Old 04-03-2009, 10:25 PM   #1
thepigsti
Member#: 166215
Default 05 STi with Dom3 by Tim at Surgeline
First of all, props to Tim Bailey and the rest of the Surgeline crew. They stayed late to get me out the door with a good tune, even after finding out that I needed a new DP because my Invidia was causing a little too much back pressure after a few pulls. Thorough pre-tune inspection as well that resulted in me getting a new Perrin inlet, as I couldn't get the APS to fit; as well as checking/fixing all vacuum and fuel lines as necessary.
Great guys, good to chat with and obviously they know what they are doing. Tim was nice enough to come out of the tuning bay several times to tell me what he was seeing and what he thought, as well as asking my input for what I would like to end up with. A great experience overall, I would recommend Surgeline to anyone.
My (power related) setup is as follows:
DW 740cc injectors
Walboro 255lph fuel pump
NGK one step colder plugs
Prodrive 3 port BCS
KStech 73mm CAI
Perrin turbo inlet
Blouch Dom 3 turbo (2.4" inlet)
Perrin FMIC
APS 50/50 BPV
Grimspeed TGV deletes and Phelolic spacers
Perrin EL header
Grimmspeed up
Cobb catted DP
Cobb CBE
Kartboy lightweight crank pulley
On to the graph. I was a little nervous as I have done all of my own work, but everything held together. Max map was 21psi, conservative on AFR and timing as I requested, the other two are 20 and 18 psi. The car feels great, nice smooth power curve that just is great to drive.
thepigsti is offline   Reply With Quote
Old 04-03-2009, 10:59 PM   #2
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Nice Numbers, you should get a C16 tune!
WagonGGA is offline   Reply With Quote
Old 04-03-2009, 11:01 PM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
So you're the guy with the 73mm KS Tech intake Tim was talking about. With my goals I'm going to have to go with the 83mm though.
Anyways, solid numbers. Must drive nice and smooth. Any videos? haha
alcoolaid is offline   Reply With Quote
Old 04-03-2009, 11:03 PM   #4
06njsti
Member#: 150986
06 #001 LSB STi
wow, tim is the man. i wish he was closer to me hear on the east coast
06njsti is offline   Reply With Quote
Old 04-04-2009, 12:42 AM   #5
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
That is a very nice mod list of some great parts
Ntercooled is offline   Reply With Quote
Old 04-06-2009, 08:25 PM   #6
Good2Go
Member#: 100634
04 STi
What was Tim's impression on dialing in the intake maf calibration. How would you say the car drives at low and part throttle with this intake?
Nice list of modifications. My setup is similar.
Good2Go is offline   Reply With Quote
Old 04-06-2009, 11:02 PM   #7
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Nice power! now over lay it with a Z06 corvette
Stames_wiltz is offline   Reply With Quote
Old 04-06-2009, 11:07 PM   #8
Tgui
Member#: 44771
Why bother with a large MAF when AP supports speed density?
Tgui is offline   Reply With Quote
Old 04-06-2009, 11:08 PM   #9
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
why would he want to do that?
godforbid67 is offline   Reply With Quote
Old 04-06-2009, 11:10 PM   #10
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
Because everyone running a dom 3 is clearly bench racing zo6 corvettes now
j255c is offline   Reply With Quote
Old 04-06-2009, 11:21 PM   #11
godforbid67
Member#: 137168
06 Built SGM WRX
c6 z06?? would make hella more then that. probably about 100 wheel more and starting 2k rpms sooner...... sound about right?
Old 04-07-2009, 01:05 AM   #12
Stames_wiltz
Member#: 143264
2006 WRX TR
I did! http://forums.nasioc.com/forums/show....php?t=1734669 Look at second dyno down.
It would give a better barometer for how much power he really is making
OFF TOPIC:
I just am sick of seeing VF39 wrx and STi's that are making 350 whp and 400 torq. with nothing of substance to compare it too. Lets get some bench marks going here. We all know the C6 Z06 is balls fast no matter where you are. but if you are making 350 whp and are 155 whp off of a Z06 then we know that your dyno reads uber high. If you are making 400 whp and the Z06 has you by 20 whp then you have a fast car. That is all I am saying
back on topic and sorry for the rant to the OP.
Old 04-07-2009, 01:57 AM   #13
jutes85
Member#: 127232
E92 M3
98' Foz
It's all about improvements over stock. If the same dyno produces 200/200 for a stock STI, then yes, 350/400 is a great improvement. If you are on the brodyno you can hit 400whp all day long with a VF39.
jutes85 is offline   Reply With Quote
Old 04-07-2009, 02:16 AM   #14
Stames_wiltz
Member#: 143264
2006 WRX TR
I agree it is about improvement. I just like comparisons
Old 04-07-2009, 06:19 AM   #15
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
The thing is, tuning subarus is no longer new like it was in 2002, 2003 when people had no idea how various setups would make power, what the potential of various setups were, etc. etc.
Most everything has been done and done many times now - it is well known how much power a given setup will make. There's no point in fantastical results for a given setup other than the confuse and mislead newbies.
verc is offline   Reply With Quote
Old 06-03-2009, 01:56 PM   #16
thepigsti
Member#: 166215
OFF TOPIC:
Not sure what you are getting at but this isn't a VF39 setup for one, look at the mod list. Secondly, any car (even the Z06) is subject to the same variations on dynos as anything else; they aren't the golden mean.
Your idea only works if every shop keeps a Z06 to run right after each customer car. Or everyone uses dynojets because you can't fiddle with them to change the results. Of course everyone cries about how "high" those read too.
Old 06-03-2009, 02:24 PM   #17
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Great looking curves! Looks like a very potent street set-up.
Steve.804 is offline   Reply With Quote
Old 06-03-2009, 06:27 PM   #18
mboulton
Member#: 174433
was is it your catted COBB DP that was giving high back pressure, or something else?
thanks
mboulton is offline   Reply With Quote
Old 06-03-2009, 08:55 PM   #19
thepigsti
Member#: 166215
Sorry I should have been more clear. When I showed up I had an Invidia v3 catted DP on, and had been running it fine with an OTS stage 2 tune for a long time. Tim overlapped a previous similar setup and tune over my dyno plot and showed how mine was spooling 500 or so RPM late. After verifying that there were no exhaust leaks and that the turbine was spinning freely, he suggested that the DP was likely the culprit. I asked them to install the Cobb, and he was right.
Old 06-03-2009, 08:59 PM   #20
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
care on sharing your timing/ POL table.
Old 06-03-2009, 09:03 PM   #21
thepigsti
Member#: 166215
Off the cuff I would say no, only because I didn't tune it myself and I consider the table values to be the IP of the tuner even if legally that is not the case. If you contact contact Surgeline and they are willing to share them with you, I have absolutely no problem with it.
05 STi ATP3071 Tuned by Tim Bailey socalLGT Proven Power Bragging 38 05-25-2009 08:01 AM
06 sti with dom3 upgrade! jazmak24 Proven Power Bragging 43 07-19-2008 12:30 AM
06 WRX tuned by Tim at PDX (CA 91 octane) more_boost_plz Proven Power Bragging 9 02-22-2007 12:44 AM
Dyno tuned GT35r 05 STi with EasyEcu by Ecutek boostinscooby Proven Power Bragging 6 10-29-2006 09:42 PM
