Welcome to the North American Subaru Impreza Owners Club Tuesday July 29, 2014
View Poll Results: miles on built motor?
5,000-10,000 49 33.56%
10,000-20,000 35 23.97%
20,000-30,000 11 7.53%
30,000+ 51 34.93%
Voters: 146. You may not vote on this poll
Old 09-28-2010, 12:16 PM   #101
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
ive got 14K 10-15% leak down 140's all way around
Rexxyou is offline   Reply With Quote
Old 09-28-2010, 12:17 PM   #102
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Innovative Tuning (over-)built my setup and I expect it'll outlast the stock engine (80K+ miles).
14K miles so far...
Spenk is offline   Reply With Quote
Old 09-28-2010, 12:51 PM   #103
CatfaceType-R
Member#: 81102
^^good luck with that mate
CatfaceType-R is offline   Reply With Quote
Old 09-28-2010, 02:53 PM   #104
Spenk
Member#: 7164
2000 Miata LS
Thanks! *kisses*
Old 09-29-2010, 12:29 PM   #105
CatfaceType-R
Member#: 81102
lol, as this page says..50k is probably what u should expect
Old 09-30-2010, 04:42 PM   #106
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
Originally Posted by Spenk View Post
Thanks! *kisses*
LOL
BuggeyEYED is offline   Reply With Quote
Old 09-30-2010, 09:46 PM   #107
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
2.5L Hybrid....25k on RAW Street Series 257 with 2.0 heads, Crower 264 cams/springs/retainers.
Running strong.
rainwrx is offline   Reply With Quote
Old 09-30-2010, 10:01 PM   #108
manjambles
Member#: 205643
2005 forged goodness
80 miles with new 2010 crank and forged internals
manjambles is offline   Reply With Quote
Old 10-02-2010, 05:49 PM   #109
scurabus
Member#: 178158
0002 ppg'd wrx / gc
stm/wrb
I have 12k with je pistons and acl race bearings, the rest stock on ej205 (daily driven). This is the first subaru engine my friend ever built. Still runs strong but would rather stay away from compression/leakdown tests to avoid any possible dismay or anxiety. My next route, I will be going with a new factory shortblock. Financially I cannot deal with the thought of hoping for 40-50k at best before needing another rebuild. It seems a built motor is for the guys wanting a lot of power along with the ability to beat the hell out of the motor without desiring/needing longevity.
scurabus is offline   Reply With Quote
Old 10-04-2010, 12:43 AM   #110
sts2689
Member#: 145708
2007 WRX TR
TopSpeed Built =D
Right at 2k on my TopSpeed built block, hasnt burned a drop of oil since I picked her up*knock on wood*, and beats most stuff on the road.......on the break in tune
sts2689 is offline   Reply With Quote
Old 10-07-2010, 01:27 AM   #111
shagwag
Member#: 196981
2005 wrx sti
CGM
roughly 12000 total. 9000 at 300whp, 3000 at 400whp. now obviously i wasnt WOT for all those miles but probably about 30% of them i was. 7800 redline and i hit it a lot. built the block my self with eagle rods, wiseco pistons, acl bearings, and i have an 11mm pump installed. block is healthy and makes great power piston slap is really annoying until it gets hot. i really do beat the crap out of it and it has lasted, so has my 30r . yesssss
shagwag is offline   Reply With Quote
Old 04-04-2012, 04:22 PM   #112
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
Bump. How many miles now boys?
06-wrx-tr is offline   Reply With Quote
Old 04-04-2012, 05:13 PM   #113
Ryan314
Member#: 82989
Hybrid VF22
9k on my hybrid block
Ryan314 is offline   Reply With Quote
Old 04-04-2012, 05:40 PM   #114
Juks
Member#: 108163
2005 STI - 10.2@137
15k on my STI - 99.75mm CP pistons/Eagle rods, 400+ & burns oil from crappy break-in but I'm used to it. Still fun as hell to drive!
~3,500 on my WRX - drop in Mahle pistons/STI rods, 300+ & barely burns a drop!
Juks is offline   Reply With Quote
Old 04-07-2012, 04:03 PM   #115
pearlSubie21
Member#: 185575
2007 wrx 351whp368tq
pearl white
What do you mean crappy break in?
pearlSubie21 is offline   Reply With Quote
Old 04-07-2012, 07:48 PM   #116
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
Running strong.
