Old 04-15-2002, 04:16 PM   #1
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default ARS-turbo-rebuild ?'s
Keep in mind that the search is down right now.
All right, I just bought a used turbo kit with a dead turbo (yes I knew it was dead before I bought it) The kit is a stage II from ASR with a Turbonetics T3-T4 I think, as I can't find any info on them anymore. I took a good look at the turbo to day and found a nut in the exhaust housing, got it out but there some damage to the impeller.
I have a few ?'s. First can the turbo be rebuilt, and what all do I need to fix it? Will a new cartridge do the job, also where is the best place to get it? If I need to replace this unit do I have to get the same unit as what was in it, or can I replace it with something else? Can I up rate it to a ball baring unit?
Can anyone tell me where to find info on this kit, mainly what turbo it is and the specs on it (the only #'s I see on it is as follows on the exh. 20359- int. H0200)?
Also where can i get deltagate wastgate spring from?
Thanks
milkman is offline   Reply With Quote
Old 04-15-2002, 04:49 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
search has been back up since yesterday....
kastle is offline   Reply With Quote
Old 04-15-2002, 04:56 PM   #3
milkman
Member#: 8066
Y2K RSt
OK, your right my system doesn't refresh on it's own for some resone.
Old 04-15-2002, 05:04 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
hehe
Damn system!!
np, just wanted to point it out to you...
Old 04-15-2002, 05:24 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
HKS gave me a good source to rebuild turbos but I can't remember it right now.
try calling turbonetics though. I know they sell rebuilds maybe they can do it or referr you to someone who will.
Brad
STiTuner is offline   Reply With Quote
Old 04-15-2002, 05:33 PM   #6
Jewbaru
Member#: 1994
2013 Impreza WRX
it's my understanding that 90% of all turbo's sold are "rebuilds". They may have a totally new cartridge, but usually the housings aren't new. Call turbonetics, they should be able to fix it for you.
Jewbaru is offline   Reply With Quote
Old 04-15-2002, 05:37 PM   #7
milkman
Member#: 8066
Y2K RSt
I've been searching now and found a place to get W/G springs, but haven't found any specs on the turbo in ASR kit.
Thanks for pointing out that the search is up I've been waiting for it or more correctly waiting for my computer.
Old 04-15-2002, 07:13 PM   #8
milkman
Member#: 8066
Y2K RSt
Default Turbo City to the rescue
Well, I called Turbo City and I'm shipping it to them to have it look at they gave me a ball park price of $150. Does anyone have any suggestion of anything more I should have them do?
Old 04-15-2002, 07:23 PM   #9
STiTuner
Member#: 5778
09 135i
Jet Black
wwhere did you find the Wastegate springs at?
I need a .3 bar spring for my Tial.
Brad
Old 04-16-2002, 12:41 AM   #10
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
try tom from ludespeed. www.ludespeed.com
ac_gohan is offline   Reply With Quote
Old 04-18-2002, 04:08 PM   #11
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
I believe the ASR turbos were sourced from Innovative Turbo, not Turbonetics, although obviously any turbo shop should be able to do a rebuild.
The wastegate spring can be ordered directly from Turbonetics (for the Deltagate; for the Tial, I don't know offhand -- I know RoadRaceEngineering carries Tial stuff, but there may be better sources).
If your T3/T4 was the same as the other ASR turbos, it has a 40-trim compressor wheel with a .42A/R turbine.
the Dabbler is offline   Reply With Quote
Old 04-18-2002, 07:44 PM   #12
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Anyone know if a Turbonetics spring will some how fit on an internal wastegate for an IHI RHB5 Legacy turbo?
I need to find one, and am having some bad luck, so if anyone knows I would appreciate it greatly.
Graham
Graham is offline   Reply With Quote
Old 04-18-2002, 07:47 PM   #13
STiTuner
Member#: 5778
09 135i
Jet Black
what do you need a new spring for graham?
did you decide to stay away from the EBC?
Brad
Old 04-18-2002, 07:51 PM   #14
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Yah I don't think that the EBC is the best option, as some guys on here (Jewbaru in particular) had some stipulations with them that caused their cars to boost spike and have wastegate problems.
After installing the ITC, I don't think that 2 more lbs. of boost would hurt, just have to find the spring.
Graham
Old 04-18-2002, 07:56 PM   #15
STiTuner
Member#: 5778
09 135i
Jet Black
Graham,
PMed you.
Brad
TD04-13T turbo rebuild question... WRXturboWagon02 Newbies & FAQs 9 01-16-2009 07:09 PM
Turbo rebuild question mingstersol Southern California Impreza Club Forum -- SCIC 6 09-27-2008 02:59 PM
Turbo Rebuild Questions (Forced Performance) APSWRX1 Texas Impreza Club Forum -- TXIC 8 12-21-2005 04:11 PM
Turbo Rebuild Question KKoepp31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-09-2005 10:24 PM
93 legacy turbo rebuild questions HomeSlice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-05-2002 10:35 AM
