Old 04-04-2009, 05:39 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Info Request: Converting from 90 degree to Modern update turbo setup
So this is kind of a general info/knowledge question. For those of us who have the old 90 degree inlet setup, how does one update to the modern inlet setup of Intake->inlet hose-> turbo If you update to a non 90 degree inlet turbo. Can you reuse your Ej20g/ej22t Maf sensor and plug it into the modern intakes?
Just wondering how it works.
JDMFLCL is offline   Reply With Quote
Old 04-04-2009, 06:30 AM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Ohhhh that's a good question. Normally I see lots of silicon joiners and clamps when people ditch the 90* stuff.
i_c_the_light is offline   Reply With Quote
Old 04-04-2009, 08:09 AM   #3
RallyColtTurbo
Member#: 16819
2002 MBP WRX, '98 OB
Three Gen 1 Legacy Turbos
Silicon adapter is the most common. With that you run basically stock stuff up to the adpater.
If your running phase 1 DOHC heads you could swap to an EJ20K (or Legacy twin turbo EJ20H/R) intake manifold and run a full under-the-manifold intake tract. Yes, an EJ20G/EJ22T MAF will bolt to a later airbox. But not too late, they started building them into the filter housing at some point (GD+?).
RallyColtTurbo is offline   Reply With Quote
Old 04-04-2009, 09:49 AM   #4
JDMFLCL
Member#: 180513
Baby Baby C'mon!
thanks for the info, the main points of confusion was if the MAF would work and the under manifold deal.
Just trying to understand these JDM engines better....slowly
Old 04-04-2009, 10:02 AM   #5
jaimebenlasnow
Member#: 188065
Do you guys have any photo with a 90 sillicone? do i only need one sillicone to do this setup cause i'm worried of boost leak
jaimebenlasnow is offline   Reply With Quote
Old 04-04-2009, 10:11 AM   #6
JDMFLCL
Member#: 180513
Baby Baby C'mon!
So the Ej20G manifold doesn't have the clearance underneath as the Ej20k/ej20h? I take it thats why you have to switch
Old 04-04-2009, 10:13 AM   #7
jaimebenlasnow
Member#: 188065
Yeah there's no clearence under the manifold for the inlet tube
Old 04-04-2009, 10:14 AM   #8
JDMFLCL
Member#: 180513
Baby Baby C'mon!
now if you convert to Map, you can just run one of those really short SRI's that is just filter-> inlet
correct me if im not mistaken?
Old 04-04-2009, 10:25 AM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
To be totally honest with you, I really don't understand why you are looking at doing this. You've finally got your car running and you're going to go back in there and F-around with it again? I would be thinking you would want to enjoy it at this point. Have you even driven the car yet? I think with the work we did to it, you won't barely "recognize" the car when you drive it.
That said, if you are serious about using a newer turbo with a straight inlet AND a FMIC as you keep mentioning here and there what you want to do is get a rotated kit. This solves the inlet issue simultaneous to the FMIC. It's the cleanest and easiest install. If you contact Troy at Suba in Denver, he can put something together for you.
Old 04-04-2009, 10:30 AM   #10
jaimebenlasnow
Member#: 188065
Well for me is that its pretty hard to find a new turbo with a 90 degree inlet
Old 04-04-2009, 10:31 AM   #11
JDMFLCL
Member#: 180513
Baby Baby C'mon!
you misread my intentions I was just seeing on RS25 some people were switching to this kind of setup and i was just wondering how it works, as i've never seen a Ej20k side by side with a Ej20g. Truly just to better inform myself, nothing more to it.
I just want to be more knowledgeable about the different subaru turbo offerings throughout the year, and be able to differentiate between their nuances. Just want to expand my knowledge base.
Asside from the superior Ej20k nissan MAF sensor, was there any real benefit for subaru in doing away with the 90 inlet? It seems like having your intake right over your engine isn't exactly going to do wonders for the intake air temp.
As for more power, that is so far down my list, i'm not even sure i'm even going to address that in ~ 2 years.fixing those god awful 5zigen springs and revamping the suspension along with dericing the exterior/repaint are far higher on my to do list.
