View Poll Results: miles on built motor?
5,000-10,000 49 33.56%
10,000-20,000 35 23.97%
20,000-30,000 11 7.53%
30,000+ 51 34.93%
Voters: 146. You may not vote on this poll
Old 04-19-2012, 10:21 AM   #126
Cheese13
Member#: 272366
2003 Evo 8 gsr
Bby
700 miles on the new 257 block and heads.
mahle pistons, acl bearings, arp studs, nitrated crank
this tread is almost scary, after spending +4k in the last two months i was hoping for a little more reliability. unfortuntely i didnt do enough reading before build and had was too high expectations, hopefully this block/rings make it at least 30k, its a little noisy when cold but doesnt consume any oil thus far, my biggest concern being the piston to wall clearance
Cheese13 is offline   Reply With Quote
Old 04-19-2012, 08:54 PM   #127
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
63k on fully built motor, 330 to the wheels at 5000 ft on conservative map, super quite even when cold.
dan az is offline   Reply With Quote
Old 04-19-2012, 10:57 PM   #128
STi stroker 55
Member#: 263724
07 Subaru WRX STi
Fully built motor with stroker kit 2.7L 4,500miles so far. 430whp
STi stroker 55 is offline   Reply With Quote
Old 04-19-2012, 11:02 PM   #129
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
That sounds awesome. 330 at the elevation is a good amount of power for that duration. Care to share your build?
codesoccer is offline   Reply With Quote
Old 04-20-2012, 01:16 AM   #130
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
Originally Posted by scurabus View Post
I have 12k with je pistons and acl race bearings, the rest stock on ej205 (daily driven). This is the first subaru engine my friend ever built. Still runs strong but would rather stay away from compression/leakdown tests to avoid any possible dismay or anxiety. My next route, I will be going with a new factory shortblock. Financially I cannot deal with the thought of hoping for 40-50k at best before needing another rebuild. It seems a built motor is for the guys wanting a lot of power along with the ability to beat the hell out of the motor without desiring/needing longevity.
This is exactly where I'm at with my stock ej257. It has 92k miles and counting (DD) and I'm getting nervous that it's going to poop a ringland after reading all of the horror stories on here. Burns about a quart every 3k.
And on the 2nd bolded part, I agree too. Thing is, I think I'll move on once my car nears 140-160k miles, that's alot of mileage and I would much rather get a newer wrx/evo/whatever than just keep sinking money into this car. 50k miles is pretty damn good when you consider the power density of running a 4 banger north of 400whp, daily driven especially.
ByeBye4g63t is offline   Reply With Quote
Old 04-21-2012, 11:35 PM   #131
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
entirely built and tuned by me, 2.5 block, sti crank, acl bearings, tomei forged rods, arp rod bolts, JE forged pistons, cometic head gasket, heads ported by hand by me (combustion chambers are stock 2.0) bc valves, bc springs and retainers, tgv deletes, blouch 20g-xt turbo, FMIC, huge top mounted oil cooler with thermostatic sandwich adapter and thermostat controlled electric fan as well, sti oil pump, full exhaust, suspension stuff and brembos.
Old 04-22-2012, 03:50 PM   #132
Siclike7
Member#: 141329
Complete RAW performance 2.5L longblock. CPs, Pauter rods, ACL bearings, Ported heads, Kelford 276s, over sized, valves, ect, ect. On 17psi car made 400whp (kept low boost because the car still had the stock 5speed). Lasted a bit over 5,000 miles when it failed a leakdown test past the valves. No marks on pistons, or valves so were assuming they weren't true when the motor went together.
Also, the crank thrust was enormous. You could push the entire crank back and force enough to hear a *thud*. It ate the ACL bearings up and ruined the crank.
Car never got hot, ran Shell Rotella 15w40 the entire "life" of the motor.
5,000 miles. Five. Thousand. Miles.