40,000 miles and still running strong. Uses a little oil -- about 1 qt. every 2k miles under normal driving. A bit more when pushing it hard or on long highway trips.
Old 04-08-2012, 03:33 PM   #117
apexslider
Member#: 168101
15 STi LE
6300 miles...and dead. Spun a rod for sure, won't the rest until I get the motor apart next weekend.
Build:
Custom Arais pistons 8.2:1
Eagle rods
Factory bore and stroke
Factory crank
Oil passages machined
Tolerance evened between mains
Factory heads
BC 280 cams
BC springs/retainers
Factory valves
Cosworth manifold/TGV's
Perrin GT3563 rotated kit
DW 300+FP
DW 1300 injectors
Aeromotive rails
Aeromotive FPR
SD tune (no MAF)
Car was making 421awhp on pump gas and 502awhp on C16
Not sure what caused the motor to go. I wasn't in boost when it let go but was on the freeway and couldn't get over fast enough to shut her down. Oil pressure and temp were solid...real curious to get the motor apart.
apexslider is offline   Reply With Quote
Old 04-08-2012, 07:55 PM   #118
bhhamblin
n00b Moderator
Member#: 99397
13 STI, 83 DR30
93 R32 GTS-T, 93 R32 GTR
I just hit 50k miles on my Rallispec shortblock in my 2008 STi, the car is just stage 2 but the engine has been awesome, doesn't burn oil, no noises other than normal built motor noise. Leak down test shows less than 3% in all 4.
Happy Rallispec customer.
bhhamblin is offline   Reply With Quote
Old 04-08-2012, 08:21 PM   #119
pearlSubie21
Member#: 185575
pearl white
How much whp did the car make?
Old 04-10-2012, 12:54 AM   #120
WRXBeatsTheBest
Member#: 311725
2010 Impreza 2.5i
Obsidian Black
Like most things, it really depends how you treat it. Of course, if you go through the effort you're probably going to drive it hard. Around 50k is a good estimate
WRXBeatsTheBest is offline   Reply With Quote
Old 04-10-2012, 12:02 PM   #121
Juks
Member#: 108163
2005 STI - 10.2@137
I was having Tial BOV spring issues during the first 50-100 miles and the A/F ratio wasn't right (too light of spring and it was drawing air on vacuum w/pull through MAF), also didn't want to boost it while I was figuring this out, so it was rich and no load during the most critical break in miles.
At least I was able to apply that lesson learned to my WRX which broke in nicely with about 10psi for a few hundred miles before we finished tuning and then I just let her rip.
I know what method I'll use when we re-ring my STI...
Old 04-10-2012, 12:56 PM   #122
LBell05STI
Member#: 305890
2005 STI
Damn that sucks.. There was no way to park the car and wait for a new bov?
LBell05STI is offline   Reply With Quote
Old 04-10-2012, 03:45 PM   #123
cgmURABU5
Member#: 247543
2006 STi SGM
100k and rollin'
6500 miles and endless smiles from my built longblock.
cgmURABU5 is offline   Reply With Quote
Old 04-10-2012, 05:00 PM   #124
Juks
Member#: 108163
2005 STI - 10.2@137
Maybe, I was getting pressure to get it out of his garage, busy guy ya know. Hind sight is 20/20 on this one though, did't realize the implication it was going to have, and who knows, always more than one factor when it comes to oil consumption. All indications at the time were that it wasn't going to be a big deal. Define "big deal" I guess...runs great, very fast, just have to add some oil every other day. Next time will be even better.
Old 04-11-2012, 04:22 PM   #125
jesterjames
Member#: 252663
whats your breather setup look like?
jesterjames is offline   Reply With Quote
How many miles on your car? NYCPimP Tri-State Area Forum 65 03-01-2002 06:02 PM
('93-'01) how many miles on your subbie! ellinopedo182 Impreza Forum 118 11-05-2001 07:39 AM
How many miles on your WRX? psoper Factory 2.0L Turbo Powertrain 27 08-20-2001 05:53 PM
poll: How many miles on your car? Scooby-Z General Forum Archive 64 02-04-2001 12:49 AM