I greatly appreciate the work you guys did - i haven't returned yet, but my stepbrother did a little lap around the block, and it was great from what i was told. now to find dumpster for that ****ty C west bumper.
Old 04-06-2009, 04:52 PM   #12
thad
Member#: 176616
1994 impreza
white
Hey cool, Somebody made a thread about this, i was about to do it myself.
I'm still in the planning phase of this project and have not decided yet if its actually going to happen.
I have a spare 98 EJ20G with bad compression, so I want to find a way to work it out to my advantage.
The problems I've run into so far are these:
-Throttle body: its turned 180, so the cable has to come in from the other side,I think worst case on this one is a WRX cable.
- TPS: its a 3 pin as opposed to 4 (i think its just missing the idle switch) might have to retro fit the TB with the old TPS
-MAF : as stated earlier in the thread, MAF fitment will need to be adressed.
-Intercooler clearance : this is my main concern right now. I have a WRX intercooler that I was going to use with this setup, but after just holding it up to the motor, I can see that it definitely won't fit, even with the Bypass valve port blocked off and a differnt valve used, the protrusion for the BPV still hits the IACV. I can space the intercooler further back from the TB with a longer TB to IC hose, since there is about 1.5" more clearance on the V3 20g than the v2, but that may give me a firewall clearance issue.
A though I had to remedy this was, if compatible, use a 2002 WRX TB and IAC and put a plate over the external IAC location to gie me room for the intercooler and BPV.
I have yet to verify if the WRX TB would even bolt on to the 20G/20K manifold, or if the ECU could control the IAC (though the wires seem to have the same roles).
the second option I considered, was to cut off the BPV flange so the IC is flush along that edge, then weld it up and put a 90 deg elbow on it (essentially making a 20K IC)
but I really don't want to cut up an intercooler.
last issue is
-turbo: i'd be giving up a 16g in favor of a TD04L, I don't have money for a better turbo, and while I'd really like to try out a TD04, I don't think I would want to do so much irreversable work for an expreriment that ultimately leaves me with a power deficit.
anybody else have input? I could use some informed opinions.
thad is offline   Reply With Quote
Old 04-07-2009, 12:28 PM   #13
JDMFLCL
Member#: 180513
Baby Baby C'mon!
98 is ej20k
Old 04-07-2009, 03:38 PM   #14
thad
Member#: 176616
1994 impreza
white
98 is ej20k
ok, maybe its a 97.
the timing belt cover sticker was damaged on the 3 digits right after EJ20G.
Old 04-07-2009, 03:43 PM   #15
JDMFLCL
Member#: 180513
Baby Baby C'mon!
its a k still
92-96 is Ej20G
Old 04-07-2009, 05:25 PM   #16
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
ok, if the EJ20K is 97+, the JDM dash i got with my clip (V4 STi) is the same as the 93 dash i pulled out of a junkyard, except for the whole RHD part. did they not change the dash like they did in the US?
Rei_Akira is offline   Reply With Quote
Old 04-07-2009, 06:09 PM   #17
bape-ape
Member#: 136009
96 RapeWagon
Ugly
There is a late model 20K variant coded 20G after 96. You should be able to use a 20k manifold and coilpack on the older style Gs.
bape-ape is offline   Reply With Quote
Old 04-07-2009, 06:53 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
The only noticeable dash change that I know about occurred in '99.
Old 04-08-2009, 05:45 AM   #19
GodSquadMandrake
Member#: 175435
1995 Ẽfini RX7
Brilliant Black
I'm converted. I just have the EJ20H intake manifold installed on my EJ20G heads, mostly because I couldn't find an EJ20G manifold. There are a couple of different ways that you can do it but they all work.
Slodrive has a really detailed thread about how he did it on his Legacy here:
http://bbs.legacycentral.org/viewtop...r=asc&start=25
Now I did mine a little for simple. I ditched all of the stock breather and PCV stuff and I am doing a custom "catch can" that is a Mann Provent 200 Air/Oil separator from a diesel truck. There are a lot of threads on it if you are interested.
I also ditched the recirc valve and went with an atmospheric BOV that bolts directly to my 2006 WRX TMIC. There are issues with an atmospheric BOV of course but that is for another thread...
