Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 04-04-2009, 12:02 AM   #1
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Default Regrinding stock cams formore lift
Hey, I just met a guy today with a 99 RS 2.5L NA. We began discussing his build, and he started to talk about his stock cams that he had grind to some custom specs. He explain this process and it seemed very logical and affordable.
I have added a link showing his work and the theory of behind this.
http://www.coltcams.com/html/tech_tips/index.cfm
Now i would like to know is this a route worth doing on my engine build. I cannot afford a set a brand new BC cams, and i am unsure if STi cams are worth the money.
I was informed that all i have to do is find my largest shimmed bucket in my 03 WRX heads and find out what is the largest shim available, and pass this information onto the machinist along with where i want to acheive my power and how fast i plan on spinning my EJ22T.
BTW this process is about $80 a cam.
cribbie is offline   Reply With Quote
Old 04-04-2009, 12:10 AM   #2
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
I was quoted more like $180 a cam from delta. They said they had to weld extra metal on each lobe and then grind it back down. Maybe this is different? No welding I guess. Let me know what you end up doing. I'm interested.
Edit: After looking at that link I am not sure that would work for your subaru. Grinding off the bottom of the cam would throw off valve lash way out of spec. You might be able to get some new buckets but that is going to cost a fortune at about $20 a pop. The guy with the 99rs has SOHC heads which are a different style than your WRX cam over bucket heads.
hustleshark206 is offline   Reply With Quote
Old 04-04-2009, 12:18 AM   #3
cribbie
Member#: 184505
2003 WRX
Sonic yellow
I know that there is no welding involved in this process. all he does is machine the "base lobe", which is were we make our measurements when doing valve adjustments. Then you compensate by increasing your bucket shim size from what he removed which then increases your lift.
Now what i would like to know is when people talk about a common BC 272/272 cam compared to a stock WRX/ STi cam does it have both more lift and duration?
Old 04-04-2009, 12:20 AM   #4
cribbie
Member#: 184505
2003 WRX
Sonic yellow
And i believe this process is very cheap and easy for heads with rocker arms (SOHC)
Old 04-04-2009, 12:24 AM   #5
hustleshark206
Member#: 182227
2000 MPS Built RS
I think sti cams would be way cheaper and I have read many threads of people putting sti cams in wrx heads. You have to plug the avcs holes on the cam which seems like a pain in the ass but doable.
Old 04-04-2009, 12:35 AM   #6
cribbie
Member#: 184505
2003 WRX
Sonic yellow
I understand this and i am very capable to under go what is required to install STi cams but considering that this process will run aprox $320 and a set of used STi cams go for around $200ish and the power still dives hard towards reline (just not ad bad as the WRX cams). I would rather spend a few extra dollars and go with something more specific to my build without buying a new set of BC cams for a grand.
Old 04-04-2009, 12:54 AM   #7
hustleshark206
Member#: 182227
2000 MPS Built RS
Hey if you can do it for $320 out the door go for it. It just sounds to me that the machinist is going to determine how much he can grind off your cams by taking the biggest bucket thats available and subtracting the biggest bucket you currently have. By doing this would would have to replace every bucket in your head.
$80 x 4 = $320 for the grind
$20 x 16= about $320 for buckets
320 x 2= about $640 total
Maybe I am wrong here?? Anyone with first hand experience wanna chime in
Old 04-04-2009, 07:12 PM   #8
cribbie
Member#: 184505
2003 WRX
Sonic yellow
I need some suggestions or recommends from experienced builders!
Old 04-04-2009, 07:20 PM   #9
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Buy a set of real cams.
Seriously, this method is full of problems, and the cost of the buckets alone makes it expensive. As well, if you are planning on changing your lift, what are you doing with the valve springs?
Jeff
sponaugle is offline   Reply With Quote
Old 04-05-2009, 12:09 AM   #10
cribbie
Member#: 184505
2003 WRX
Sonic yellow
If this method is full of problems then i would like to hear of them. If i go ahead and buy a new set of cams or even go to a set of STi cams i will still require to purchase some new buckets regardless.
Old 04-05-2009, 12:13 AM   #11
gold rush
Member#: 90110
2004 wrx wagon
You will need seriously thick buckets, better idea is to get the longer 2.5 N/A overhead cam length valves.
gold rush is offline   Reply With Quote
Old 04-05-2009, 09:53 AM   #12
cribbie
Member#: 184505
2003 WRX
Sonic yellow
how much longer are these valves?
Stock cam specs and interchangability- 97 2.5 heads with 04 STi cams? boostedballs Built Motor Discussion 5 05-11-2010 01:10 PM
For sale stock sti heads plus stock cams... with knife edged intake divider west Engine/Power/Exhaust 7 07-08-2007 05:59 PM
cams : lift and duration dpjef Normally Aspirated Powertrain 2 05-14-2003 09:15 PM
Regrinding Stock CAMS?! Firewire Vancouver Impreza Club Forum -- VIC 14 10-24-2001 10:40 AM
Stock Cams and performance cam ideas... Reciprocity Technical Forum Archive 28 06-07-2000 07:37 PM
