Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
View Poll Results: miles on built motor?
5,000-10,000 49 33.56%
10,000-20,000 35 23.97%
20,000-30,000 11 7.53%
30,000+ 51 34.93%
Voters: 146. You may not vote on this poll
Old 10-10-2009, 10:36 AM   #51
subyguy21
Member#: 222612
04 GD EFR
Dang where is the zero's or the 0-1000 one...ill be putting my first mile on today :-)))
subyguy21 is offline   Reply With Quote
Old 10-10-2009, 10:49 AM   #52
jays05
Member#: 78165
05 STI 35r + e85
Originally Posted by jays05 View Post
I have around 4k miles on my rebuilt rebuilt rebuilt 2.5L... more than half of those miles with 500whp+ on tap. 540@23-24psi on 93, 61x@26-28psi on c16.
cp 100mm pistons + swaintech skirts
pauter rods
stock crank
stock sleeves
headwork+cams/valvetrain
35r+huge fmic
It's the same motor I had that broke a camshaft in half @ 6k miles and a blown hg 2k miles later. The block was rehoned, heads resurfaced, one piston was replaced, all four pistons had the skirts coated, new rings, one rod had the small end bushing "fixed", the crank was machined for undersize main bearings, and that's about it besides new headstuds, gaskets, bearings, t-belt/tensioner, and little things. The heads were in great shape after all the problems and I was very happy about that.
My built motor was 100% destroyed a couple weeks and a couple hundred miles after I posted this. Three valves dropped into cyl #4. All the rod bearings had excessive wear on the outside edges of the shell, while the middle was like new... and the sides of the rods had wear from hitting the crank. Ron@raw1 turned into a dick, blamed the installer/tuner, and completely forgot about my motor at one point while he had it apart. When I got the parts back we found mega side clearence on the rods, but that's not why the valves dropped.
jays05 is offline   Reply With Quote
Old 10-10-2009, 11:06 AM   #53
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
9k on motor, going to get a compression test done to ensure everything is still good to go.
j255c is offline   Reply With Quote
Old 12-02-2009, 05:48 PM   #54
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
any updates on your built blocks?
06-wrx-tr is offline   Reply With Quote
Old 12-02-2009, 05:58 PM   #55
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
I've got about 220 miles on mine. I hope it lasts....*crosses fingers*
cooleys04 is offline   Reply With Quote
Old 12-02-2009, 06:05 PM   #56
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
51,000+ miles and growing by at least 70 miles per day! Just made 464whp on 20psi pump gas too.
RealStreet is offline   Reply With Quote
Old 12-02-2009, 07:35 PM   #57
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Why are these motors such a gamble?
There are people in this thread who have had failure after the motor was built by a reputable builder...others have had theirs slapped together in their home garage and lasted 40k.
What's up?
CKxx is offline   Reply With Quote
Old 12-03-2009, 01:19 PM   #58
R4ND0M_AX3
Member#: 67483
2005 WRX STi
A tad over 50K on my cobb block w/ coated pistons and rod bearings.
Burns oil now.
Compression is low but even.
Daily driven.
I might re-ring it or just replace it with a new built setup in the next 10-20K.
R4ND0M_AX3 is offline   Reply With Quote
Old 12-03-2009, 02:14 PM   #59
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
Care to share whats in the block and specs on clearances?
cellgeek101 is offline   Reply With Quote
Old 12-03-2009, 03:22 PM   #60
RealStreet
Member#: 205916
2003 Subaru WRX
It's over 2 years old so I can't remember the exact clearances.
It's just a basic build; Hone, stock bore CP's 8.2:1 CR, Manley I Beams, cosworth race bearings, ARP studs, and stock headgaskets.
Old 12-03-2009, 03:28 PM   #61
CKxx
Member#: 33458
93 RX7+09 Forester
Burns oil now.
Daily driven.
Same here. My older COBB block has taken a beating. Whoever built their motors apparently did a pretty good job.
Old 12-04-2009, 11:14 AM   #62
cellgeek101
Member#: 143941
04 STI JBP
Thank you....BTW...what turbo where u using to get to that HP on 20PSI on pump gas?
Old 12-04-2009, 11:38 AM   #63
R4ND0M_AX3
Member#: 67483
2005 WRX STi
I think it was Jeremy. I just wish they still built them.
Old 12-04-2009, 12:03 PM   #64
Turbo_Mike
Member#: 130276
2004 Pontiac GTO
LS1 T56 RWD
What's up?
lolol
These are complicated motors, theres a lot to go wrong, but if its built correctly, the tune on break in is 99% of it from my experience.