For the throttle body I had to flip it upside down and rotate the TPS 180' like Slodrive did but instead of making some crazy spacer/adapter plate to get the TB to bolt onto the manifold I just took an angle grinder and made some clearance for it to fit! Mine works without a problem and I don't get why he went through the trouble of making the adapter plate...
Here is the boot he used:
I used a different one but it's made by the same company "Autobahn88" on Ebay. They have two different designs. His is made especially for the EJ20H, mine is made for a GC8 WRX. Because I changed my breather and recirc valve setup the GC8 WRX one works better. They both will fit the same under the manifold though, no problem there.
After the inlet you could go with the rest of the WRX intake if you wanted or basically anything you want. I plan on bringing my filter in from behind the passenger side headlight and deleting the ABS pump that is in the way there. Then building a little divider wall with some thin sheet metal (bends easy and cuts with tin snips) and putting some RV weather stripping on it to get it to seal against the frame and hood and then cutting a hole in the hood and installing one of those generic vents. So it's basically a poor man's version of a cold air intake box. I could bring the air in from the fender which is just as good but it makes it harder to check and clean the filter and this is a rally car. I also could put the filter somewhere higher up on the car so it doesn't get water logged as easily but I think that I'll try this and it should be ok.
As far as the MAF sensor goes I haven't decided if I am going to just delete it and create a map using a MAP sensor and IAT sensor, or if I want to keep the MAF for when the car is not under boost and just use the MAP sensor when there is positive intake manifold pressure. I guess I'll try both and see how well the ECU responds to it. I am using Greddy E-Manage Ultimate. I've heard nothing but good things about the MAP it's just harder to tune.
GodSquadMandrake is offline   Reply With Quote
Old 04-08-2009, 04:00 PM   #20
thad
Member#: 176616
1994 impreza
white
i think it was either 96 or 97 the dash was altered a bit, the top was convex instead of concave and I believe they all had the passenger side airbag.
out of curiosity, how does that late ej20g TD04L stack up to the US spec WRX version?
I think I'm going to hold off on this conversion for a while.
when i do get around to it, my primary goal is to get it running and looking as close to oem as possible.
Old 04-08-2009, 05:30 PM   #21
Rei_Akira
Member#: 194555
1997 GC8 coup
green
i think he was talking about the japan dash, as the dash that came with my EJ20K (should be out of a 97/98 right?) is still convex with no airbag as my 97 coup had the concave with airbag, but im converting to a USDM 93 dash as its concave like the JDM and has no airbags (swappin to the JDM steering column as well so no airbags there now either).
haha sorry for jacking the thread >.<
Old 04-08-2009, 06:31 PM   #22
bape-ape
Member#: 136009
96 RapeWagon
Ugly
That TD04 is a wee bit better from what I have heard.
Old 04-14-2009, 03:45 PM   #23
thad
Member#: 176616
1994 impreza
white
So i borrowed a WRX throtle body and bolted it one to msee what the clearance would be like, fits like a dream, the only interference is with the IAC pipe that goes over the manifold, that would be removed, and the throttle plate rotates the opposite direction, but i cannot forsee that being an issue. the bigger problem is as I had anticipated, different input signals for the IAC, ej20g being dc 6-9 v open closed to open on 2 wires, and ej205 being 0-14v waveform signal on one wire. I may not be clever enough to make that work with a reasonable amount of effort.
Old 11-29-2011, 12:57 AM   #24
thad
Member#: 176616
1994 impreza
white
topic resurrection, anyone have details on the TB modification. GodSquadMandrake maybe?
OGC's new logo turns heads! (turn your head 90 degrees to your left shoulder). WRXdonkey Off-Topic 18 04-26-2008 04:42 PM
rear brakes from 90 leg to 98 leg? sketron13 Legacy Forum 8 12-26-2007 08:46 PM
90 degree to straight inlet conversion Natoe Subaru Conversions 9 10-06-2005 10:59 AM
C++ How do you convert from a float to an integer? Corn-Picker Off-Topic 28 10-04-2002 03:56 PM
Message Board Statistics All times are GMT -4. The time now is 12:49 AM.
