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Ok, so the o2 sensors (front & rear) from a 2.5rs should work on a 2.5i?
Old 04-04-2009, 05:52 PM   #11
subiidude
Member#: 141472
2008 shagg wgn STI
yes i know for sure that the o2 sensors from an 04-05rs will work with the 06-07 2.5i
Old 04-04-2009, 06:21 PM   #12
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Thank you!
Turbo XS Race Pipe, question about o2 sensor... wirolla Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-12-2006 12:10 AM
Question about o2 sensor impreza97 Engine Management & Tuning 5 02-01-2006 09:35 PM
Quick Question about o2 sensors Trademark Tri-State Area Forum 10 12-14-2005 06:33 AM
Question about O2 Sensor and Hi-Flo Cat jtemplin Normally Aspirated Powertrain 4 12-24-2004 03:48 AM
('93-'01) Question about O2 sensor sub25rs Impreza Forum 2 05-11-2001 12:02 AM