Turbo_Mike is offline   Reply With Quote
Old 12-04-2009, 01:00 PM   #65
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I just rolled 3100. 2000 miles of those miles were very hard. I have no idea how long she will last, but quite frankly im surprised it made it this far.
I want 60k, that my goal. What sux is I blew the trans in my kia beater.... Those 3100 were put on the motor in the last month........
STi Mikey is offline   Reply With Quote
Old 12-04-2009, 01:20 PM   #66
RealStreet
Member#: 205916
2003 Subaru WRX
Precision's Billet 6765 http://realstreetperformance.com/sto...00hp-1311.html
Old 12-04-2009, 01:45 PM   #67
Built Industries
Member#: 33839
A few years back....... Manley I beam rods, Mahle pistons, .020" over - ran the motor over 450 WHP for 20k before I sold the car. That was a few years back, last I heard owner had 60k on it.
PTE billet turbo - and Manley rods... MMMM, MMMM Good.
Built Industries is offline   Reply With Quote
Old 12-12-2009, 01:59 AM   #68
autocannon05
Member#: 136232
04 STI
turtles
have about 12,900 miles on my motor built by real street performance.
100mm cp pistons
manley h beam rods
acl race bearings
arp studs
stock gaskets
autocannon05 is offline   Reply With Quote
Old 12-12-2009, 07:19 AM   #69
cbourbs
Member#: 117749
bought a stage 3 motor from axis. bad motor right off the get go. Burning 1 quart every 80 miles. yes 80 miles. compression test 100 across the board and leakdowns of 25ish and 2 cylinder and 40 ish on the others.Tried to get warranty work. John at axis blammed it on the install. Said if i wanted to take the motor out and pay for that, then pay to ship it, he would fix it at cost....LOL...what a joke!!! In my opinion go with cosworth and be done with it!! Heard nothing but good thing with cosworth and they last longer then other blocks because of tighter clearances.
cbourbs is offline   Reply With Quote
Old 12-12-2009, 02:05 PM   #70
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Damn, that sucks.
However, the lesson I see from that is to have the motor built, installed, and tuned at the same shop. That way the builder and tuner and installer can't all blame each other and walk away if **** happens. If that same shop installed a Cosworth engine and you ended up burning oil and making crap compression, you'd be in exactly the same situation.
Old 12-12-2009, 07:33 PM   #71
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
about 1k for the last 2 mos on my built longblock. p&l is still trying to figure out why an apt35r (stock loc) is only making around 330whp and falling flat on its face around 5500rpm.
Danomite is offline   Reply With Quote
Old 12-13-2009, 02:51 AM   #72
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
mine has 1300 miles, damm quite even on cold startup, no oil consumption.
dan az is offline   Reply With Quote
Old 12-13-2009, 03:35 AM   #73
STimo
Member#: 110273
450 whp 30R STI
11.3@123, 10's a commin'
That really sucks, sorry to hear that i hate hearing about things like this.. People spend all this money to get things done THE RIGHT WAY and most shops nowadays are just after your money and how fast they can get it done, not worrying about making sure its done and measured correctly.. Again sorry to hear that, he lost my business.. I was DEAD SET on going with a block from Ron after all the good things i had heard, and called and talked to him even and he seemed like a good guy, but lately ive been reading about nothing but failed motors by him, its not all done by the same tuner and this is just too much IMO for it to be coincidence so i went with a local shop instead and they got it together nice a quick, not in the car yet though so we'll see how she does when it gets some boost thrown at it.. Its Closed deck with full forgd internals, race bearings, etc. so hopefully it holds up good..
STimo is offline   Reply With Quote
Old 12-13-2009, 01:51 PM   #74
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
These poll numbers are disturbing.
hybrid gti 2 is online now   Reply With Quote
Old 12-13-2009, 02:14 PM   #75
NSFW
Member#: 140444
05 Stage Free LGT
Not if you read the poll question as "how many miles on your built motor so far?"
It might be interesting to do a different poll on a different question: "how many miles on your built motor before it popped?"
How many miles on your car? NYCPimP Tri-State Area Forum 65 03-01-2002 06:02 PM
('93-'01) how many miles on your subbie! ellinopedo182 Impreza Forum 118 11-05-2001 07:39 AM
How many miles on your WRX? psoper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-20-2001 05:53 PM
poll: How many miles on your car? Scooby-Z General Forum Archive 64 02-04-2001 12:49 AM