Siclike7 is offline   Reply With Quote
Old 04-22-2012, 06:38 PM   #133
LNG
Member#: 128576
02 wrx
13000 on ralispec 2.1
LNG is offline   Reply With Quote
Old 10-05-2012, 06:44 AM   #134
scurabus
Member#: 178158
0002 ppg'd wrx / gc
stm/wrb
Now at roughly 34k daily driven since my last post at 12k. Sometimes a quart or so of oil will disappear every oil change (3k), sometimes it wont burn any... And I still have no desire to see leakdown compression results. Power seems to lack what it used to be or its probable thats all in my head. A built motor has been a good learning experience but until I have enough money to play, Ill be back to a stock block on the next one.
scurabus is offline   Reply With Quote
Old 10-05-2012, 07:20 AM   #135
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
15,000 miles on built bottom end, 99.5 cp pistons acl bearings stock rods. Around 500whp not a daily but driven enough. When driven it sees 7700 redline 50% of the time and still loving life built short block and tuned myself
02rex62 is offline   Reply With Quote
Old 10-05-2012, 09:08 AM   #136
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
2700 miles and counting on my closed deck stroker with all manley internals save from wiseco pistons and bc280's. 450hp at 25psi.
fastblueufo is offline   Reply With Quote
Old 10-05-2012, 11:29 PM   #137
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
This thread would be twice as useful if those of you who are getting good results would post the names of your builder, installer, and tuner.
Old 10-05-2012, 11:44 PM   #138
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
everyone needs to have the block honed and ring gap set with thick torque plates simulating distortion like the heads were on, also, most likely with the bearing clearances you will have to buy more then 1 (maybe 3, 1 sized under stock, stock size and 1 size over) set (sized) bearings to achieve everything coming out to the same, mix and match them all to get whatever you are going for (same for all or just about the same/ do your best), for me its going to be .0015 for the mains and .002 for the rods, and .0035 for the p/w , per team screams specs for my set-up
I had my expensive closed deck shortblock go with in less then 10k daily driven miles, due to (supposedly) bad valve job, and/or wrong valve guide seals (wrx on an sti) which this I dont understand because I thought wrx/sti valves were the same
fact is, if you are able to do it yourself or check it yourself, do so, if you would like peace of mind, offer to spend more with the builder to have you there at least to check over the clearances with you there to ensure what your paying for and what your driving, measuring tools can get pricey for nice stuff, im at over 650 and still have a few minor things to go
knowone is going to take the time doing all the work for a customer as they would for their own motor, thats why its all unfair, for the amount of work, I understand why most just whip it out and slap a 3k price tag, I mean 2250 in just parts for h beams and a new case, bearings, crank and pistons, used case subtract like 700,
to do it right, while measuring, everything needs to be torqued down, checked, taken apart, redone swapping the bearings back and forth if need be,( a BUNCH) of times until everything comes out to your desired specs, and until the read-outs are all consistant, I dont think that using these measuring tools is at all cake, it takes some practice to get it down
Irv Weissmanhowerton is offline   Reply With Quote
Old 10-06-2012, 01:55 AM   #139
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
Car blew ringland on cylinder 3 roughly a month after I posted this . Now has a built motor with 2700 miles, and it's pouring white smoke on startup. Pressure tested cooling system, held pressure fine. Ah, the joys of owning a money pit .
Old 10-07-2012, 03:50 PM   #140
byun
Member#: 258046
2011 Impreza WRX
13k on my eqtuning stage 1 block, Beat on daily
byun is offline   Reply With Quote
Old 10-08-2012, 11:43 PM   #141
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
EJ205 built by my subie guy and mostly assembled by me.. Hard Break In! Honed, Rebuilt heads, Stock Internals with ACL main & rods. Running Cobb Stage 3 (93oct) VF39, Sti Pinks on 19lbs catless etc.. she stinks, only a small puff of smoke on extremely hard driving, startin to weep oil from the valve cover gaskets, runs like a bat outta hell at 42k strong! Building an EJ257... all forged this time.. lol. wish me luck.
99imprezd is offline   Reply With Quote
How many miles on your car? NYCPimP Tri-State Area Forum 65 03-01-2002 06:02 PM
('93-'01) how many miles on your subbie! ellinopedo182 Impreza Forum 118 11-05-2001 07:39 AM
How many miles on your WRX? psoper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-20-2001 05:53 PM
poll: How many miles on your car? Scooby-Z General Forum Archive 64 02-04-2001 12:49 AM
